Old 02-25-2013, 09:36 PM   #26
SubieLuvin
Member#: 248202
2013 WRX Sedan
Edited for innaccuracy
SubieLuvin is offline   Reply With Quote
Old 02-25-2013, 09:44 PM   #27
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Originally Posted by SubieLuvin View Post
If you switch to catless you WILL overboost. Overboosting from time to time you might be okay, or you might blow your **** up. Retune. Why are you switching to catless anyways?
This is not correct.
Psychoreo is online now   Reply With Quote
Old 02-25-2013, 10:24 PM   #28
SubieLuvin
Member#: 248202
2013 WRX Sedan
Care to elaborate ? Not trying to be a dick, genuinely curious as I've always been under this impression. Ie cobbs warnings of running catless on their cat based stage two maps.
Old 02-26-2013, 02:14 AM   #29
daseca07
Member#: 277630
2007 WRX TR
i recently contacted my tuner (turboxs) about this and their lead tuner said a retune is not needed switching to a catless downpipe if a protune was already done with my catted downpipe. just the check engine light fix when emissions time comes. i never did the swap anyways.
daseca07 is offline   Reply With Quote
Old 02-26-2013, 09:20 AM   #30
Psychoreo
Member#: 79643
2015 WRX STI
You said that it WILL overboost. That part is not correct. It MAY overboost would be more accurate.
My car before I swapped it was on a COBB OTS stage 2 map which was unchanged through two different catted down pipes (one bell mouth, one divorced) and one crappy ebay special bell mouth catless down pipe.
Not once did it overboost or throw a code.
So saying that it will do something isn't accurate. Giving them the warning that it could is.
Old 02-26-2013, 09:23 AM   #31
SubieLuvin
Member#: 248202
2013 WRX Sedan
Okay good to know I only went half retard...never go full retard
