#1 |
Member#: 305528
BAIC
Vehicle:2011 WRX Black |
Hey all, I'm trying to decide on a single din head unit for my nexus 7 install,
My budget is around $250, AUX in, USB and BT are a must. Current short list is as follows: Alpine CDE136 Kenwood Excelon 996 JVC KD-R80BT Does anyone have any opinions on these head units? or have better recommendations? how do they fare by themselves? and are would they be worth upgrading with an amp later down the road? thanks!
#2 |
Member#: 262767
SCIC
Vehicle:2011 WRX Base Hatch White |
While I think those Nexus 7 installs are really cool if you are just using existing hardware you already own...I think it's a better value to just get an AppRadio 2 and use ARLiberator with your Android phone (assuming you own one).
http://slickdeals.net/f/5869092-Pion...-in-Rebate-NEW If not, I like the 996 you have a lot as well as the Pioneer DEH-80PRS. |
#3 |
Member#: 305528
BAIC
existing hardware would mean the stock HU, which I absolutely abhor, half the time it will glitch when trying to pair my phone.
As for the appradio, pioneer will never be able to update their firmware fast enough, as it is right now, my nexus 4 is incompatible with it. it also seems pretty laggy when running with AR liberator, or maybe it was just because of the galaxy s3 was not running jelly bean the 80PRS is nice, but kinda pricey. Last edited by w0ng3r; 02-23-2013 at 06:54 PM. |
#4 |
Member#: 262767
SCIC
I'm running a Nexus 4 with the Appradio 2 and ARLiberator. I don't think it's laggy at all. Not as smooth as just on the phone, but I'd say it's 95% there and that's good enough for about $280 bucks right now.
The 80prs is right in your price range. If you are thinking about mounting it behind the nexus 7, don't get the 80prs though since the face plate is pretty thick, it wouldn't allow you to close it off. I tried a quick test fit because I happened to own a nexus 7 and 80prs and it was a no go. Ultimately, your car and your call. I was thinking about going the nexus 7 route too, but when the 80prs didn't fit behind the 7 without hacking some stuff out I went the app radio route. |
#5 | |
Member#: 305528
BAIC
I think at the end of the day, the only real reason i dislike the appradio is the resolution is alot lower compared to the nexus 7. But I will have to give it some serious cost vs benefit thought but thanks for the great info, keep it coming guys ![]() Last edited by w0ng3r; 02-23-2013 at 09:44 PM. |
#6 |
Member#: 345825
MWSOC
Vehicle:2013 WRX 4dr Dark Grey |
Wow. I didn't know this was an option. With ARLiberator and Appradio2 do you have to have your phone's screen on all the time? What happens if you turn the screen off?
I'd think this drains battery. I have a GS3 which has MHL so I might be able to charge it at the same time. Also, what is the sound quality like on the SPH-DA100? A big reason for me upgrading is the crappy sound coming from the OEM HU. |
#7 | |
Member#: 305528
BAIC
there's an app for turning off your device screen while keeping it on the headunit, can't remember what its called. the da100 has a really low powered internal amp though, i think its 12-14 watts rms. |
#8 |
Member#: 345825
MWSOC
ah yes here it is
https://play.google.com/store/apps/d....screenstandby after looking into this more, i don't think this specific HU will fit my needs. The video mirroring is awesome but it doesn't have CD player, HD radio, auxiliary input, or A2DP to stream music from bluetooth If they release a unit that does have all those features then I'm definitely in |
#9 | |
Member#: 262767
SCIC
- CD player...correct not one in there but couldn't you just rip and put it on your phone? - HD radio...totally correct again. Try tunein or iheartradio apps though as they have a ton of channels. - Aux input...what would you need this for if it can play everything on your phone? -A2DP...again what would you need this for because presumably you'd be streaming from your phone right? Sounds like I'm a huge ARL fanboy =). I guess I am...just very happy with the set up. |
#10 | |
Member#: 345825
MWSOC
I do want the ARL streaming abilities, but not at the cost of the others. Hopefully Pioneer will expand their offerings |
#11 |
Member#: 348221
Vehicle:2008 impreza blue |
I have owned many head units and I would have to say Kenwood seems to always trump everyone else. They are great radios, easy to use and highly compatible with BT
