Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 02-26-2013, 08:26 PM   #1
echo18904
Member#: 283563
1999 legacy outback
white
Angry hella supertones help!
i know there is a ton of posts like this but none of them seem to answer my question i got a set of hella horns from jna performance and i wired them up without the relay which alot of people seem to have no problem doing... i have checked tons of diagrams and it seems like i have done everything right when i honk the horn i hear a clicking but no sound it worked the first time of me trying i have no clue what could be wrong with my set up.
its a 1999 subaru legacy outback.
what i did to wire it:
1. unplugged the stock horns.
2. made a wire one side male which is plugged into the stock horn wire and the other side is female which is plugged into the copper side of the hella horn.
3. repeated the same for the other horn.
4. made a ground with a ring terminal i combined both negative wires and grounded them on the mounting bracket.
Any suggestions???
echo18904 is offline   Reply With Quote
Old 02-26-2013, 09:28 PM   #2
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Is the mounting bracket properly grounded? Painted surfaces will interrupt the circuit. The horns should have Ikea-like pictograms for instructions: 12v + in, ground out.
And use a relay.
Old 02-26-2013, 09:53 PM   #3
MaSTi
Member#: 41358
06 Forester
And use a relay.
+1
MaSTi is offline   Reply With Quote
Old 02-26-2013, 10:20 PM   #4
echo18904
Member#: 283563
1999 legacy outback
white
working on getting the wires set up for the relay right now i was trying to take the short and easy route guess thats not gonna happen
Old 02-27-2013, 12:35 AM   #5
kevinb721
Member#: 188314
wrb
happened to me first time around - make sure you have a solid ground. makes all the difference
kevinb721 is offline   Reply With Quote
Old 02-27-2013, 07:40 AM   #6
tuzzio
Member#: 292532
05 STI
What I did was plug one side into the stock harness and run the other side to a seperate ground.
tuzzio is offline   Reply With Quote
Old 02-27-2013, 08:17 AM   #7
leach0789
Member#: 210903
2013 MS3/Turbo Miata
Nitrous Rhodes
Set up the relay - it's worth it. If you still can't get it to work, let me know and I'll post pictures of my wiring.
leach0789 is offline   Reply With Quote
Old 02-28-2013, 06:00 PM   #8
echo18904
Member#: 283563
1999 legacy outback
white
i got it thanks for the help i ended up using the relay but now i think my starter is on its way out =(
Old 03-01-2013, 10:58 AM   #9
Drowner
Member#: 49297
14 Focus ST3
After installing on my past two subarus with making my own wires and dealing with mounting, on this car i bought the bracket and the wiring harness, i simply couldn't be bothered to do it from scratch again.
http://www.subimods.com/subimods-hel...rness-kit.html
Drowner is offline   Reply With Quote
Old 03-01-2013, 12:08 PM   #10
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
JNA Hellas are the powder coated ones right? Are they worth the extra 15 Bucks?
BradX978 is offline   Reply With Quote
Old 03-01-2013, 05:09 PM   #11
echo18904
Member#: 283563
1999 legacy outback
white
they are pretty nice and the powder coat stays pretty well i thought i was going to scratch them a few times but surprisingly i didnt i woukd say they were definetly worth the extra $15
Old 03-02-2013, 11:56 AM   #12
BradX978
Member#: 334143
2008 WRX
Vin Diesel.
Good to know, what color did you get? I'm going purple haha
Old 03-05-2013, 03:15 PM   #13
06scoobydoo
Member#: 264385
2016 STI
white
Im having the same problem. I just got my hella horns, I thought it was plug n play, but wen I tried to install my old ones back on n it does the same thing. Clicks n no sound
06scoobydoo is offline   Reply With Quote
