Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 09-22-2008, 09:00 PM   #1
jetski247
Member#: 188171
04 sti baby
wrb
Lightbulb how to fix rear strut rattle?
how do i tighten the rear struts?
i removed the seat, removed the three bolt top and tried to tighten the nut and it was super tight already.
do i loosen the nut, adjust the allen screw first???? its bugging the heck out of me.
jetski247 is offline   Reply With Quote
Old 02-24-2013, 06:08 PM   #2
mrchyes
Member#: 294069
98 Forester
Green
the tophat on my rattling strut was defective, causing the strut top nut to not be physically able to tighten it down, the nut was at the end of the threads, couldnt tighten any more, yet there was wobble room for the tophat between there, that was the rattle. Used my old tophat, problem fixed. yay
mrchyes is offline   Reply With Quote
Old 02-25-2013, 06:20 PM   #3
thegreg
Member#: 105429
2004 WRX STi
If they are stock STi struts, you will need to remove & disassemble the the strut completely. There is a nut on the bottom of the strut, once you've got the spring removed, undo the nut & remove the ''cartridge''. You will need to lubricate the shaft with some type of heavy grease..I used axle bearing grease. Search on here, it is a common issue with STi struts & the inverted design.
thegreg is offline   Reply With Quote
how to fix rear camber issues? skate enjoi Brakes, Steering & Suspension 15 06-30-2008 10:00 AM
How to fix rattles (interior noises) Chrisnonstop General Community 22 12-31-2007 10:41 AM
how to fix rattling catalyst rex-machine Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 10-26-2004 06:37 PM
How to install rear strut bar for sedan? coolray Brakes, Steering & Suspension 11 12-22-2003 09:25 AM
Did Anybody figure out how to fix that rattling from WOT on a Cobb CAI AustinSTi Normally Aspirated Powertrain 8 02-07-2002 11:07 AM
