Old 02-09-2013, 06:11 PM   #2626
Subarufreak199
Member#: 230057
2010 Impreza
I just bought a 95 Impreza L wagon 5-speed, is there a version of the v3 formula for high millage cars?
And i hear a whining from time to time while in 4 and with mostly, it pulsates until i take my foot off the gas, could this be the rear diff or an axle? (i ask because if it’s the rear diff, then this forum makes it an easy fix)
Subarufreak199 is offline   Reply With Quote
Old 02-09-2013, 11:15 PM   #2627
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Originally Posted by Superorb View Post
If you have an 02 WRX you won't be able to downshift into 1st until you're going really slowly, like 2mph. On my 02 WRX I have to be at a complete stop to shift into 1st while the car is still warming up.
yeah...until it is warmed up....it wont go back into 1st until almost stopped regardless of what is in the trans
Old 02-11-2013, 02:07 PM   #2628
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
Even when mine is warmed up it won't go into 1st unless I'm barely moving. While cold I have to come to a complete stop and wait a second before it goes into 1st. Real PITA in Colorado.
Superorb is offline   Reply With Quote
Old 02-11-2013, 10:53 PM   #2629
Uncle Scotty
OK buy Nates beans
i can and could heel and toe or rev match both of my wrx's to go into first at any reasonable speed once warmed up
NEVER had any issue with first other than when the car is stone cold
Old 02-12-2013, 09:36 AM   #2630
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
^same here
With a double clutch + rev match it should go right in. If you get everything spinning the same speed there is very little for the synchro's and fluid to have to do.
Old 02-12-2013, 01:58 PM   #2631
Superorb
Member#: 135252
2002 WRX Wagon
86% Operational :(
I've tried the double clutch route and it doesn't play nice. Used to do it on my Honda and it worked wonderfully.
Old 02-13-2013, 03:29 AM   #2632
shemoves
Member#: 80663
2005 STi
Prolly gonna try this in my '97 Outback as it has a 1st and Reverse grind unless I am gentle with it.
shemoves is offline   Reply With Quote
Old 02-13-2013, 03:58 AM   #2633
Uncle Scotty
OK buy Nates beans
make sure you use the v3 formula and quantities as they are different
Old 02-14-2013, 03:00 AM   #2634
D-Rodman
Member#: 110078
05 saabaru artc gr
02 wrx wag wrb ej207
Tried the latest version of the cocktail in my 02 5 speed but it didn't feel nearly as good as the subaru extra s I had before. Went back to the subaru oil, much much better, quiet and effortless.
D-Rodman is offline   Reply With Quote
Old 02-15-2013, 02:50 PM   #2635
Chuckls
Member#: 280696
2005 WRX
Waiting on my redline to arrive then I shall throw it in mine! Second and third are becoming a bit notchy.
Chuckls is online now   Reply With Quote
Old 02-15-2013, 04:23 PM   #2636
Uncle Scotty
OK buy Nates beans
you are one of the few.....are you sure you used the correct products in the correct ratios???
Old 02-15-2013, 04:24 PM   #2637
Uncle Scotty
OK buy Nates beans
....redline is a company....NOT a product
Old 02-16-2013, 12:31 AM   #2638
D-Rodman
Member#: 110078
05 saabaru artc gr
Absolutely, your blend works better than the Mobil 1 gear oil I once used in one of my cars for a short time, that was terrible. I have no transmission issues with my cars, no grinding, nothing. I can feel the mechanical difference with each oil type I've tried. I'm easy going on my stuff, got 170,000 miles out my stock clutch on the bugeye and still on the stock clutch in my saabaru at 143,000 miles. It's a matter of preference, I'm a perfectionist, I know what I like, subaru extra s just feels superior.
Old 02-24-2013, 05:42 AM   #2639
N/A_junkie
Member#: 99961
03 Super Obnoxious
Wrx. A rare blue one.
Ugh...I hate to be a non-searcher. But I'm mid swap and noticed the change from lightweight to heavyweight Redline fluid (Grimmspeed still has the lightweight in the group, I ordered it quite awhile back, I'm old and lazy)
Why the change?
I know it's not going to make my car burst into flames. Just wondering.
N/A_junkie is offline   Reply With Quote
Old 02-24-2013, 07:03 AM   #2640
Uncle Scotty
OK buy Nates beans
Why the change?
lasts longer....LOTS longer....smoother
Old 02-24-2013, 10:43 PM   #2641
Chuckls
Member#: 280696
2005 WRX
Got mine in...Holy crap, what a difference.
Now I just have to deal with my friend giving me crap because he didn't like it when he used it.
Old 02-24-2013, 11:29 PM   #2642
Uncle Scotty
OK buy Nates beans
tell the wanker to piss off
Old 02-25-2013, 09:21 AM   #2643
cuztomimportz
Member#: 97904
World Rally Blue
I need to do this cocktail mix...seems like it will solve my slight grind into 4th gear. Doesn't happen all the time but its worth a shot I guess. I wonder if GrimmSpeed will sell the heavyweight redline instead of the lightweight. I'll have to call them.
cuztomimportz is offline   Reply With Quote
Old 02-25-2013, 10:17 AM   #2644
P-Train
Member#: 279233
2008 WRX
I'm sure I've read this at one point or another since I've got this sub'd. Roughly how much is "LOTS longer"?
P-Train is offline   Reply With Quote
Old 02-25-2013, 03:02 PM   #2645
N/A_junkie
Member#: 99961
03 Super Obnoxious
Thank you sir. I'll make note of that for the next go around.
I'm pleased with the results even with the lightweight. Lots smoother, quieter, and even eliminated a small 'grind' I had going into 4th.
Old 02-26-2013, 12:28 AM   #2646
Uncle Scotty
OK buy Nates beans
long enough that you can easily run it to a 30k mile change interval....the v1 and v2 only lasted about 15k.... 20k MAX
Old 02-26-2013, 08:46 AM   #2647
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
I'm having the same issue. Is your grind under normal driving conditions? Mine grinds only when doing a 60mph pull in 3rd gear as I shift into 4th..
2.5L Monster is offline   Reply With Quote
Old 02-26-2013, 09:33 AM   #2648
vicious_fishes
Member#: 158864
2003 SOHC destroker
yeah track 3rd to 4th i get it. the 3-4 is very fast shift and probably the most common shift (traffic etc) so the syncros are most worn.
cocktail FTW.
Old 02-26-2013, 09:48 AM   #2649
cuztomimportz
Member#: 97904
World Rally Blue
Yeah under a hard load it will grind. But it has occasionally done it under normal driving conditions but that's very rare.
Old 02-26-2013, 10:10 AM   #2650
2.5L Monster
Member#: 307177
2k4 WRX/WRB
Shuckin' & Drivin'
cocktail FTW.
Just ordered the Cocktail from Grimspeed can't wait to change the fluid
Bartender: One Chim's cocktail please. chimchimm5 Off-Topic 0 06-30-2007 05:34 PM
FS: One (1) Uncle Scotty's Cocktail FunkMasta VIC Private Classifieds 14 05-07-2007 11:09 PM
uncle scotty's cocktail with superlight? RUrunning Service & Maintenance 8 11-12-2005 05:29 PM
Who uses Uncle Scotty's cocktail? Impr3zy0u Transmission (AT/MT) & Driveline 25 09-18-2005 09:33 PM
Update: Uncle Scotty's cocktail with 80w90 hype-R-29 Transmission (AT/MT) & Driveline 17 09-07-2005 09:36 AM
