Old 02-25-2013, 06:11 PM   #1
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Default DIY side vent light up Write-Up
First off I tried posting this last night, it said it needed to be viewed by a mod. But after a day I decided it might not have gotten through since I never had that problem before. If it does show up and this is a repeat, please delete.
Link to my full build: http://forums.nasioc.com/forums/show....php?t=2467134
Ok, this is my first write up for this site and my first modification to my new wrx. I want to install L.E.D.s in my side vents so they light up when the headlights are on. I have multiple requirements with this install too:
1. I want everything to look like it came from the factory (all the wires hidden and out of the way)
2. I want everything to be taken apart at each panel so if I have to take it off I don’t have to fully re-run the wires.
3. I don’t want to splice into any wires, since depending on your dealer, it has the possibility of voiding the warranty.
4. I want everything to be easily reversible.
5. If I decide that having them on all the time when the headlights are on is too “ricey”, since at the moment I am un-sure if it will look that way, I want to make it easy to connect them to the turn signals instead.
Before
After
To learn how to take off the Side vent it is easiest to just go to youtube and look up the video “10-13 wrx rally armor install” this shows exactly how to do it. It will look like this
Start with running the L.E.D. wires and deciding on which fuse to tap into. I want to have them on when both the bright and the dims are on, this is the fuse I wanted to use, it is the fuse labeled “Hi/Lo (Lo)” 30 amp fuse. I had originally wanted to use an “Add-A-Circuit” and sadly these are only rated to 10 amps, I actually found a story of it catching on fire with 20 Amp supplied so we have 2 options…
1) Just shove the wire into the fuse stop and push the fuse down on top adding an in-line fuse so the circuit is protected.
2) Finding and interior fuse that is 10amps or lower to tap into that is switched, in this case the illumination fuse (also used when installing gauges) works.
After a couple days of thinking about it (had to wait till a Sunday anyways) I opted to go option 1. I think both ways will work and be safe but option 1, in my mind kept it more stock by not having to get the wire from the interior to the exterior.
Next let’s plan on where we are going to run the wires, and where we are going to place the quick disconnects. I decided 1 wire to the driver side fender while running a second all the way around the front right before the radiator under the metal cover to the passenger side. I decided that for two reasons,
1) I think I can hide the wire better then running it under the cowl.
2) When I do the light up emblem the wire will be there to splice into.
Ok, so I ran my driver side wire first starting at the fuse box and ending at the passenger side fender, I left it long and will cut the sire as the last thing I do.
I moved onto the power wire. I used and in-line water proof fuse to protect the circuit. The fuse box has a hole on the bottom so I did not need to create one. I had to shave some rubber off the fuse holder to get it to fit in the spot (note: After it was all said and done, I notice I did no leave enough slack to easily pull the inline fuse out to replace it, I can but its difficult, I suggest giving it some slack). I soldered a bit of wire onto the fuse holder so it would go through the bottom and wrap up. This is the grounding bolt I used and I just ran the wire under the fuse box to meet up the power wire.
00camaro16 is offline   Reply With Quote
Old 02-25-2013, 06:11 PM   #2
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Then I ran the passenger side wire around in front of the radiator and down the fender. Here are some pictures of the process.
Now on to the Fender L.E.D.s, I want to place them at an angle which you won’t be able to see them, but far enough back that the light will hopefully be defused enough so that you won’t see “spots” of light on the door panel. I used side emitting LED strips from oznium so that they didnt block any of the vent.
This is where I will try first.
Splice your power wires and grounding wires using the quick disconnects (in my case the stripes came with quick disconnects), twist just for now, then place fender panel back temporarily so you can test the placement of the L.E.D.s. Adjust if needed, if not then solder/shrink tube everything up making sure to keep enough slack in the wires so you can pull the fender and get to the quick disconnects. Repeat on the other side.
Old 02-25-2013, 06:12 PM   #3
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
I also painted the fender badges at the same time.
(Sorry for dirty pics, where I live it is almost useless to wash your this time of year because of the salt... The first day I had it a week ago it looked like this)
Before
After
LIGHTS
Before
After
I will do another write-up on the front emblem light since after reading more into it looks like most people damage the emblem when trying to get it off and I am not ready to buy a $60 badge. I also think it might be easier when I take the bumper off to paint the head lights.
Hope you enjoyed it, Ask all the questions you want. After it was all done the lights were a bit more "blue" then I expected, it wouldn't be hard to switch them if I decided to switch the "cool blue" for the "natural white". I also notice I forgot to take picture of the final product and what you see, I wrapped the wires were visible with that black tubing stuff, it looks much better. I will add those pictures tonight.
Chris
Old 02-25-2013, 06:38 PM   #4
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Here are the pictures of how the wiring ended up. These are pictures of the only parts the wires are visable.
Fuse box
Fuse box closed
Driver side, where the main power and grounds connect to the other wires.
Passenger side
Whole engine bay
Old 02-25-2013, 07:33 PM   #5
murking
Member#: 323284
06 sti
Total rice, but thank you for at least keeping it professional.
I do however like the idea of them being turn signals.
murking is offline   Reply With Quote
Old 02-25-2013, 07:47 PM   #6
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Yea like i said I'm not sure about it yet. Figured I'd give it a bit. It is much more subtle in person
Old 02-25-2013, 07:50 PM   #7
Serkan
Member#: 180514
2004 Sti
rICE.
Serkan is offline   Reply With Quote
Old 02-25-2013, 07:55 PM   #8
az_sti_04
Member#: 239732
2004 Sti
+1 agreed
az_sti_04 is offline   Reply With Quote
Old 02-25-2013, 08:15 PM   #9
ImBenDood
Member#: 227634
2006 Impreza 2.5i
SGM - 26D
I don't think it's rice... I think the pictures don't do it justice... I imagine it is much more subtle and not as super bright as the camera makes it seem. Would be cool to get the dual LED strips so its white led constant than switches to orange flashing when you hit the turn signal.
+1 on creativity and professional looking install.
ImBenDood is offline   Reply With Quote
Old 02-25-2013, 08:35 PM   #10
WRX-ERROR
Member#: 83211
2002 WRX - stg4
Is that speaker wire?
WRX-ERROR is offline   Reply With Quote
Old 02-25-2013, 09:31 PM   #11
yatssdaa
Member#: 348213
yatssdaa is offline   Reply With Quote
Old 02-25-2013, 10:01 PM   #12
danny_d19
Member#: 180748
2013 Scion FRS
Whiteout
thought the same thing myself lol
danny_d19 is offline   Reply With Quote
Old 02-25-2013, 10:06 PM   #13
WRX USA
Member#: 11192
.. VF48'd Bugeye
As turn signals in amber they make sense otherwise regardless of brightness they do nothing for you...
WRX USA is offline   Reply With Quote
Old 02-25-2013, 10:44 PM   #14
talonhart2
Member#: 346338
1998 Legacy OUtback
These would be awesome turn signals!
talonhart2 is offline   Reply With Quote
Old 02-25-2013, 10:55 PM   #15
aerosaaber
Member#: 33850
2006 WRX Wagon
WRC Blue
Not my thing, but it looks like you did it well.
aerosaaber is offline   Reply With Quote
Old 02-25-2013, 11:06 PM   #16
jinstwrx
Member#: 338623
2011 Subaru WRX
red
this is as bad as led washer nozzle total ricer
jinstwrx is offline   Reply With Quote
Old 02-25-2013, 11:12 PM   #17
Turtules
Member#: 268734
2013 WRX
I can dig it...good job!
Turtules is offline   Reply With Quote
Old 02-26-2013, 07:55 AM   #18
00camaro16
Member#: 334291
2013 WRX Limited
Dark Grey Metallic
Da*m, glad I brought my change bucket for all the .02 laying around lol.
But I am going to have a decision about these tonight whether I keep them or leave them. I am leaning much more towards taking them out for a couple reasons.
1) having the wire just shoved into the fuse box is really bothering me even though I don't see it I know its there.
2) I am thinking it is just too flashy for me.
3) Don't think it will go well with future exterior mods.
4) The lights don't match the HID's color so I would have to swap them out any ways.
5) Police attractant.
I could switch them over for turn signals easily if I wanted too since I ran the wires planning for that, but I would have to splice into the wires therefore not complying to my requirements. I also would have to swap them on for amber strips, again easy because I planned it, but another step. So I think I am simply going to take everything out, maybe install the stripes under the cowl connected though a switch to constant power in order to create an under hood light, or connect to dome lights in the hatch area for more light, or just not use them (they're meant to be used to make audi style headlight, but I just don't like that's look unless it came factory).
Chris
Old 02-26-2013, 08:17 AM   #19
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I've seen another thread where a guy did amber ones for turn signals. Looked great. I think having them on all the time (with the headlights) would look a little strange.
Old 02-26-2013, 11:34 PM   #20
thomasubi
Member#: 338934
1998 Impreza L Wagon
Red
Looks cool. It would be sick if they were amber turn signals
thomasubi is offline   Reply With Quote
Old 02-27-2013, 01:53 AM   #21
pwujszuf
Member#: 348336
pwujszuf is offline   Reply With Quote
Old 07-06-2013, 07:44 PM   #22
lokilabs
Member#: 322934
I would like to do this on my 13 hatch but need a list of materials, as well as the step by step to include turn signal sync. I want to make sure they all blink at the same time.
lokilabs is offline   Reply With Quote
Old 07-06-2013, 09:42 PM   #23
JDMSTA
Member#: 310615
1213 12'Sport+13'STi
Pretty good write up. I think its all up to the owner if its good taste or not. I personally like it with a switchback effect like what I did to my headlight reflectors here in this thread. http://forums.nasioc.com/forums/show....php?t=2513902
JDMSTA is offline   Reply With Quote
Old 07-08-2013, 03:39 PM   #24
Masta Splint
Member#: 189211
2005 18g WRX wagon
Nice write up, thx. Looks dam good. I like it!
Masta Splint is offline   Reply With Quote
Old 06-03-2014, 10:01 PM   #25
tantric rex
Member#: 163064
14 wrx 5dr
dgm
Interesting wiring approach. Nice write up. Subscribed for future reference.
tantric rex is offline   Reply With Quote
