Old 09-19-2012, 01:29 PM   #176
mke723
Member#: 219094
07 95L-RS Rally
custom OBS paint
did you get out on the 15th?
mke723 is offline   Reply With Quote
Old 09-21-2012, 09:00 PM   #177
mattruk
Member#: 245408
99 STI RA
I did mke723.
Made a few changes to the car before hand. Changed the intercooler, fuel set up, brake pads (Pagid RS29) and turbo (Billet 30).
Car was running fantastic and doing pretty well until a sudden steam bath called a end to the day. Turns out it was a split silicone hose that had been rubbing and eventually split. Cheap fix so plenty to look forward to over the winter.
Few pics and vids
mattruk is offline   Reply With Quote
Old 09-21-2012, 09:06 PM   #178
mattruk
Member#: 245408
99 STI RA
Old 09-21-2012, 09:15 PM   #179
mattruk
Member#: 245408
99 STI RA
Old 09-22-2012, 04:02 PM   #180
d357r0y
Member#: 200465
2005 92x times two
what was rubbing on there?
d357r0y is offline   Reply With Quote
Old 09-22-2012, 07:12 PM   #181
mattruk
Member#: 245408
99 STI RA
Drivers side cam cover buddy at the top.
Guessing as the system pressurized and got hot it weakened the cover and then the cam pulley tore through the cover and ate my hose
Quick easy fix thankfully.
Old 09-23-2012, 11:13 PM   #182
mke723
Member#: 219094
07 95L-RS Rally
custom OBS paint
that unfortunate. But its easy fix. now u have all winter to check and re-check all the little things, like hose clearances. thanks for the vids and update. Your car sounds like a beast. have you a chance to check out a set of sub frames from www.TSSFAB.us, lighter, stronger, custom options. give them a look. a few places sell them in their catalog , but for almost twice as much as you can get them direct.
Old 09-24-2012, 05:37 PM   #183
patrickrobare
Member#: 324177
2012 impreza WRX
pearl blue
AMAZING!!!!!!!!!!!!!!! you give me hope :')
patrickrobare is offline   Reply With Quote
Old 09-25-2012, 05:55 PM   #184
mattruk
Member#: 245408
99 STI RA
Not yet mke
Handling set up will be looked at over the winter. A friend does have what you mentioned on his car so I'm kinda waiting from some feedback from him once his car is up and running.
Old 10-07-2012, 04:06 PM   #185
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Awesome project brother! Keep up the good work man! And thank you for all of the help!
Team Scream is offline   Reply With Quote
Old 10-28-2012, 11:43 AM   #186
gu5
Member#: 82623
my06 spec-c type ra
Originally Posted by mattruk View Post
Not yet mke
That must be me Matt ....not long to go
gu5 is offline   Reply With Quote
Old 02-27-2013, 01:51 AM   #187
maggion31
Member#: 340753
2012 STI + 2006 WRX
Ice Silver + WRB
Hey bud, absolutely amazing build. Great job building such a supreme car and not half a**ing anything. One question though, how long did the planing/research phase of this car take. Did you follow all of your plans or have to sacrifice any because of financial or difficult install obstacles? Good luck in your future events.
maggion31 is offline   Reply With Quote
Old 02-27-2013, 05:00 PM   #188
mattruk
Member#: 245408
99 STI RA
Thanks.
Research just involved what I wanted and what others that were at a similar spec were using. Things changed along the way and continue to change to this date. I've just swapped coilovers to KW v3 Clubsports. Changed turbo from a billet 35 to a 30. They are constantly a work in progress and motorsport never stands still for long so there are always improvements coming out. They are hard work and you sacrifice a lot but once in such a car it's like an ex girlfriend. You forget all the bad and remember only the good
There adrenaline rush is something else.
You live once, might as well follow the dream
Old 07-29-2013, 03:45 PM   #189
mantasv
Member#: 363110
Thanks.
Any news?
Just read everything through! I love so honest project threads.
mantasv is offline   Reply With Quote
Old 07-31-2013, 07:13 PM   #190
mattruk
Member#: 245408
99 STI RA
Thanks dude. Glad you like it.
Phew, updates......where to begin..
In Dec 2012 I was getting ready for a winter/off season of trackdays and tuition to improve my driving skills and decided to have the car mapped for a bit more power.
Sadly my engine let go at 570bhp on the dyno even though others running the same spec are getting good use out of theirs at 700+. Turns out none of the tolerances etc were checked during the build Blew the HG but in such a way it destroyed the block, heads, pistons, 1 rod and the rad. Expensive fix
Having missed all the tuition and trackdays I decided to put a standard JDM v9 bottom end in with STi 8 UK heads just to get back out there and have some fun. Ran it at safe power 360bhp to get some reliability but my bad luck struck again with piston ringland failure after just 2 events.
It's just had a brand new 2.1 built and had a running in map put on it yesterday. 1 bar of boost limited to 5500 revs. Will put some miles on it via the dyno over the next couple of weeks and then drop the oil and have a proper map done. Aiming at 550 to keep things on the safe side.
Fingers crossed this one lasts a little longer than the previous 2. Eventually it will have another 2.35 in it and get 700+ again but cash flow dictates when that will happen.
Old 08-08-2013, 04:56 AM   #191
mantasv
Member#: 363110
No luck.
Why you want 700? I know big power is a good thing, but honestly, it should be very hard to keep it on track.
I drive 300hp GD WRX and it's a lot! Skidding in 2gear in turns (city). waiting for a proper winter (snow) to get along with the 4wd drive. This is pretty new stuff for me.
But I really enjoy your project, and if Men needs 700hp it means he needs it. go for it.
Old 08-16-2013, 09:26 PM   #192
mattruk
Member#: 245408
99 STI RA
Well the new engine is ready
and running
new front end
Few small jobs to finish before mapping on the 28th and then a event to attend on the 31st.
3rd time lucky I hope
Old 08-19-2013, 09:52 PM   #193
cphelps1125
Member#: 365928
dude! that car is NUTS! def an amazing build. ::thumbs up::
cphelps1125 is offline   Reply With Quote
Old 08-30-2013, 12:21 PM   #194
LUMBERZACK
Member#: 340009
2007 STi
48W
So sweet! I love seeing running project cars!
LUMBERZACK is offline   Reply With Quote
Old 09-01-2013, 05:11 PM   #195
mattruk
Member#: 245408
99 STI RA
Thanks guys.
Had the car mapped last week and made 500.9/465 @ 1.75 bar. Happy enough with that as it's not overly stretching the new engine and plenty quick enough in a light car.
Took her out for the first event yesterday and done pretty well. Came 3rd in my class so very happy with that.
Few pics and a vid of my 2nd quickest lap. Excuse me talking to my car at the end I'm slightly nuts
Old 09-02-2013, 01:56 PM   #196
mantasv
Member#: 363110
congrats with the podium!
nice non-grippy start, shows the power and fast turbo spool, really nice.
couple questions - what tires and gearbox you're running in such events?
Old 09-02-2013, 03:51 PM   #197
mattruk
Member#: 245408
99 STI RA
In that video I was using Dunlop CR311 x10's. Tyre pressures cold were 27 front 25 rear.
Gearbox is a 2003 JDM 6 speed DCCD using 40% diff lock on that video
Old 09-03-2013, 02:44 AM   #198
mantasv
Member#: 363110
Do you train your skill besides running your impreza? I mean go-carting, PC car racing simulation games etc...
Old 09-03-2013, 07:42 AM   #199
mattruk
Member#: 245408
99 STI RA
Haha. No. I've been seriously stupid tbh.
I had never driven a car more than 140bhp and never driven on track before.
For some strange reason I thought it would be fun to build a race car. It scared the s**t out of me tbh. With all the issues I've had with that car I've still probably only had an hour actually driving it, and that's been over the last 18 months.
Driving tuition is definately on the to do list and I have a training day booked for the 20th Nov. hopefully I'll get a few tuition sessions in over the winter and actually learn how to drive it properly.
The car is definitely a lot more capable than I am at the moment.
Old 09-03-2013, 01:33 PM   #200
mantasv
Member#: 363110
If I hear well you're doing heel & toe for downshifts - that's good.
Braking points looks quite good as well.
Just the racing lines... But if you got only 1 hour of racing - you're doing very well.
And training racing lines - go carts are the best (price/performance).
of course PC racing simulators with a proper wheel are good as well (and way cheaper than go-carting).
Could recommend Live For Speed (not Need for speed, but Live...) and Richard Burns Rally.
Keep us posted, very nice build, racing and the story overall!
BR,
Mantas
New track car project! LargeOrangeFont Southern California Impreza Club Forum -- SCIC 5 11-09-2008 02:28 AM
L.I. NY- 1987 VW GTi Rally/Track car project imprezaf Private Vehicle 'For Sale' Classifieds 5 01-15-2006 10:43 PM
My New Impreza WRX project.. from the Uk Muddymudster Member's Car Gallery 42 04-20-2005 01:08 AM
In car video from the Subaru Track Day sponaugle North West Impreza Club Forum -- NWIC 6 10-30-2002 11:36 PM
Hmm some nice cars... how about this from the UK? MATTeL Member's Car Gallery 19 09-14-2002 02:34 PM
