12-29-2012, 10:05 PM | #76 | |
Member#: 287783
RMIC
Vehicle:08 predator evo X RR |
and im sure he would defiantly agree with this ***kidding lol
12-30-2012, 05:08 PM | #77 | |
Member#: 53451
Vehicle:2000 JDM Impreza SRX w/ AVCS Silver |
http://www.bptstore.com/Subaru-WRXST...rger_p_25.html http://www.bptstore.com/Subaru-WRXST...rger_p_16.html |
12-30-2012, 06:43 PM | #78 |
Member#: 243992
MWSOC
Vehicle:2006 WRX TR WRB |
Those both are the turbos I want, but in twin scroll.
But I might be able to put an anti surge cover on one of those I gotta do more research. |
02-27-2013, 01:53 AM | #79 |
Member#: 161271
NWIC
Vehicle:2005 Saab 92x |
Just my 2 cents, but I had a Forced Performance 68hta and HATED it. I have a stroker, so maybe my setup is weird, but until we went with a 10 cm^2 hotside, we had a hard time getting more than 300 whp. Throughout the whole process the customer services was lacking, and worse often incompetent giving bad information.
The moral of the story is that I will never buy a FP product again. Avoid the hype people. Who cares what a maxed out tune with e85 and high boost looks like. It isn't a tune you want to run day to day. |
02-27-2013, 10:10 AM | #80 | |
Member#: 142608
TXIC
Vehicle:2003 Sonic Yellow Marginally well behaved. |
I can't speak to the customer service issue, I havn't had any more or less problems dealing with FP than I have with any other high performance vendor. It's not hype if it works. |
02-27-2013, 11:19 AM | #81 | |
Member#: 130990
NWIC
Vehicle:06 Red Ltd.Wagon Dom 1.5xtr JJ tuned |
As it is, my setup has been very successful on pump 92, but my motor is a completely different build than yours. |
02-27-2013, 10:07 PM | #82 |
Member#: 161271
NWIC
"Works" is a very non-precise word. MPS got it to "work" for me and got about 330 whp using the Blouch 10 cm^2 hotside on pump gas, but it was still a laggy turd. Without the 10 cm^2 hotside, that turbo caused a huge restriction. The off boost response was terrible. If I was already cruising a med RPM and then wanted to accelerate it would take for ever to get to my target boost, normally in time to shift. Makes 330 whp and sucks most of the time while driving != works to me.
I have a stroked ej205, so my build may be non-standard, but with my rotated Garrett gtx3071r, the drivability is night an day. I know it isn't exactly the same, but I provide it as a counter point. I have more power everywhere (+100 whp more on top, +20 lbs tq down low), get to peak boost several 100 RPM faster, and there is not much lag off of boost in cursing situations whereas sometime the FP sometimes would not hit the target boost. Making over 400+ whp and being responsive == works. |
02-28-2013, 12:25 AM | #83 |
Member#: 281835
NWIC
Vehicle:2008 STI 1990 mk2 GLi vdub |
i placed an order for my hta71. i will post results in few weeks or so.
02-28-2013, 07:55 AM | #84 |
Member#: 303849
Tri-State
Vehicle:2004 Forester Xt Silver stg2 |
let me see the results .. looking to buy one too for my fozzie
02-28-2013, 10:14 AM | #85 | |
Member#: 142608
TXIC
Besides, this thread is about the HTA71, not the HTA68. Many people have had sucess with the 68. I'm sorry that you had issues with getting it to work for your particular application. However, the HTA71 is an excellent turbo and my car is a stellar example of that. FP turbos have been working well in this segment for years, the sucess of the Green, Red, Black, etc shows that they make good turbos that work well. Your experece with the HTA68 (arguably their most controversial turbo) shouldn't define them as a company or the products they build. That was the basis of my statement. The HTA71 isn't hype. it really works. |
03-01-2013, 10:30 AM | #86 |
Member#: 145985
Off course the HTA71 is a hype to be, it's just a reasonable priced turbo that pushes good torque and power.
But.......to my opnion ....... .....it's just another 71mm compressor with a to small hotside, that comes relatively cheap and will do for 95% of the scooby community that's working in the powerlevels the hta71 could deliver. It fooks with the engine's VE due to the small hotside, so you have to run high boost. And not a **** was given. Because it's all about the pub-numbers......but it performance for what you pay for it, but do not expect miracles. A 71mm compressor should do ca 430hp, and that's just what it does. Now if you take a decent -non cheap ass turbo-, with a proper hotside (10cm or bigger), and super fancy BB, billet compressor, you will notice you need MUCH less boost for same output (or even more output) and much more toppower. Your AIT will go down drastically, which will able you to push timing more. In the end, when everything matches inside the engine, you will push either bigger numbers, or can step down in compressor size to keep same numbers but gain in spool and response. For what it's worth, a little info on my setup (08Sti) I'm running a MDX321T in stock location from Lateral Performance (Turbo Dynamics) which is a hybrid GT3071, with a 68mm billet compressor wheel, and the hotside untouched (only IWG) Result 400Nm/2400rpm 600Nm/3000rpm, 685Nm(500ftlbs) 3250rpm and 430hp from 4200rpm till redline (on a built Cosworth Motor 8,6 CR with std heads). The respons is awesome, pushing all this air through the std Sti 08 Tmic. Yes I stepped down in size, caise my priority was spool, respons, and early torque. I do not say my setup is better than an HTA71, I just would like to point out that there is power and power. Topend is most probably the same, but the area under the graph is unequalled. A good turbo doesn't come cheap, and the initial feeling with a fresh mounted HTA71 will be freaking awesome, I know that, i've done that Till the moment somebody with a quality built lines up, hits the throttle, and just rockets off. You will not and cannot believe your eyes at that moment. But when you talk to the guy that just killed you massively, and start thinking for yourself in stead of following main stream mods that fit your car, but actually do not suit the engine And to my opinion that's what the HTA71 is and will be, just another mainstream 71mm compressor turbo. No trolling intended, Cheers Erik (The Netherlands) Last edited by Dutch Devotion; 03-01-2013 at 05:10 PM. Reason: stupid typo's :) |
03-01-2013, 01:57 PM | #87 |
Member#: 142608
TXIC
I agree with you that a turbo costing 2x as much with a ball bearing center section, billet whels, etc will be (and damn well should be) better. But trying to compare a $2500 turbo to a $1200 turbo is kinda silly. A $2500 turbo better have more area under the graph. Saying that these are cheap-ass turbos is, IMHO, ignorance. They have not shown to have any longevity problems, and power is power.
Just cause people don't run out and buy the most expensive thing they can doesn't mean they aren't thinking for themselves (actually, it could be said that the 'if it's expensive it must be good' mentality is the definition of not thinking for yourself)...case in point, this turbo didn't even exist in a Subaru variant before my car...it was made for my specific application...it worked so well, they decided to offer it as a standard turbo in their lineup. I havn't been beaten by anyone yet simply because their turbo cost more than mine and there isn't anything wrong with building a powerful, competition proven car on a budget. I don't think an inexpensive turbo that does what it claims to do is hype. That's my point. |
03-01-2013, 02:24 PM | #88 |
Member#: 145985
Thanks for your constructive reply (y)
Power does not equal power That's my whole point..... You need area under the graph to be really quick. And what makes you get a boner is response and crispyness (don't know another word for that feeling). If you combine this area, spool, response and crispyness, I think we're talking "quality of power" or something. The 71hta is not a cheap ass turbo, sorry for my bad insinuation, it will become a mainstream mod, same like the super evoIII td05-16G once was. And that's nothing to be ashamed of, it might hype, or not, isn't even important I would say, what it could be, most probably, is a hughe money machine for FP, and for that I will take my hat off and salute FP again. They manage to do it every time again and again. super evo3 16G / 68hta / 71hta Last edited by Dutch Devotion; 03-01-2013 at 02:26 PM. Reason: taking the Dutch vibe out of the English LOL |
03-01-2013, 02:35 PM | #89 | |
Member#: 142608
TXIC
Seriously though, i completely agree. The HTA71 will become (or already is) a mainstream turbo for those on a budget...and i don't think there is anything wrong with that. You can still make serious power with them, and have a car that is very fast. I also agree that more expensive turbos with fancy covers and BB centers, and Billet wheels, will perform better...ball bearing over journal bearing? I mean come on...that's just physics. |
03-01-2013, 02:39 PM | #90 |
Member#: 14116
Erik, the 71HTA works PERFECTLY just as it comes with 8cm turbine housing and even with small compressor housing, it's amazing! It can't compete with the turbo you have, but at the price it's a VERY nice little turbo. It delivers what the 68HTA couldn't deliver, spools about the same as the former, but with LOTS more power.
But to be honest, a TD05H 20G with 8cm turbine housing is quite similar... I couldn't compare both in the same car and neither was I able to push the 71HTA to it's limits (because running out of injector), but even when ABSOLUTELY not pushed the 71HTA outperformed the 68HTA quite easily. The turbo you have is not comparable with a GTX3071R as yours is noticable smaller, it has the "normal" GT3071R turbine wheel, combined with a 68 mm billet compressor which flows about the same as the Garrett 71 mm compressor. Because of the smaller and lighter compressor the response of your turbo is better than the non-billet version. It's an amazing turbo! (as you have discovered) And the HTA71 isn't a super "boner" type of turbo (to take your words), but it does a lot of things very well. |
03-01-2013, 03:24 PM | #91 |
Member#: 145985
Hi Mark thanks for jumping in.
So we agree, I should redefine; the HTA71 gives a pretty good boner, the MDX321T gives instant and continuous orgasm. Case closed. To be serious, what I like to point out, the 71hta will work for 99% of the guys. It's not a bad turbo, not at all. I think it's a very clever move of FP to put it on the market |
03-02-2013, 06:18 AM | #92 |
Member#: 14116
This is a decent description Erik!
It's not (only) a clever move from FP, but one which was needed, as the HTA68 didn't deliver what was promised... (which wasn't really a problem for me, as I have used this turbo with other goal in mind and it's response was amazingly good for the power it could make) I don't know if this one (71HTA) does exactly what is promised, but what I DO know from experience with this turbo, that is DELIVERS what I expect it to do and MORE! It makes very good power at quite low boost levels, I maxed out the injectors and couldn't (and didn't want to, as the car already had quite a bit more power as I had promised the customer) test what it did at even higher boost. But I will test this sooner or later. |
09-12-2013, 12:22 AM | #93 | |
Member#: 235550
RMIC
Vehicle:2007 WRX TR OBP |
A small 16g might perform the same as a vf turbo... |
09-12-2013, 01:07 AM | #94 |
Member#: 178426
Vehicle:2010 S4 Gray |
That's about what I would expect. A small 16g will still outperform a vf, at least on the top end.
09-12-2013, 01:44 PM | #95 | |
Member#: 130990
NWIC
Edit -- Ok, here's a long thread on 18g and 16g 1/4 mile times. Looks like 16g's can run into the 11's, and 18g's can even break into the tens: http://forums.nasioc.com/forums/show....php?t=1058200 Last edited by Dave D.; 09-12-2013 at 01:53 PM. |
09-13-2013, 12:57 AM | #96 | |
Member#: 235550
RMIC
The reason why you don't see a lot of fast 16g wrxs or stis is because nobody pushes the turbo the way it's meant to be pushed. And evo3 16g doesn't really even wake up till 18-20psi. Dsm guys run these turbos into the 28-30psi range. A 16g isn't popular on the ej25 because people say that it's too small. Thus, there aren't a lot of people with built a bottom end pushing 28-30psi on E85 to really turn up any results. A bug eye went 10.80 with an 18g... an 18g only flows 25cfm more than an evo3 16g 8cm. |
09-13-2013, 01:14 AM | #97 | |
Member#: 178426
04-13-2014, 10:14 AM | #98 |
Member#: 166005
MWSOC
Vehicle:2005 Saab 92x Beaten Silver |
Anyone else have new information about results with this little guy?
04-13-2014, 02:59 PM | #99 | |
Member#: 216580
MWSOC
Pk tq around 4500rpm. 500whp could probably be reached with more boost at redline. But 475ish whp is with tapered boost 20psi at redline. 28psi peak |
04-14-2014, 10:07 PM | #100 | |
Member#: 166005
MWSOC
Peak torque at 4500 meaning peak boost right around there as well? Was that a stock 2.5 motor or a built something? Pretty exciting to hear the WHP possibilities! |
