#101 |
Member Sales Rating: (39)
Member#: 208152
TXIC
Vehicle:2007 STI LTD #576 Urban Gray Metallic |
^ Do you not have the AOS plumbed back into the inlet? Or is this temporary to monitor blow-by...?
I, too have the ETS TMIC and the Crawford, but with a custom bracket made by the shop that built my motor. No clearance issues, but no FSTB, either.
#102 | |
Member Sales Rating: (23)
Member#: 42645
Vehicle:2007 STI BrenTuned Crystal Gray Metallic |
I'm also ruining an AMR Inlet now too. ![]() |
#103 | |
Member Sales Rating: (31)
Member#: 202958
Vehicle:2008 wrx |
i also never have the "very strong oil vapor fumes". this is on a high-hp setup but perhaps adding that filter at the end would help you if you have a desire for that design setup/eliminating the opportunity for blow-by to enter the intact tract. |
#104 | |
Member#: 42645
#105 | |
Vendor Sales Rating: (2)
Member#: 42075
SCIC
![]() Team Crawford
__________________
Crawford Performance Home to Ken Blocks Gymkhana 1 and Gymkhana 2 Home to the worlds fastest new age Subaru WRX STI To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Follow us on To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#106 |
Member Sales Rating: (19)
Member#: 179330
Vehicle:05 LGT Wgn 400whp PriceRocket |
Mine finally showed up in the mail today and will be getting installed in a few weeks when I am ripping into my engine bay again. I bought the tmic aplication for 02-07 sti's and am looking forward to installing it along side of my rotated 3076 and spearco top mount. I will update with photo's.
-Gary |
#107 | |
Member#: 202958
Vehicle:2008 wrx |
#108 | |
Member#: 279233
Vehicle:2008 WRX, Stage II OBP |
#109 | ||
Member#: 208152
TXIC
#110 | |
Member#: 42645
#111 |
Member#: 208152
TXIC
Oil level is consistent when not pushing the car hard (like at a track day), so not sure where I'd have a leak. Can't smell anything under the hood while running, it's out the exhaust. I think I've read of others experiencing the oil vapor smell, I just need to read up on it a bit.
#112 |
Member#: 42075
SCIC
If you are smelling it in the exhaust then you are burning oil in the combustion chamber which is exiting out the back of your car. This is common for a high mileage motor or one that is very loose for what ever reason. If the oil is going into your turbo faster than its draining out the bottom then that could cause the smell as well, this usually happens with rotated turbos that do not have a proper restrictor in the oil feed line.
__________________
#113 | |
Member#: 208152
TXIC
#114 | |
Member#: 42645
I also recently pulled my TMIC - it definitely smelled, but it was bone dry. ![]() |
#115 | |
Member#: 42075
SCIC
Team Crawford
__________________
#116 | |
Member#: 42075
SCIC
Team Crawford
__________________
#117 | |
Member#: 208152
TXIC
![]() That's why I never worried about it. I expect some consumption with the looser tolerances, but just no idea how much since I haven't been able to really measure it. Just wasn't expecting the oil vapor odor out the back end. Thanks for the feedback! |
#118 | |
Member#: 42645
#119 |
Member#: 208152
TXIC
Normally I'd agree with you, but I'm not burning any really noticeable amount of oil, and I've done 7 track days with this motor, using roughly 1/2-1 qt per day. Unless it starts creeping up to something excessive, I think I'm good. *crosses fingers and does a little dance*
#120 |
Member#: 74872
Vehicle:2006 STi White/Black |
I am so glad I did not buy the grimspeed AOS for my new 18Gxt sti build. I think I will do catch can(s) instead.
Which is the very best catch can system people? or is there an AOS that actually works. Should I just get the crawford and call it good? |
#121 | |
Member#: 42645
#122 |
Member#: 42075
SCIC
__________________
| Thread Tools | |
| Display Modes | |
| FS: Crawford AOS for TMIC - Brand New | jordanretro1223 | Engine/Power/Exhaust | 19 | 09-25-2011 07:36 PM |
| Crawford AOS, ARP studs, Grimmspeed, JDM STi Spec C 12L WATER TANKS in STOCK!! | IA Performance | Engine/Power/Exhaust | 8 | 04-24-2011 04:04 PM |
| FS (SC): Crawford AOS - New | rubberman | Engine/Power/Exhaust | 4 | 02-18-2010 08:55 AM |
| FS: Used Crawford AOS - FMIC version | kuldud | VIC Private Classifieds | 8 | 01-18-2010 11:32 AM |
| Cobb vs Hawk pads - reviews/ opinions? | Jeenyus | Brakes, Steering & Suspension | 7 | 06-22-2008 12:45 AM |
