Old 02-25-2013, 08:48 PM   #1
jarrodblake
Member#: 314134
02 wrx
midnight black
Default Thoughts before I replace my ball joints and tie rod ends 02 wrx
Before I replace my ball joints and tie rod ends is there and anything I should look at that could be making a clunking sound? I have a 02 WRX with 134k on it and have had a clunking sound for about two months coming from the passenger side. I had thought it was my sway bar bushing as when trying to find where the noise was coming from, I noticed that there was a big chunk of the bushing missing. Today I replaced the sway bar bushings with polyurethane bushings. After a quick test drive I was still getting a clunking sound from the passenger side. I put it back up in the air and tried to move things around I cant find the noise. I only here it when I'm driving and hit a dip or uneven pavement on the road and coming out of my driveway sometimes. So what other things should I look at before I replace my ball joints and tie rod ends?
Also are there and manufactures I should stay away from? I plan on just buying from autozone But have been looking on ebay and amazon also.
jarrodblake is offline   Reply With Quote
Old 02-25-2013, 08:54 PM   #2
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Do you have all the right tools to remove ball joint from the knuckle? If I were you, I will try to find OEM ball joint from FS section. That's where I found 2 new ball joints for $25 shipped. I'd recommend either OEM or Moog for tie-rod.
I am having the same issue, but it wasn't the ball joint or tie rod end. Next thing I'm going to replace is axle and putting in a spacer between bar and end link.
Old 02-25-2013, 09:31 PM   #3
jarrodblake
Member#: 314134
02 wrx
midnight black
Yes I have all the tools. I had forgotten about moog I used them on a few other car, I may use them.
This is what I'm trying to avoid, not that they couldn't use to be replaced, but I don't want to spend the money on something that wont fix the problem. As for the axle mine look new and the boots are in great condition, However I will see if I can get them to make noise when I look at the car tomorrow.
Old 02-25-2013, 11:39 PM   #4
darkops
Member#: 82567
2013 WRX 4dr
ISM
I had the same problem on my 04. Turned out the front sway bar links were a little loose. Make sure if you tighten them that the car is on the ground.
darkops is offline   Reply With Quote
Old 02-25-2013, 11:44 PM   #5
wobbletop
Member#: 11652
'11 STI 5dr Red
'70 Porsche 914/6
Check the axle boot on that side. Typically the heat from the turbo/down pipe cooks and dries out the rubber boot. Grease gets spun out and axle dies soon after.
wobbletop is offline   Reply With Quote
Old 02-26-2013, 07:37 AM   #6
Aaron'z 2.5RS
Member#: 1026
'00 RS/WRX Stg5
'98 RS Stock
Start cheapest first.. swaybar endlinks..
Ball joints dont usually clunk, unless they are about to fall out of the cup, they typically give a "pop"... a much sharper noise than a clunk
Old 02-26-2013, 11:19 AM   #7
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
You can test sway bar end links by removing one side.
Instead of getting OEM Replacement ball joints and tie rod ends, consider the Whiteline kit.
Old 02-26-2013, 12:13 PM   #8
jdblock
Member#: 235211
2004 STi
Check that the axle nut is tight.
jdblock is offline   Reply With Quote
Old 04-22-2013, 04:47 PM   #9
jarrodblake
Member#: 314134
02 wrx
midnight black
just now updating this thread. I ended up replacing ball joint, but like you all said it was the endlinks.
