Welcome to the North American Subaru Impreza Owners Club Saturday May 23, 2015
Old 02-25-2013, 07:12 PM   #1
happyhands
Member#: 347741
2005 WRX WAGON
SILVER
Default avc type r boost controller
New to the subaru. I have a Avc type r boost controller installed and im trying to learn it. Has any body has exsperince with this? I bought it mainly to have low and hight boost. i dont want to give it hell all the time when i go flat out. I bought the car with it tuned already and a/f's are 10.0-10.5 under boost. Just to give some info. on the car. it has invidia down pipe with magnaflow exhaust, up pipe, cobb short ram. Runs around 19psi on stock turbo. I dont want to go any higher in boost, just want to run off of the wastgate when driving around town and be able to run high boost when i get to the track. My issue is that i can get it to run low boost. 1-3rd it runs around 14psi. Then 4th it stays around 19psi. i switch from high boost to low boost and it does the same. does not change my max boost? Any ideas? Thanks for the help.....
happyhands is offline   Reply With Quote
Old 02-25-2013, 10:40 PM   #2
rudymcskoody
Member#: 257618
2006 wrx
aspen white
.........wut
rudymcskoody is offline   Reply With Quote
Old 02-25-2013, 10:54 PM   #3
Navendra94
Member#: 327495
2012 Impreza WRX 5DR
Plasma Blue
"Hello, I am new to owning a Subaru. I have an AVC Type R Boost Controller installed and I'm trying to learn about it. Does any body have experience with this? I bought it mainly to have the option to switch from low and high boost. I dont want to give it hell all the time, only when I go flat out. I bought the car with it tuned already and the A/F's are 10.0-10.5 under boost. Just to give some more information on the car, it has an Invidia downpipe with a Magnaflow CatBack Exhaust, UpPipe, and Cobb Short Ram Intake. The car runs around 19psi on a stock turbo. I don't want to go any higher in boost, I just want to run off of the wastgate when driving around town and to be able to run high boost when I get to the track. My issue is that I can get it to run low boost; 1st-3rd gear, it runs around 14psi and then in 4th it stays around 19psi. I switch from high boost to low boost and it does the same. Does the boost controller not change my max boost? Any ideas? Thanks for the help....."
Edited his post to make it a bit easier to understand...
I tried, but I can barely understand lol.
Navendra94 is offline   Reply With Quote
Old 02-26-2013, 08:36 AM   #4
happyhands
Member#: 347741
2005 WRX WAGON
SILVER
I cant get the car to stop going to 19psi with i go into 4th full throttle. I set the controller to 14.5psi. Im thinking the reason for this is because of the tune that cme with the car. Im using avc typr r boost controller.
Old 02-26-2013, 09:04 AM   #5
Loyale93
Newbie Moderator
Member#: 91347
'13 XV Crosstrek,
1050 Triumph Speed Triple
You're using avc typr r boost controller. We got it.
Attempting to re-read your post I've gleaned the following information.
Your car came with a tune already on it along with a bunch of mods.
You don't know what the tune is.
You added an AVC Type R Boost Controller to give you the option of running high/low boost given the situation.
You haven't retuned....
If that's all correct, I think the answer is clear. Go get it re-tuned.
Loyale93 is online now   Reply With Quote
Old 02-26-2013, 09:10 AM   #6
jayman4312
Member#: 228784
2004 wrx
black, stage 2+
use your right foot for boost control. If you don't want to hit 19psi in 4th, then dont floor it in 4th.
jayman4312 is offline   Reply With Quote
Old 02-26-2013, 09:12 AM   #7
rudymcskoody
Member#: 257618
2006 wrx
aspen white
You need a low boost map to switch to. You can not just simply turn down the boost in these cars. You need a low boost tune, a high boost tune, and an access port to switch between them.
Old 02-26-2013, 09:57 AM   #8
tommyson01
Member#: 154579
2005 OBXT
Old man blue
As stated, OP talk to a professional (before you blow up your engine).
Also, if you fill out this (with you general location) we'll be able to point you in the direction of a good professional to talk to.
http://forums.nasioc.com/forums/usercp.php
tommyson01 is offline   Reply With Quote
Old 02-26-2013, 10:58 AM   #9
happyhands
Member#: 347741
2005 WRX WAGON
SILVER
I know every one hates newbie question, but thanks for the info. Knowing that i need a low boost map is the answer i was looking for. Im waiting for the tuner i use to free up so i can make an appointment. Again thanks for the help..
Old 02-26-2013, 11:21 AM   #10
rudymcskoody
Member#: 257618
2006 wrx
aspen white
Its no problem. Next time just make sure you write in a way we can all understand what you are trying to say.
Old 02-26-2013, 11:53 AM   #11
happyhands
Member#: 347741
2005 WRX WAGON
SILVER
Sory about that , i had a Red Bull moment....
Old 02-26-2013, 11:54 AM   #12
happyhands
Member#: 347741
2005 WRX WAGON
SILVER
rudymcskoody i see you live in TX. Have you been to the Texas Mile?
Old 02-26-2013, 12:15 PM   #13
rudymcskoody
Member#: 257618
2006 wrx
aspen white
No I haven't. I'd like to go watchvone year but I never seem to make it out. Are you in DFW?
Old 03-06-2013, 06:56 PM   #14
happyhands
Member#: 347741
2005 WRX WAGON
SILVER
DFW? I live in nc. I ran my focus at Maxton. Mile with ecta-lsr. The ecta moved to a place in Ohio. I havnt went lsr in about two years. I want to take my wagon.
Old 03-06-2013, 09:26 PM   #15
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
did someone say AVC-R? welcome to 2001
but seriously, its your duty settings that are shooting you up to 19psi.
The lowest setting should be wastegate spring pressure.
check this out if you insist to use it. It can still be an effective tool if you or your tuner doesn't mind tuning it independently of the ecu, but obviously there are more tuning options now days.
http://www.turbomr2.com/MR2/HowTo/AP...%20AVCR-03.htm
