Vancouver Impreza Club
Old 02-26-2013, 04:07 PM   #1
shum_87
Member#: 129898
2001 Impreza
Default PSA: Subaru Blue Oil Filters recall
shum_87 is offline   Reply With Quote
Old 02-26-2013, 04:38 PM   #2
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
I use WIX filters, but have always heard good things about the OEM filters, now I learn that they are made by Fram?
Why do OEM filters get such good reviews compared to Fram's terrible reputation?
brett192 is offline   Reply With Quote
Old 02-26-2013, 04:44 PM   #3
FunkMasta
Member#: 66985
2001 2.5RS sold
2012 2.0 Hatch
the blue ones never did brett, it was the black jdm filters that were good.
FunkMasta is offline   Reply With Quote
Old 02-26-2013, 04:50 PM   #4
brett192
Member#: 274252
2002 WRX Sedan PSM
VF39, EWG & 6 speed
Ohh ok. You can see how much I pay attention..
Old 02-26-2013, 06:48 PM   #5
ShiftGear
Member#: 130493
1999 v5 STi
So basically i've used OEM filters since new and now they are actually fram filters?
ShiftGear is offline   Reply With Quote
Old 02-26-2013, 06:49 PM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
You never knew? Haha
Old 02-26-2013, 07:10 PM   #7
thescreensavers
Member#: 333820
2013 WRX Limited
thescreensavers is offline   Reply With Quote
Old 02-26-2013, 07:17 PM   #8
jaydow11
Member#: 138952
2011 STI Hatch
Pearl White
After doing extensive research, I used the OEM Mazda oil filter in my last oil change... Same as the old (good) Black filters but just a tad taller....
jaydow11 is offline   Reply With Quote
Old 02-26-2013, 07:50 PM   #9
DIGGYGV8
Member#: 313558
2011 STi Sedan
I believe it even says honeywell on the blue ones, which is Fram basically.
I miss my toyoroki's from my Honda days.
DIGGYGV8 is offline   Reply With Quote
Old 02-26-2013, 07:57 PM   #10
ShiftGear
Member#: 130493
1999 v5 STi
Subaru I AM dissapoint
Old 02-26-2013, 08:12 PM   #11
DIGGYGV8
Member#: 313558
2011 STi Sedan
According to some insider sources: both have confirmed any blue honeywell (fram) from Canada recently wouldn't hve been a problem. This is most likely affecting US market. At least Subaru Canada's system doesn't show any recalls.
FWIW: fram is okay with your everyday car, as long as you change it up often enough. It's still filters. Just terrible if you pay stealerships pricing on it.
Old 02-26-2013, 09:55 PM   #12
subaru-r6
Member#: 304173
2005 imp wrx sti
wrb
went to don dockster subaru, replaced 3 filters that had the bad build dates no questions asked
subaru-r6 is offline   Reply With Quote
Old 02-26-2013, 10:14 PM   #13
ShiftGear
Member#: 130493
1999 v5 STi
Any info on Bosch filters?
Old 02-26-2013, 11:18 PM   #14
wookieda
Member#: 326265
1996 GF8 WRX STI
oh **** i bought like 6 of these from an us dealership.. will match the dates up.. i wonder if canadian dealership will exchange these for me..
wookieda is offline   Reply With Quote
Old 02-26-2013, 11:29 PM   #15
clsmooth
Member#: 86394
2000 RS Coupe
2006 Forester L.L. Bean
You have a part number/photos by chance?
clsmooth is offline   Reply With Quote
Old 02-27-2013, 01:04 AM   #16
notjustforshow
Member#: 143277
05 STI PPP OBP
1098, Z1000
^ was in an alcoolaid thread: Mazda filter N3R1 14 302
notjustforshow is offline   Reply With Quote
Old 02-27-2013, 01:33 AM   #17
DIGGYGV8
Member#: 313558
2011 STi Sedan
interesting, these were originally from DD?
most likely where you got it from will do it...
Old 02-27-2013, 01:41 AM   #18
SubbyPimp
Member#: 79952
1999 RS/ 2004 WRX
WRB/ JBP
I have been using these for the past year on my gc and gd,
the 15208AA160 is same width as the 15208AA12A just a bit taller.
the 15208AA130 is same height as the 15208AA12A but a bit wider.
Both the have the correct bypass pressure and made at TK.
SubbyPimp is offline   Reply With Quote
Old 02-27-2013, 01:54 AM   #19
pope_face
Member#: 274373
1997 Impreza OBS
Blue - "Mishka"
Are the Mazda black ones OK for N/A cars, or turbo only? The bypass pressure, that is. If they're good for the N/A cars I might switch over to them.
pope_face is offline   Reply With Quote
Old 02-27-2013, 02:08 AM   #20
lucky.
Member#: 266144
2015 STi
btw, the 15208AA160 is for the brz fa engine and the 15208AA130 is for the 11MY forester fb engine.
Also, just curious how you found out they have the same bypass pressure?
lucky. is offline   Reply With Quote
Old 02-27-2013, 02:41 AM   #21
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
Most of you guys know how good these are. Actually Fram Heavy duty guard oil filter/mobil 1/wax/purolator are all very good filters as well. Check bypass pressure before mount on your car.
Mobil 1 oil filter is highly recommend by some suby members
*15208AA100*
Here is the alternative one for suby jdm tokyo roki
Mazda RX8 tokyo roki----n3r1 14 302
fujiwara_yingyu is offline   Reply With Quote
Old 02-27-2013, 03:42 AM   #22
chutoyy
Member#: 331372
2013 WRX
Ignore the purolator... I bought a bunch of those pre-maturely.
Mazda in middle, OEM from first oil change on right
chutoyy is offline   Reply With Quote
Old 02-27-2013, 03:43 AM   #23
SubbyPimp
Member#: 79952
1999 RS/ 2004 WRX
WRB/ JBP
I was told almost all subaru engines have similar bypass rating, only difference is between na and turbo is .4 psi which is negligible
na's are rated at 22.8 psi / 157 kPa
turbos at 23.2 psi / 160 kPa
i know the brz filter has an anti-drain back valve because of the way it's mounted but should be no problem to use.
If someone has there hands on a brz or 12+ FORESTER service manual, maybe they can confirm it...
Old 02-27-2013, 03:20 PM   #24
fujiwara_yingyu
Member#: 116351
1998 GC8/ 2014 GK5
2006 EVO IX MR
^the tokyo roki one has no problem with brz. Actually Hamp oil filter works better than tokyo roki on BRZ
Old 02-27-2013, 03:48 PM   #25
slowguy
Member#: 4326
What's wrong with the PureOnes? Was always under the impression they performed fine?
slowguy is offline   Reply With Quote
