Old 05-27-2010, 11:10 AM   #1
mikeemoscooby
Member#: 247847
GC prez
white
Question AWD swap? what cars can parts be used from?
I have a 93 impreza fwd and wanting to do awd conversion. I am trying to find out what cars you can use parts from. like there is a buch of 91 legacys around here and wondering if any parts are compatible like the x member , rear end struts so forth and so on.
mikeemoscooby is offline   Reply With Quote
Old 05-27-2010, 03:56 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Yes you could use all the legacy parts except the driveshaft, it's longer.
Old 05-27-2010, 04:17 PM   #3
mikeemoscooby
Member#: 247847
GC prez
white
alright . thats awesome cause i can get the whole rear end setup for about $250
Old 06-27-2010, 11:07 AM   #4
JoshP
Member#: 94350
what about newer legacys? 95-99 stuff
JoshP is offline   Reply With Quote
Old 06-27-2010, 11:57 AM   #5
69subaru360
Member#: 159682
1995 WRX
2015 F150
It all fits the impreza except the driveshaft.
Old 07-03-2010, 12:09 AM   #6
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Quite simple, like legos... Bro
Old 11-03-2011, 09:01 PM   #7
MNMarine1992
Member#: 298259
96 Impreza Outback
Green
Sorry to thread jack but if i have a 96 impreza outback and i get a 93 impreza coupe everything should really be bolt in right? they have the same wheelbase and everything right?
MNMarine1992 is offline   Reply With Quote
Old 11-03-2011, 10:18 PM   #8
69subaru360
Member#: 159682
1995 WRX
2015 F150
It's all the same
Old 11-04-2011, 10:42 AM   #9
MNMarine1992
Member#: 298259
96 Impreza Outback
Green
I thought so, I just wanted to be sure before i bought another subie for another 1400. This one I am going to have some fun with.
Old 02-24-2013, 11:11 PM   #10
krazebill
Member#: 306001
1995 Impreza L
Green
Not thread jumping...but does the gas tank from the legacy fit the impreza?
fwd impreza tank has no hump for driveshaft.
krazebill is offline   Reply With Quote
Old 02-25-2013, 03:11 AM   #11
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
1998 Declasse Moonbeam
Yes, bolts right in.
I used a gas tank from a 1991 Legacy Turbo in my 94 Impreza Brighton.
Though IIRC the GD chassis has a slightly higher (1 gal IIRC) capacity. If you can get one on the cheap it might be worth it. Plus it has the built in "surge" tank.
Old 06-16-2014, 04:12 AM   #12
Krang
Member#: 134272
Chapter/Region: HIIC
2007 Sti, DGM
Rotated EFR 6758
So the GD tanks will fit the GC body?
Krang is offline   Reply With Quote
Old 06-17-2014, 07:38 PM   #13
Hondaslayer
Member#: 4562
1995 Legacy LSi
I'm running a GD tank in my wifes SF Forester.
Old 06-17-2014, 08:34 PM   #14
69subaru360
Member#: 159682
1995 WRX
2015 F150
Physically fits yes. The hoses are different, especially if you have an older one like 97 or older. More emissions stuff. It all can be made to work though. It's fairly obvious what you need to do when you look at them side by side. There is a check valve thing you need to remove or you won't be able to fill the tank.
Old 06-18-2014, 06:19 PM   #15
Hondaslayer
Member#: 4562
1995 Legacy LSi
I assume you swapped the pump, filler neck etc......
I just used the tank and reused the SF stuff.
Edit: Speaking of, I need a new filler neck, hers rusted out and will fail emissions in October
Can AP be used for WRX also??? fastseven Texas Impreza Club Forum -- TXIC 6 08-28-2005 05:55 PM
17' Astro Bass Boat - Can also be used for skiing w/harness. Disgruntled Bay Area Impreza Club Forum -- BAIC 1 05-01-2005 04:32 PM
SubaruBucks. Can they be used for parts AND labor? plunk10 General Community 8 10-07-2004 10:20 AM
what car can be fitted EJ20 engine other than Subaru? PUMPKINS Subaru Conversions 31 07-08-2004 03:53 PM
OEM front camber bolts, can they be used in rear? edubb11 Brakes, Steering & Suspension 7 03-10-2004 02:29 AM
