02-20-2013, 08:45 PM | #7001 |
Member#: 347730
Vehicle:2004 WRX Silver |
04 WRX WAGON
fp 68 hta agency power fuel rails Walbro 400 ID 1000cc injectors E85 102% duty cycle at stock fuel pressure last dynoed at 24psi boost 391wph 380tq
02-20-2013, 10:46 PM | #7002 |
Member#: 149262
MWSOC
Vehicle:03WR rallycarFXTleg PrimerGrey |
02-20-2013, 11:57 PM | #7003 |
Member#: 56203
Tri-State
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
I bet its on stock wiring
02-21-2013, 12:01 AM | #7004 | |
Member#: 255114
Tri-State
Vehicle:2015 STi Limited CBS |
02-21-2013, 01:28 AM | #7005 |
Member#: 193757
MWSOC
Vehicle:2006 XTI Limited OBP, Junior tuned 573WHP |
02-21-2013, 09:58 PM | #7006 |
Member#: 347730
02-24-2013, 06:53 PM | #7007 |
Member#: 348148
Those dynographs are a very nice reference for setup standards for the power you want to have
02-24-2013, 07:13 PM | #7008 |
Member#: 307177
MWSOC
Vehicle:2k4 WRX/WRB |
Someone school me please. I'm moving to Cali this Friday and wanna tune for e85 but completely new to the subject.
I'm running DW 850cc injectors and a Walbro 255 fuel pump. Will these support e85 or no? I'm guessing I'll need aftermarket fuel rails? Anything else to replace/install when going e85? All help is appreciated. |
02-24-2013, 07:20 PM | #7009 |
Member#: 159243
Tri-State
Vehicle:5/01 bugeye Hakt Ecu is back! |
is there e85 where your moving?
02-24-2013, 07:22 PM | #7010 |
Member#: 307177
MWSOC
02-24-2013, 07:28 PM | #7011 |
Member#: 178426
Vehicle:2010 S4 Gray |
02-24-2013, 08:06 PM | #7012 |
Member#: 149262
MWSOC
2.5 what turbo are you trying to feed? Stock fuel rails should be fine.
02-24-2013, 08:06 PM | #7013 |
Member#: 307177
MWSOC
02-24-2013, 08:09 PM | #7014 |
Member#: 149262
MWSOC
You should be fine.
02-24-2013, 08:14 PM | #7015 |
Member#: 307177
MWSOC
02-24-2013, 08:32 PM | #7016 |
Member#: 307177
MWSOC
Any clue whatsoever what kind of numbers I'll put down with the following mods and e85?
- FP 18g P/P'd - APS Turbo-back - APS Intake - Godspeed catless DP - Invidia UP - JDM V8 STi TMIC - 3 port ebcs - DW 850 injectors - Walbro 255 Soon to go EWG |
02-24-2013, 08:37 PM | #7017 |
Member#: 149262
MWSOC
You should be able to get over 300 whp easy. I am running an 18g, 38mm ewg, ID 1000cc, process west tmic and getting 330 on a conservative tune.
02-24-2013, 09:07 PM | #7018 |
Member#: 307177
MWSOC
02-25-2013, 10:31 AM | #7019 |
Member#: 336241
MWSOC
Vehicle:08 Sti OPB |
Guess I should post this as well,
08 Sti Built Bottom End All bolt on's Tgv Deletes with 3m Phenolic spacers Currently on a vf48(will be getting a td06 sl2 20g put on in a few weeks 1000cc ID Injectors 300lph Detchworks Fuel pump IDC 49% with a elevation of 6k+ feet(Colorado Springs) Havent had a baseline done yet as I a street tuned but thinking im at 300awhp. |
02-26-2013, 12:32 PM | #7020 |
Member#: 330971
Vehicle:2005 STi CGM |
I'm sure this has already been answered in this thread, but forgive me for not wanting to read thru all 281 pages. For the guys running 100% E85 on built motors, what is the typical life expentacy of these motors? I'm strongly considering going to 100% E85 when I build my motor, but its going to be my DD for awhile and I really need it to last me around 50k miles otherwise I'll probably have to stick with just pump gas.
02-26-2013, 12:38 PM | #7021 | |
Member#: 52314
South East
Vehicle:... 02 and 04 WRXs! 2020 G70 3.3T RWD |
02-26-2013, 12:42 PM | #7022 |
Member#: 159243
Tri-State
I don't think that a properly built ethanol motor has any less life expectancy than a gas engine.
If its tuned and maintained optimally, I'd bet the e85 engine which burns cooler and cleaner would actually last longer. |
02-26-2013, 12:43 PM | #7023 | |
Member#: 330971
Edit: thanks for the response too maxpowr |
02-26-2013, 12:50 PM | #7024 |
Member#: 52314
South East
ninja!
02-26-2013, 02:29 PM | #7025 | |
Member#: 172698
MWSOC
Vehicle:11 STi BW 8374 E85 02 v8 Spec C E85 |
A lot of the local Subarus have been on E85 for around a year since people started to switch around here. I've got 12,000 miles on E85 personally. There are people that have been running E85 for much longer than this as well. A few of us have been doing Blackstone oil analysis' and the results seem to indicate that oil breaks down just slightly faster when running E85. Most of us run Rotella T6 at 2000 - 3000 mile intervals depending on usage. |
Similar Threads | ||||
Motion Lab Tuned: Juanmedina's 2007 WRX E85 ARMY | Motion Lab Tuning | Proven Power Bragging | 125 | 04-12-2010 02:57 AM |
jid2 Track Car - e85 ARMY | jid2 | Member's Car Gallery | 38 | 01-22-2010 10:44 PM |
The Honduran army is the bravest in the world... | wrxcelent | Off-Topic | 36 | 07-07-2009 08:21 AM |
Spacific E85 Tuning thread Here ? | discopotato03 | Engine Management & Tuning | 1 | 09-09-2008 11:01 AM |
Did anyone hear the one about the Italian army and the IRAQI satiation? | Asinine | Off-Topic | 3 | 09-20-2005 07:06 PM |
