![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#1 |
Member#: 61036
While replacing my front pads I attepted to find the rattle that has been annoying me for months. Well I found where its comming from but not what is causing it. It is definately comming from the strut, because when I tapped on it with a rubber mallet it would rattle. Would a blown strut cause that?
#2 |
Member#: 146626
NWIC
Vehicle:2001 Impreza GC8 Panda on rails! |
I dunno if a blown strut would make rattling noise or not. Although I used to have a car with the front right strut blown (it doesn't take bumps too well after that) but it didn't make any rattle noise.
But either way, struts should NOT rattle internally if they are installed properly. If you're 100% sure that the rattle is coming from your perfectly installed strut you should probably get it replaced. (Excuse to get something fun to put on your car!) ![]() |
#3 |
Member#: 108557
NWIC
Vehicle:2003 PSM WRXWgn STG2 05 OBM LEGACY SDN |
Did you check to make sure the bolts attaching the strut to the chassis were tight? A blown strut generally is indicated by fluid leaking from the unit and the aforementioned issue with oscillation control when going over bumps. I would retorque all the bolts to factory spec and see if that helps.
#4 |
Member#: 294069
MWSOC
Vehicle:04 Impreza RS PSM |
the tophat on my rattling strut was defective, causing the strut top nut to not be physically able to tighten it down, the nut was at the end of the threads, couldnt tighten any more, yet there was wobble room for the tophat between there, that was the rattle. Used my old tophat, problem fixed. yay
#5 |
Thanks Sir Alex!
Moderator Member#: 88606
MWSOC
Vehicle:2011 GMC Sierra 1990 Miata |
Is there a reason for bumping a 4.5 year old thread other than telling everyone you fixed a problem?
Sounds like you put a newer strut mount on an older strut. This commonly causes noise issues and is the reason people stack washers or spacers under the strut mount when doing this type of combination of parts. |
| Thread Tools | |
| Display Modes | |
| Loose metal rattling by front driver side | gumby1976 | Brakes, Steering & Suspension | 5 | 08-04-2004 12:51 PM |
| Metallic rattle from rear drivers side?? | jroberts | Service & Maintenance | 4 | 07-28-2003 01:28 PM |
| Rattle from rear driver side wheel...how do i fix it? | CanadianWRB-WRX | Brakes, Steering & Suspension | 2 | 05-04-2002 12:07 PM |
| rattle from rear pasenger Strut!! | GregBolby | General Forum Archive | 6 | 01-15-2001 03:10 PM |
