Old 02-25-2013, 08:32 PM   #151
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I finally did this. Can't believe it took me almost a year since my motor rebuild either.
Old 02-25-2013, 08:36 PM   #152
BananaSammiches
Member#: 347739
2006 WRX wagon
You're right. I found it on Rockauto. Thanks!
BananaSammiches is offline   Reply With Quote
Old 02-25-2013, 08:38 PM   #153
spiralsmurf
Member#: 16085
2005 STi
Did you find the $90 one? I swear I saw the other one which hooks up to the canister in the rear of the car...but I looked now and can't find it.
spiralsmurf is offline   Reply With Quote
Old 02-25-2013, 11:27 PM   #154
Ed05WRX
Member#: 319401
05 WRX
WR BLue
Originally Posted by BananaSammiches View Post
Autozone doesn't carry them. I can't even order them in their system. It looks like I have to buy direct.
I got one here for 33 shipped
Ed05WRX is offline   Reply With Quote
Old 02-26-2013, 08:37 PM   #155
BananaSammiches
Member#: 347739
2006 WRX wagon
Yeah, it was the 90 dollar one. I'm pretty sure that's the part I need.
Old 02-26-2013, 08:37 PM   #156
BananaSammiches
Member#: 347739
2006 WRX wagon
Could you give me a link for that if you have it?
Old 02-26-2013, 09:19 PM   #157
spiralsmurf
Member#: 16085
2005 STi
I was actually thinking its this: http://natemichals.com/wp-content/up...707_190215.jpg
The canister vent valve, not the purge solenoid.
Old 03-14-2013, 11:42 AM   #158
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
I have noticed what I thought was an exhaust leak on cold start. After lifting the turbo and check both UP gaskets, and all exhaust manifold and DP gaskets, I haven't found any leaks. I'm beginning to wonder if the "leak" is simply gas fumes coming up into the cabin on cold start. I only really notice the smell on cold start when the HVAC (heat) is turned on.
The gas tank vent hose near the firewall has been extended, and it routes to underneath my car. It exits right near the rear mount for the *front* control arm on the drivers side. This is pretty much under the drivers seat almost, so I'm wondering if this has been my smell all along. My shop removed this solenoid in the first place because they claim it can leak, and that they remove it on all cars that see competition. (autocross for me)
I have the correct CEL's turned off of course, and I have the proper caps on my AMR inlet, and on my intake manifold. The "hard" fuel line under the intake manifold is simply left open, since nothing is connected to it on either end.
Thoughts? I thought I had an exhaust smell all along, but maybe not.
Acejam2k is offline   Reply With Quote
Old 03-14-2013, 12:14 PM   #159
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
Acejam2K - If you smell fuel fumes, like you would when filling up with gas, then chances are it is coming from that vent line. An easy test would be to extend the vent hose back to the gas tank area and see if the cold start smell still exists.
Stephen
IA Performance is offline   Reply With Quote
Old 03-14-2013, 12:22 PM   #160
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Stephen
Can the hose be disconnected at the gas tank? Doesn't the hose at the firewall originate from that charcoal canister?
Old 03-14-2013, 12:43 PM   #161
IA Performance
Member#: 25194
Dark Gray
I'm not certain. Keep in mind that you may always have this fuel smell since Subarus are not sealed as tight as a submarine. I'd prefer to see the solenoid installed and functioning since that would eliminate the smell. I'd remove it on a race track only car, not daily driver.
Stephen
Old 03-14-2013, 01:08 PM   #162
Acejam2k
Member#: 42645
2014 Audi S4
Brilliant Black
Stephen
Thanks IA for the help. If I were to pickup a new solenoid and install it - would that throw off my tune? I wasn't sure if the fumes being sucked into the inlet would be considered "unmetered". For what it's worth though, the smell doesn't entirely smell like fresh gas at a gas station - it smells more like exhaust.
Are there any MPG effects on removing this solenoid? I've noticed my car has always had a slightly lower MPG, but I think that might be due to my heavy right foot.
Old 03-14-2013, 01:21 PM   #163
IA Performance
Member#: 25194
Dark Gray
I do not believe it will throw off the tune. I'm learning more and more about the overall evap system. I've tuned cars both with and without these sensors and they both run very similar fuel maps.
Stephen
Old 05-18-2013, 01:11 PM   #164
the silver subie
Member#: 216662
05 STI
Will one of the solenoids from a 03 wrx work on my 05 sti?
the silver subie is offline   Reply With Quote
Old 05-18-2013, 05:12 PM   #165
IA Performance
Member#: 25194
Dark Gray
I believe so. The best way to check would be to call your local dealership on Monday and have them look up the part number for your VIN and then give them the VIN of a 2003 WRX (grab it from a car on eBay). If the numbers match then it definitely will work. I know both models are identical in appearance and plug size.
Stephen
Old 05-18-2013, 07:06 PM   #166
the silver subie
Member#: 216662
05 STI
Thanks! A friend of mine ended up having one from his car that he was no longer using
Old 06-13-2013, 10:54 PM   #167
photoczynek
Member#: 358780
2002 WRX with EJ257
WRC Blue
Talking
so glad i found this thread, thanks for all the great info IA Performance!
photoczynek is offline   Reply With Quote
Old 07-12-2013, 12:51 AM   #168
Kcvietsuba
Member#: 361232
07 wrx
blue
I would like to revive this thread and see if i can get any help. I have the same problem as Striker on post #50.
I have 07 Wrx throwing code p0457. Idle is weak -dying then goes up and down. Also car stalls - shake very bad after pump gas. I checked the T hose they all connect and all other hoses I can find but everything seem okay. I was wondering if you have that diagram for wrx 07 jdm /delete hoses to prevent/ stop evap cel ?
Kcvietsuba is offline   Reply With Quote
Old 07-12-2013, 09:59 AM   #169
IA Performance
Member#: 25194
Dark Gray
Please reference this thread:
http://forums.nasioc.com/forums/show...1#post39456471
Although, it does not contain the answer regarding deleting the 07 purge solenoids. If I were you I would do a "boost leak test" to identify the leak. Since the car is idling poorly then I imagine there is a loose hose or broken nipple somewhere. The "boost leak test" will show this.
www.facebook.com/iaperformance
Old 07-12-2013, 06:26 PM   #170
Kcvietsuba
Member#: 361232
07 wrx
blue
Hey thanks for the reply. This morning i scan the car n got another code. p0301 misfire #1. I haven't perform any boost leak test yet... Still researching how. Sorry im new to subaru world.
Old 07-12-2013, 06:46 PM   #171
IA Performance
Member#: 25194
Dark Gray
Do the "boost Leak test" and then report back with what you find.
Stephen
Old 07-18-2013, 01:59 PM   #172
Got Groceries?
Member#: 25323
2003 WRX Wagon
Ok, deleted the purge valve on my '03 and I'm now getting the P0457 CEL. This is a new CEL 100% related to this mod, which was very helpful in straightening out some of my A/F Learning concerns.
Can I have my tuner safely disable this CEL code via the AccessPort or is this an indication of another issue?
Got Groceries? is offline   Reply With Quote
Old 07-18-2013, 03:48 PM   #173
IA Performance
Member#: 25194
Dark Gray
I'd consult with your tuner. They are the only ones to determine if it is safe to turn off.
Old 07-24-2013, 09:34 AM   #174
Mechie3
Member#: 120152
Originally Posted by burtonboy759 View Post
What do people do with aftermarket fuel rails when venting the valve off the evaporation pipe?
Aftermarket fuel rails would delete that evaporation pipe (the bottom pipe on the stock fuel rails Part C in the diagram)
Originally Posted by Mechie3 View Post
Take a line of fuel hose from the metal tube on the firewall, run it under the manifold and hook itup.
Originally Posted by Geek Guy View Post
If you did that, then you would have both positive and negative pressure in the fuel tank... theoretically as much as positive pressure as what the turbo puts out. Pretty sure you don't want that
Just saw this old tidbit I posted and thought I should clarify. I didn't mean to run a hose from the firewall hose to the manifold. Rather, replace the metal line in the stock fuel rails with rubber fuel hose and hook that up to the purge assembly where the metal line used to hook up.
Old 08-01-2013, 11:35 AM   #175
DarkBlueBug
Member#: 301445
2001 WRX
Dark Blue Mica (95H)
Okay, I've just read through all of this and as I read it I can completely delete the purge control solenoid and EGR valve as long as I vent the fuel evap line to atmosphere and bung up all of the take-off nipples. I will need to get the solenoid fault codes turned off by my mapper though - is that correct.
If it is I'll be cutting off all of the take-offs on tha manifold and welding and smoothing them as I've done with a load more lugs and take-offs...
DarkBlueBug is offline   Reply With Quote
WTB: Purge control solenoid valve jblaine Private 'Wanted' Classifieds 7 04-21-2009 08:51 PM
Purge Control Solenoid valve? Synx Service & Maintenance 4 07-02-2008 05:40 PM
Broken Nipple on Purge Control Solenoid Valve 48mpg Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 02-24-2008 07:40 PM
Purge Control Solenoid Valve?? abosworth Normally Aspirated Powertrain 3 07-21-2005 04:20 PM
Code 35 purge control solenoid valve troubles theascen Service & Maintenance 2 04-02-2004 04:36 AM
