Old 02-26-2013, 12:53 AM   #1851
pkL
Member#: 313093
2012 Impreza 2.0i
5-door Sport. Dark Grey
For those of you with Hella Supertones, how did you guys mount the horns? Did you fabricate something from the local hardware store or buy a mount like this? http://www.cruxmotorsports.com/index...&product_id=93 Would such a mount be even necessary? I'm OCD so I would probably spend forever trying to align them properly (so I am leaning towards buying one). I've read about people mounting them to their hood latch, except the hood latch rubs against it.
I guess this bracket from Subimods is a safer bet being cheaper too helps as well http://www.subimods.com/subimods-com...s-bracket.html.
Would getting this horn harness be worth it, I'm sure it's doable without and it's $5 cheaper (at $35) when you order it along with the bracket? http://www.subimods.com/subimods-hel...rness-kit.html
Old 02-26-2013, 03:37 AM   #1852
uspopo
Member#: 317014
2015 WRX Limited CVT
ISM
I got the complete kit from Subimods for my 12 Sport Limited and it worked fine. Just a word of advice, make sure you use the OEM relay in the Supertones kit and NOT the one with the harness kit. When I had mine installed we used the cheapie relay and it worked for about 5 minutes and then stopped. Pain in the ass to troubleshoot and we were checking all the fuses and connections. Then we swapped out the relay with the OEM one and it worked without a hitch.
uspopo is offline   Reply With Quote
Old 02-26-2013, 06:41 AM   #1853
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by ans2k View Post
yea thanks. i considered over lays or just yellow bulbs. whats the difference.
I have the overlays on my factory ones now, they do change the output color to yellow and they are protective too.
In my post above I meant to say that is what I will be doing again, not "u". But I think you would be happy with overlays too. I have headlight armor now, I think they are the thickest on the market.
Old 02-26-2013, 06:42 AM   #1854
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I made my own bracket, there is a thread here with installs from a few of us.
Old 02-26-2013, 07:37 AM   #1855
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
Lens protection. And lenses with overlays look nice even when the lights aren't on.
Old 02-26-2013, 11:04 AM   #1856
ans2k
Member#: 315631
2012 Impreza Sport
But don't they decrease the amount of light output?
Old 02-26-2013, 11:41 AM   #1857
Zeeper
Member#: 299286
2015 WRX CVT
Default Flapatax Simplified (installed)
Finally got a chance to install the front flaps, rear I did a couple of months ago. I like these, they are big enough without being obnoxiously big, and offer WAY more coverage than the OEM aero mud guards that Subaru sells (those are a fashion accessory, they barely stick out and down).
He has two designs, these are Flapatax Simplified, bought on ebay for $57.00 including shipping, Pumpkyn (sp?) who is occasionally on the forum makes and sells these.
They install with simple U-nuts and bolts, and are very stiff urethane. I have decals that I might add when it is warm for the rear.
Overall very pleased, at first I got some bum hardware (which is why the rears only were installed) be he corrected that right away, with the correct bolts and U-nuts I put the fronts on in about 20 minutes including putting the car on jackstands and pulling the wheels (and cleaning around the wheel wells):
Old 02-26-2013, 11:43 AM   #1858
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
If so, it's not by much.
Old 02-27-2013, 12:17 PM   #1859
pkL
Member#: 313093
2012 Impreza 2.0i
Looks good, I'm assuming you had to drill your own holes in order to mount them, is that correct? Just wondering about your though process for picking the simplified over the originals, I can't seem to decide.
Old 02-27-2013, 12:19 PM   #1860
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
No, they just act as a filter, they are translucent yellow
Old 02-27-2013, 12:20 PM   #1861
Zeeper
Member#: 299286
2015 WRX CVT
I wanted the least big option, because big mud flaps are like big ears, useful probably but not universally considered attractive (my ears are closer to big than small, so I should know).
The mounting holes are already in the fenders, for the front the clips and bolts replace the lower two plastic clips and the rear has holes right where you need them to install them. It isn't too difficult, though you probably should pull the wheels to speed it up. The front you also have to temporarily dislodge the wheel well plastic but it isn't difficult to do.
Old 03-05-2013, 01:32 AM   #1862
pkL
Member#: 313093
2012 Impreza 2.0i
Okay thanks, I'll keep that in mind when I install mine. How long was the installation process?
Old 03-05-2013, 01:33 AM   #1863
pkL
Member#: 313093
2012 Impreza 2.0i
Do our cars have a harmonic balancer and if yes is it attached to the crank pulley? I haven't had a chance to install mine yet and I'm a bit reluctant after reading this: http://www.machv.com/tip11cranpul.html
"Performance enthusiasts have been known to remove harmonic balancers, usually when the balancer is attached to the crank pulley, deciding that they aren't necessary and their mass reduces the performance of the engine. However, this is unproven and potentially very risky because the danger of damage to the engine from the vibrations the damper is intended to prevent is too high."
Old 03-05-2013, 05:48 AM   #1864
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I'm pretty sure we do and it is built into the crank pulley. I like having bearings so I won't ever get one
Old 03-05-2013, 06:28 AM   #1865
Zeeper
Member#: 299286
2015 WRX CVT
Probably about ten minutes each or less, and time spent pulling the wheels to access everything.
Old 03-05-2013, 07:20 AM   #1866
Irongrave
Member#: 325040
2012 Impreza 5door
DMG
its been stated in this thread and others the crank pulley is just that a crank pulley on these motors. The bigger key is to run a stock sized pulley so your not under driving other components.
Irongrave is offline   Reply With Quote
Old 03-05-2013, 10:31 AM   #1867
scoutisimo
Member#: 315759
2014 WRX Hatch
Can anyone confirm this?
scoutisimo is offline   Reply With Quote
Old 03-05-2013, 01:08 PM   #1868
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
the service manual just talks about the crank pulley. i have never looked at mine so I can't tell you if that is just subaru's description or if it is a harmonic balancer
Old 03-06-2013, 01:41 AM   #1869
pkL
Member#: 313093
2012 Impreza 2.0i
If you could point me in the direction regarding our Impreza's and the crank pulley with/without a harmonic balancer, it would be much appreciated.
Old 03-06-2013, 02:33 AM   #1870
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
Someone contacted SOA and they actually gave a full response somewhere on the forums, I saw it as well. They assured it was absolutely NOT a harmonic balancer.
Though, I'd agree with the fact that the lighter weight could wear out other parts faster.
danstheman7 is offline   Reply With Quote
Old 03-06-2013, 04:29 PM   #1871
mrbloink
Member#: 333058
Getting my taxes back in a week so I think it is time to do some suspension upgrades to my car! I'm going to go with a perrin 22mm rear sway bar, a cusco 24mm front sway bar, and front and rear poly perrin end links. Will total $770. Opinions?
mrbloink is offline   Reply With Quote
Old 03-06-2013, 04:32 PM   #1872
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
I would be afraid that sway bars of those dimensions would make an oversteer condition too easy for my taste. But if that's what you want, and you know how to control it, and you don't find that price too spendy, then go for it.
Old 03-06-2013, 04:43 PM   #1873
mrbloink
Member#: 333058
That was my worry about it all. The stock front is 21mm and the only front one I can find is 24mm. For the rear I have found a 19, 20, 22, and 25. Not too sure on which rear to go with
Old 03-06-2013, 05:57 PM   #1874
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Most people who upgrade the RSB go with the 19mm STI bar. I don't know about the front because I hear more from people upgrading just the rear bar and leaving the front alone.
Old 03-06-2013, 06:07 PM   #1875
mrbloink
Member#: 333058
That's the same upgrade that I am running at the moment with the stock end links. At first it felt way stiffer however its been about 2 months now and tend to find it is still a little sloppy. I got it free since my buddy upgraded his bars on his 12 sti so I don't mind doing an upgrade again. Just not too sure what to go with for rear. Another friend runs 25 front and 22 rear in his wrx in the medium setting and really likes it. Just not too sure if I could compare how his feels to how mine would feel since the rest of his suspension is totally different
Anybody in SCIC-land taken possession of 2012 Impreza 2.0i yet? somebody else Southern California Impreza Club Forum -- SCIC 3 12-23-2015 04:34 AM
factory SS or aftermarket for 2012??? Myth21 Transmission (AT/MT) & Driveline 8 01-07-2012 11:18 AM
Has anyone test drive a 2012 Impreza yet? pRiMe DiReCtIvE General Community 25 11-28-2011 10:03 PM
Hybrid Impreza in the works for 2012? rsholland News & Rumors 43 03-12-2010 10:58 PM
