Old 01-28-2013, 11:08 AM   #2426
96accord
Member Sales Rating: (30)
Member#: 145105
2015 WRB WRX Limited
2007 WRX Limited (sold)
Originally Posted by IMPORTIMAGE View Post
pm sent on the bc's
havent tried feals, I can only tell you that my customers call me after they've tried them and purchase bc's....thats been our feedback so far.
Thanks.
You can disregard the PM reply to ya.
96accord is offline   Reply With Quote
Old 01-29-2013, 08:13 PM   #2427
IMPORTIMAGE
NASIOC Storefront Vendor
Vendor Sales Rating: (617)
Member#: 79304
CALL 941-257-9618
www.ImportImageRacing.com
No prob. Have a good one
__________________
Open Daily
#1-941-257-9618 AIM= importimagerace
Best Deals on
!!! WE BEAT ALL PRICE QUOTES!!!!!
IMPORTIMAGE is offline   Reply With Quote
Old 02-04-2013, 01:59 AM   #2428
rymaggi
Member Sales Rating: (17)
Member#: 253442
Rear top hats started to clunk. Are they under warranty. I purchased through importimage.
rymaggi is offline   Reply With Quote
Old 02-04-2013, 07:29 AM   #2429
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
their warranty is 1 year. so if its before yes, if after it's under their "no more then $95 per corner replacement" warranty. call bc's tech line 321 206 6381 and they will get you going.
__________________
Open Daily
Best Deals on
Old 02-04-2013, 12:27 PM   #2430
DurtyB
Member Sales Rating: (2)
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Installed my coils a little over a week ago now. Just started to get a rubbing noise from both front coils when turning the wheels. Anyone else get this? Everything appears to be tight, preload was set to 5mm. Sounds like rubber rubbing on something near the top of the coils..
DurtyB is offline   Reply With Quote
Old 02-04-2013, 01:11 PM   #2431
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
that would not be normal. i would call them real quick to diagnose it
__________________
Open Daily
Best Deals on
Old 02-04-2013, 06:21 PM   #2432
tehknikhal
Member Sales Rating: (8)
Member#: 227548
2009 09 WRX Sedan
Obsidian Black Pearl
Get under the car and check and see if your wheels are sitting on the coils.
tehknikhal is offline   Reply With Quote
Old 02-06-2013, 03:16 PM   #2433
Quatty-24BS
Member#: 290298
2007 Impreza WRX TR
Blacked
Ill be purchasing these very soon and I love all the reviews so far iv gotten / get the swift springs and also before install make sure everything is nice and tight I can't wait
Quatty-24BS is offline   Reply With Quote
Old 02-06-2013, 04:19 PM   #2434
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
Nothing is rubbing. Was told to grease the spring perches. Will do that tonigth and report back.
And to keep this relevant. These ride awesome with the swift springs...Not harsh what so ever.
Old 02-06-2013, 04:34 PM   #2435
tehknikhal
Member#: 227548
2009 09 WRX Sedan
Glad you found a solution. good luck
Old 02-06-2013, 07:19 PM   #2436
DurtyB
Member#: 292699
2011 WRX Sedan DGM
Stg1+ SF
No solution found . Still making the noise after greasing them up
Old 02-07-2013, 06:31 PM   #2437
DDScooby
Member Sales Rating: (13)
Member#: 161876
02 Impreza WRX
Check the center nut on the top-hat (strut mounts) get an allen (hex wrench) in the damper very center to make sure it doesn't spin with the nut and use a box end wrench 14mm iirc to check tightness. Also you have to take the load off the coil when doing this. Put the front end on jack stands and use the floor jack under the A-arm(front control arm) to get either side up to ride height. Hope that helps
DDScooby is offline   Reply With Quote
Old 02-08-2013, 12:29 AM   #2438
Nick-subiefan
Member#: 164500
2004 WRX
I have 2 questions about the BC Racing BR Series Coilovers with Swift springs on a 04 WRX:
1. What is the minimum drop?
I hear i'ts very close to stock WRX height. Is that true?
2. What is the max. neg. front camber you can achieve with the included plates?
Other info if it helps: I'm running on 225/45-ZR17 wrapped on 17x8 ET48 wheels.
Nick-subiefan is offline   Reply With Quote
Old 02-08-2013, 07:54 AM   #2439
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
minimum drop would be almost stock height.
-3 is max camber
__________________
Open Daily
Best Deals on
Old 02-14-2013, 08:35 AM   #2440
new_to_drift
Member Sales Rating: (1)
Member#: 316071
15 WRX Limited
Just picked up a used set and I'm wondering why kind of grease people are using to prevent squeaking and where it's going.
new_to_drift is offline   Reply With Quote
Old 02-25-2013, 01:06 PM   #2441
-AspenSTi-
Member#: 164323
2005 STi
To anyone that went with a softer spring, how are you liking it? I just ordered a set with 7k/5k and am hoping its just right for the DD.
-AspenSTi- is offline   Reply With Quote
Old 02-25-2013, 02:23 PM   #2442
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
7/5k will be comfy for DD
__________________
Open Daily
Best Deals on
Old 02-27-2013, 04:04 PM   #2443
-AspenSTi-
Member#: 164323
2005 STi
How about 6/4? Too soft? Or would I even notice?
Old 02-27-2013, 04:07 PM   #2444
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
its a bit too soft. they can do it, but they do not like to
__________________
Open Daily
Best Deals on
Old 03-07-2013, 01:42 PM   #2445
2010SubieFoz
Member#: 342130
2010 Forester
Camelia Red Pearl
Will these coil overs work with the power flex rear camber kit on a 2010 Subaru Forester? I figured the control arms on the rear would be how I would need to adjust camber in the rear.
2010SubieFoz is offline   Reply With Quote
Old 03-12-2013, 06:36 PM   #2446
Zwilks14
Member Sales Rating: (4)
Member#: 336694
2005 Wrx wagon
Gray
If I order the bc br's with the swift springs , how long will it take for them to ship?
Zwilks14 is offline   Reply With Quote
Old 03-12-2013, 06:37 PM   #2447
vision.dynamix
Member Sales Rating: (53)
Member#: 139955
2015 Subaru STI
Stage e
I dont see why they wouldnt.
Old 03-13-2013, 08:58 PM   #2448
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Just ordered some with the swifts and 8k front and rear with the extenders. I hope they get here fast I need em!!
Old 03-14-2013, 07:52 AM   #2449
IMPORTIMAGE
Member#: 79304
CALL 941-257-9618
we are rushing em! just waiting for the springs to get to bc and ships right out
__________________
Open Daily
Best Deals on
Old 03-14-2013, 02:09 PM   #2450
Zwilks14
Member#: 336694
2005 Wrx wagon
Gray
Thanks , u guys have been great so far
Megan Racing Vs BC Racing Coilovers silver_surfer_rex Brakes, Steering & Suspension 59 04-11-2011 10:12 AM
BC Racing Coilovers now sold at GNV. High quality, cost-effective coilovers! ON SALE GNV Motorsports Suspension/Brakes/Handling 20 08-30-2006 12:21 PM
