Old 01-08-2013, 11:58 AM   #3226
Member#: 67
1999 Outlasting
the competition.
tom@kartboy is offline   Reply With Quote
Old 01-08-2013, 01:16 PM   #3227
silviajdm
Member#: 163703
09 Forester
SSS
My sticker phase ended a few weeks ago
silviajdm is offline   Reply With Quote
Old 01-08-2013, 02:26 PM   #3228
WRX7871
Member#: 309558
2010 WRX
Dark Grey Metallic
Default custom pillar pod
WRX7871 is offline   Reply With Quote
Old 01-08-2013, 07:48 PM   #3229
S1CkWrx
Member#: 325249
2012 wrx
dgm
^ would look so dope if you gott a black interior where its beige for us WRX owners....
S1CkWrx is offline   Reply With Quote
Old 01-09-2013, 10:36 AM   #3230
shamrock 05
Member#: 120057
2015 WRX (base) 6spd
Originally Posted by shamrock 05 View Post
^^^^^^^This pisses me off... I have Autometers too and a mechanical boost gauge. The gauge used to be at 20 psi in vac at idle and now its at 15 psi at idle.....while driving and letting off the gas the needle would sink down to 23-24 psi in vac and now it only goes down to 18-20 psi MAX in vac.....so WTF
See here for symptoms^^^^^my issues are only with what the gauge is reading in vac
Originally Posted by Pearly_Whites View Post
It could be how you worded it and your units of measure. Vacuum reads in 'inhg'. -20inhg is around 9psi of vacuum.
So which is it?
the boost gauge does read in vac when you are not in boost....ie sitting at a red light/ letting ur foot off the gas while driving.
shamrock 05 is offline   Reply With Quote
Old 01-09-2013, 04:37 PM   #3231
Pearly_Whites
Member#: 164714
2007 WRX TR
Yes.. I understand this. I feel like we've done this before...
Go look at your gauge... Above 0 will read in a unit of measurement known as PSI. Below 0 will use a different unit of measurement known as inhg.
Psi and inhg are not the same thing. However, they can be converted.
Pearly_Whites is offline   Reply With Quote
Old 01-10-2013, 09:13 AM   #3232
moviet
Member#: 341415
The new pod would one be able to keep the clock, fuel economy meter and thermometer?
moviet is offline   Reply With Quote
Old 01-10-2013, 09:37 AM   #3233
Stephen_cnd
Member#: 179422
I just wired these up the other evening.
Now on to the sensors.
Stephen_cnd is offline   Reply With Quote
Old 01-13-2013, 06:03 PM   #3234
havenshalo44
Member#: 286193
2006 Impreza WRX
Default Modified Clock Bezel
http://www.facebook.com/photo.php?fbid=10151163073651377&set=a.12478973137 6.109776.579571376&type=1&theater
Still a work in progress, its a modified bezel where the clock usually sits. Turned it into a 3 gauge pod holder with some fiber glass!
havenshalo44 is offline   Reply With Quote
Old 01-13-2013, 06:36 PM   #3235
cannondalemtb
Member#: 267715
'05 FXT-Built-6spd
04 HD softail deuce
Custom fiberglassed dash pod with Defi boost and Defi link display.
cannondalemtb is offline   Reply With Quote
Old 01-14-2013, 07:02 AM   #3236
campen
Member#: 343570
Interesting.. kind of like my zeitronix lcd display. External sensors or does it read off of the obd port?
campen is offline   Reply With Quote
Old 01-14-2013, 06:12 PM   #3237
cannondalemtb
Member#: 267715
'05 FXT-Built-6spd
04 HD softail deuce
External sensors for:
Boost
Fuel pressure
Oil pressure
Oil temp
Water temp
EGT
Speed
All feed to a controller mounted in the center console that can set warnings, replay peak, and can even record and playback. The display shows two gauges at a time and automatically displays anything in peak/warning. When idle for about 10-15 seconds, it begins to cycle thru everything, showing two gauges at a time.
Old 01-17-2013, 07:29 PM   #3238
tuzzio
Member#: 292532
05 STI
Finished wiring my innovate today:
tuzzio is offline   Reply With Quote
Old 01-21-2013, 11:25 PM   #3239
brendan04wrx
Member#: 167494
04 STi
psm
brendan04wrx is offline   Reply With Quote
Old 01-22-2013, 11:53 AM   #3240
Louie
Member#: 43393
2014 Audi a6
Daytona Gray
Nice link. I also have the HUD for the defi link.
Old 02-23-2013, 02:32 AM   #3241
Excision
Member#: 294622
2007 STI - WRB
Perrin GTX3076r, Slow
bumpskie. lets see those gauges
Excision is offline   Reply With Quote
Old 02-23-2013, 02:52 PM   #3242
SMY
Member#: 256505
2013 STI Sedan
Originally Posted by flimflamman View Post
This is my second Autometer dual gauge bezel. The first one was flimsy and I ended up cracking it. The second one I think I got from ImportImageRacing but it wasn't advertised as an Autometer. When it arrived there was a piece of paper in it that had Autometer stamped on it with instructions. This one was a little darker and thicker. The top does not bend down like the first one (which was annoying).
Gauges are AEM digital boost and wideband.
Oh my better go with ours which is super strong and doesn't require you to use screws...
SMY is offline   Reply With Quote
Old 02-24-2013, 03:24 AM   #3243
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Gauges in...
cianuro is offline   Reply With Quote
Old 02-24-2013, 10:24 AM   #3244
klarowe
Member#: 284753
2004 WRX STI
World Rally Blue
Got rid of both failed fiberglass pods and went generic. ATI clock pod with Tru-boost, Wideband A/F, and Aquamist. Then I have an Autometer (I beleive) cluster pod with a Prosport Oil Temp and Prosport Oil Pressure.
klarowe is offline   Reply With Quote
Old 02-24-2013, 01:37 PM   #3245
QwaktastiK
Member#: 219100
'09 WRX Premium 5dr
COBB Stg3 336whp/370wtq
Just for fun, our Cuisinart coffee maker's coffee gauge:
QwaktastiK is offline   Reply With Quote
Old 02-27-2013, 12:24 AM   #3246
New2Subies_801
Member#: 318020
Work in progress....
OEM SPT pod modified to house 52mm gauges.
I didn't like the "hacked" look of the notches, so I moulded the face to the pod for a cleaner look.
Will post pics of the finished product...when I'm finished.
New2Subies_801 is offline   Reply With Quote
Old 03-11-2013, 01:14 AM   #3247
Yeeman19
Member#: 8
Chapter/Region: HIIC
2012 WRX
Ice Silver Metallic
STRI Boost w/control button.
Yeeman19 is offline   Reply With Quote
Old 03-11-2013, 01:58 AM   #3248
socal_subie
Member#: 341316
^looks good man!
socal_subie is offline   Reply With Quote
Old 03-11-2013, 03:57 AM   #3249
itsburrito
Member#: 334721
soon ill have my sti gauges in
itsburrito is offline   Reply With Quote
Old 04-09-2013, 03:33 PM   #3250
stierzy34
Member#: 92113
2013 Mini Cooper S
"Martha"
Love the stri. Been thinking about ditching the SPT for one!
stierzy34 is offline   Reply With Quote
Post Pics Of Your Navigation Setup ( Eclipse , N1 ,N2 .... ) minx1225 Interior & Exterior Modification 1 09-06-2005 01:43 AM
Post pics of your FMIC setup KitchenerWRX Member's Car Gallery 2 08-30-2005 01:27 PM
Post pics of your gauges lit up... MomoWRX Electrical & Lighting 22 12-11-2004 10:21 PM
post pics of your gauge clusters/bezels 03wrx 03twrx South East Region Forum 5 11-13-2004 09:28 PM
Post Pics of your gauges and cluster shots! Leo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 02-19-2004 10:16 AM
