Welcome to the North American Subaru Impreza Owners Club Monday May 25, 2015
Old 02-25-2013, 12:17 PM   #1
Quiksmith
Member#: 266230
2006 WRX STI
Default I Got a Dom Tune! APS SR56 Pump Speed Density 419WHP/405Wtq
Shop: Maxwell Power Services
Ambient Temp: 41 F
Elevation: 200 feet
Weather: Rain/Sleet
Car: 2006 STI
Tuner: Dominic
Dyno Info: Dynocom
Peak Horsepower at RPM: 419.6 whp @ 6100 RPM
Peak Torque at RPM: 402.5 ft*lbs @ 5300 RPM (Seems really late but it actually is like 4500-4800 rpm Max Torque, It flat lines there and holds to 5300rpm)
Peak Boost: 20.8 PSI
Engine by S+R Performance:
Stage 2+ Shortblock
CP Pistons
Manley I-Beam Turbo-Tuff Rods
OEM bearings
OEM Nitrided Crank
Fully Closed Deck
Heads done by: Custom Import Heads
BC 272/272 Stage 2 cams
BC Springs and retainers
Supertech Inconnel +1 Exhaust Valves
Supertech SS +1 Intake Valves
OEM head Gasket
ARP HeadStuds @98 ft*lbs
Other Power Mods:
APS SR56 Turbo
Perrin FMIC
Perrin Inlet
Perrin Short Ram Intake w/ Foam Filter
Perrin BOV Full Recirc
Agency Power UEL Headers (Black Velvet Ceramic Coating)
Grimmspeed uppipe
Tial 38mm External Wastegate
Agency Power Downpipe
HKS Hi-Power Cat back
Grimmspeed Phenolic Spacers
Throttle Body Coolant Line Delete
Grimmspeed Light Weight Pulley
Mounts:
Group N Motor Mounts
Group N trans Mount
Perrin Pitch Stop Mount
Transmission:
Stock 6 Speed
Motul Gear 300 75w90
Competition Clutch Stage 3.5 Segmented Cerametallic
Motul 90 PA Rear Diff Fluid
OEM Flywheel
Fueling:
92 Pump
1000cc ID Injectors
Maxwell Power/T1 Motorsports Top Feed Conversion Kit
Aeromotive FPR
Braided 6AN Fuel Lines
Walbro 255
Tuning:
Cobb AccessPort Speed Density Hybrid Tuning (Still uses MAF at low boost for drivability)
IAT relocated to I/C Pipe right before throttle body
Boost Control:
3-Port EBCS Hybrid with Perrin MBC (Works Great!!)
Oiling:
Maxwell Power modded OEM 10mm Pump (+1 Shim)
Motul 5w-40 Synthetic
Saikou Mitchi Dual Catch Cans
Battery:
Odyssey Red Dry Cell battery
Suspension:
Cusco Coilovers 2 Zero-E
Whiteline 22mm Rear Sway
Perrin Heavy Duty Rear Endlinks
APR Front Tower Strut Brace
Other Mods:
KSTech Hood Scoop Block off Plate
Perrin Brake Stiffy
Samco Hose Kit
Koyo Full Aluminum Race Radiator
Perrin Turbo Blanket
Gauges:
60mm Defi Boost
60mm Defi Oil Temp
60mm Defi EGT
52mm Prosport AFR
52mm Prosport Oil Pressure
Defi V1 Link
Quiksmith is offline   Reply With Quote
Old 02-25-2013, 02:34 PM   #2
bebesito21
Member#: 176128
5862 ...baby boosted
weird that you went to Dom for the tune and not the motor? Kinda hard to beat their track record. you gonna turn up the boost and test that "closed deck?"
bebesito21 is offline   Reply With Quote
Old 02-25-2013, 04:06 PM   #3
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 430/413 JJtuned
In some ways very similar to my hta68 build tuned by Dom. My tq is similar but comes on much sooner (4200rpm), while I'd love that 28 extra hp up top. I have avcs exhaust cams only and stock valves, which might help explain the low end vs. top end differences.
Well, that and the turbo.
Old 02-25-2013, 04:40 PM   #4
Quiksmith
Member#: 266230
2006 WRX STI
To be totally honest I didnt know MPS even built short blocks when I was in the market for them. If I could go back in time I would most definetely be a MPS motor owner. I fell on a killer deal for this S+R shortblock and couldn't pass it up at the time.
Eventually I will get a meth kit set up (cause E85 is rare in my area) and see what this thing can do. Although not anywhere near S+R's claimed 800 horsepower lol.
Ya this turbo is pretty laggy and Dom even said he wasnt a huge fan but that turbo was on my previous build. You mean intake avcs? Thats all I have as well. I do think the valves help a bit. I hope you were as satisfied by MPS's work as I was. Truly a great experience with excellent results.
Old 02-25-2013, 04:53 PM   #5
Dave D.
Member#: 130990
06 Red Ltd.Wagon
Originally Posted by Quiksmith View Post
I hope you were as satisfied by MPS's work as I was. Truly a great experience with excwllent results.
Absoutely. Went with an MPS-built block from the start and have been well-taken care of.
Old 03-21-2013, 01:42 PM   #6
Quiksmith
Member#: 266230
2006 WRX STI
Just replaced my cuscos coils (one was bent >< ) with BC ERs, got my first autox of the year this weekend!
Old 03-21-2013, 06:14 PM   #7
Uncle_kovac
Member#: 349488
wow looks like a really good power band!!
Uncle_kovac is offline   Reply With Quote
Old 03-22-2013, 07:03 AM   #8
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Yes, more octane and boost and this thing would open up quite bit.
May I suggest a better flowing air filter and, if in the budget, a better set of headers.
Old 03-22-2013, 09:50 AM   #9
insaneimpreza
Member#: 83291
1998 RSTi
Ej257 GTX3576r
Not the most power out there but an extremely nice powerband, that must be a lot of fun to drive
insaneimpreza is offline   Reply With Quote
Old 03-22-2013, 02:01 PM   #10
Quiksmith
Member#: 266230
2006 WRX STI
Thanks shes a blast!
My goals were 400+ whp while maintaining some reliability on pump gas. E85 will be next once I feel the need for more haha.
As far as air filter I doubt my foam filter is limiting at these power levels, also after reading alot on these headers I discovered they perform excellent for thier price. I mean for a non-rotated, non-twin scoll, and unequal length setup these headers are great. Good gains up top while maintaining decent spool. You cant ask for more than that at $500 bucks. They were even recommended by my tuner .
Thanks, she pulls hard all the way to redline. So much area under the curve after 4300 Rpms, I've never driven a car that felt like this, It's truly a pleasure to drive .
Old 04-29-2013, 10:57 PM   #11
Maxwell Power
Member#: 190729
The AP headers are very nice and flow very well. It's possible you are mistaking them for another brand. The primaries are nice and large, the merge collector is beautiful, the welds are great, the finish is gorgeous... I don't think there is anything else that AP makes that I like. Coincidentally, I don't think AP really makes these. Pretty sure they're made in china. Regardless, they fit well, I've never had a set crack in 5 years and I have taken them as high as 600whp while being under 30psi. I sell a lot of them and have great success. My only complaint is the gasket they supply with them for the header to up pipe SUCKS. Since the collector has a larger ID than the stock one, the stock gasket works O.K. but hangs into the pipe. We're having custom gaskets made that hopefully won't fail and will still fit the headers perfectly.
The late peak torque is a testament to the conservative timing. If the timing was aggressive, the peak torque would come in right after peak boost. Instead, the safe timing values at peak boost give the car a flatter section of torque and knock down the peak number.
Old 04-30-2013, 06:12 AM   #12
A-man07
Member#: 271525
07 STi
Hi Dom thanks for replying. Wouldn't the large diameter primaries be slowing the exhaust gas flow and unecessarily slowing spool without adding significant top end flow? For example the Killer B header uses stock diameter (1.5") primaries and as far as I can tell doesn't seem to be top end limited.
Old 04-30-2013, 03:11 PM   #13
Maxwell Power
Member#: 190729
I picked up 40whp and spooled 250rpm faster when running 21psi on a GT35R from the factory header with Grimmspeed Crosspipe to this header. Most of my customers see similar results. That would tell me, no, it isn't hurting spool and yes, it is improving flow.
Old 04-30-2013, 03:15 PM   #14
Maxwell Power
Member#: 190729
I just measured the ID of the primaries: 1.50 at the flange, but the pipe is really about 1.52" ID with an OD of about 1.7
Old 04-30-2013, 03:23 PM   #15
medamullet
Member#: 99442
2006 SGM STI
I'm on CORN YO!
My experience is the same. The only time smaller runners help is for smaller turbos. There is a point when the runners become the choking hazard of the motor.
medamullet is online now   Reply With Quote
Old 04-30-2013, 06:52 PM   #16
A-man07
Member#: 271525
07 STi
Okay, so really same as exhaust port diameter. Thanks for the data.
Old 05-01-2013, 01:34 AM   #17
Tyrial
Member#: 284392
2011 STI Limited
Plasma Blue Pearl
Nice and flat, very nice area under the curve
You'll be hearing from me a lot this summer Dom
Tyrial is offline   Reply With Quote
Old 05-01-2013, 09:07 AM   #18
Slimsti
Member#: 155696
2007 BLK STI Dom3XTR
415/405 Precision Tuning
Looks really good. Nice solid power delivery and a nice safe boost level. Im liking what i see from those aps turbo's. Our numbers are almost identical so i know exactly how it must feel on street. Its taking me 27psi and meth to get there though so im maxed out basically, you have TONS of room left to make more power. This will easily make 500 with a more aggressive tune. Conservative is the way to go though.
Slimsti is online now   Reply With Quote
Old 05-01-2013, 09:11 PM   #19
Maxwell Power
Member#: 190729
I'm not a fan of APS turbos at all. Other turbos on the market perform better. I'm a firm believer in the Blouch turbos and going rotated with garrett turbos.
Old 05-01-2013, 09:21 PM   #20
Quiksmith
Member#: 266230
2006 WRX STI
Agreed, that is one thing (of many) I regret not changing before my build. Im more than happy with the power but really want faster spool.
Dom are you not a fan of ATP/garrett stock location turbos? Or just prefer blouch in the stock location?
Old 05-02-2013, 09:28 AM   #21
Slimsti
Member#: 155696
I know alot of people love there blouch turbo's but i fully regret mine. Im just not happy with it at all. I like my og 7cm FP green better. Ill be going roatated soon cause im less than impressed. It just didnt do what i expected. Takes way to much to make power. Id be thrilled with over 400whp with 21psi. To each there own tough. Everyone has there opinions and favorites. Nice numbers nonetheless.
Old 05-02-2013, 10:56 AM   #22
Maxwell Power
Member#: 190729
Which one do you have and what were you expecting?
Old 05-02-2013, 10:58 AM   #23
Maxwell Power
Member#: 190729
No I'm not. I used to push them, but the fitment sucks and the performance is substandard. The oem location has so many shortcomings. Over 400whp I tell everyone to just go rotated and get it over with.
Old 05-03-2013, 09:18 AM   #24
west_minist
Member#: 53451
2000 JDM Impreza SRX
w/ AVCS Silver
I guess Slimsti is using the Dom 3.0XT-R based on this profile. Thats interesting.
west_minist is offline   Reply With Quote
Old 05-03-2013, 11:37 AM   #25
Maxwell Power
Member#: 190729
We talked in pm. His results are not typical and I wouldn't be happy either. I suspect either tuning issue. Boost leak or other restriction.
