Welcome to the North American Subaru Impreza Owners Club Tuesday May 5, 2015
Old 02-23-2013, 03:47 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default DIY front axle / knuckle on WRX (with pictures)
Well, I've taken some pictures from today's install on 2002 WRX sedan (axle + replacement knuckle).
Tools you need:
I did not have to use ball joint separator; instead used arm puller, which pretty much does the same thing.
You absolutely must have a roll punch set. Not needed on certain model year.
1. Use 32mm socket to remove axle nut with wheel on the ground. Once removed, go ahead and remove wheel, caliper, etc....
2. Use a roll punch kit to remove the pin (pin comes out of flat side / not chamfered side). One useful tip is to have both front ends off ground, which will allow you to turn axles freely.
3. Remove 19mm bolt and use tie rod end separator to separate it from the knuckle. Never use ball joint fork kit which will 100% damage the boot (this step not necessary if you're not going to remove the knuckle).
4. Remove pin from the ball joint nut. You can find replacement pin from autozone for cheap.
5. Use arm puller to separate ball joint from the control arm. You will hear a loud pop when it separates!
txl146 is offline   Reply With Quote
Old 02-23-2013, 03:51 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
6. Remove 2x19mm bolts/nuts from the strut, which will allow you to remove the knuckle from the control arm/strut. Axle can now be also removed (skip this step if you're just replacing axles).
Axle can be removed by pulling it toward you. You will need to wiggle around the knuckle in order to have enough room to remove axle.
7. EMPI vs. Stock Axles (I am returning them for a refund due to poor fitment).
Removed knuckle with 105k miles, which will be replaced with knuckle from 2007 WRX with 55k miles. I plan to install new ball joint & new wheel bearing.
8. Make an appointment to get wheel alignment done!
Make sure to apply enough anti-seize when putting back everything!!!
Old 02-23-2013, 03:58 PM   #3
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
If you're just doing the axle, you can leave the knuckle attached to the strut. This will allow you to skip the alignment afterwards.
vision.dynamix is online now   Reply With Quote
Old 02-23-2013, 04:29 PM   #4
alx8283
Member#: 225024
2002 wrx
Txl, what was the fitment issue for you? Larger boot contacting the bottom of the strut?
I've never used roll punches. I've got a round file that gets in there, and a $1 screwdriver with the head cut off
Ps, great write up as usual!
alx8283 is offline   Reply With Quote
Old 02-23-2013, 06:29 PM   #5
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Only if you have female axles.
Counterfit is offline   Reply With Quote
Old 02-23-2013, 08:02 PM   #6
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Thanks everyone for your input.
alx8283, fitment issue I was having is pin hole not aligning correctly and one axle not sliding in no matter what I did (2nd one slid in without any issue). I decided to just keep OEM stock axles as reason for replacing nuckle/axles was to replace bad ball joint.
Old 02-23-2013, 08:06 PM   #7
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Rotate the axle 180* if the pin isn't lining up. It is NOT exactly centered.
Old 02-23-2013, 08:22 PM   #8
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I did try to rotate the axle, but still wouldn't align correctly. To make it worse, only one of two axle slid in completely.
Old 02-24-2013, 09:29 PM   #9
alx8283
Member#: 225024
2002 wrx
That's too bad. I've used EMPI axles on quite a few subarus and vw's with zero fitment problems. It happens though, and at least you were able to reuse your stockers
Oh yeah, one more step: stake the new axle nut.
Old 02-27-2013, 08:13 PM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
I just received replacement used OEM axle purchased from eBay in awesome shape. Install went smoothly without any fitment issue.
Old 03-05-2013, 07:53 PM   #11
SirRichieLee
Member#: 331655
2006 WRX Wagon
Crystal Gray Metallic
How about installation? I'm having trouble getting the hub back into the arm
SirRichieLee is offline   Reply With Quote
