Old 02-25-2013, 10:10 PM   #1
tjluke
Member#: 348283
Default super clean sleeper swap.
im looking into buying a bug eye wrx for 2500, clean everything is there minus the engine. i found a EJ25 auto on craigslist for 75.00, but its from a 97 legacy n/a. he pulled the engine cause its over heating. i did some research and have come to understand that all EJ blocks will bolt up to the trans and mount to the engine mounts as well. if this is true then the engine sounds golden, but idk if i can turbo,- fuel injection. i figured id buy them both and just swing by a junk yard and pull some sti parts such as the intake, turbo, injectors, ecu, fly wheel-clutch, and other parts. has any one heard of such a swap??????
all i know on the EJ25 is that it has a 160k, its from an 2.5 gt auto. it looks like it was turbo and not carb?????? any help????
i have built multiple engines, not sti but i have done american v8s, vw 2.0, and straight 6 jeeps, also Mercedes motors. im a tech at Mercedes Benz. i know a 75 dollar motor sounds a bit off the edge. im talking about using it as the building block to an engine to drop in after i rebuild it for turbo and add performance to as well. but where my question was at, is the block compatible for the proper sensors and what not.
tjluke is offline   Reply With Quote
Old 02-25-2013, 10:13 PM   #2
slayer44wagon
Member#: 300834
03 wrx wagon
Ummmmm....
slayer44wagon is offline   Reply With Quote
Old 02-25-2013, 10:29 PM   #3
tjluke
Member#: 348283
lol
Old 02-25-2013, 11:27 PM   #4
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
Subarus are basically legos.
That said, I'm going to save you about $3,000 and probably your marriage. Pass on both. Walk away, look back on this day and say "damn, glad I listened to those guys"
Old 02-26-2013, 12:52 PM   #5
bigolrig
Member#: 185347
2002 EVO3 bugeye wag
EG33 Swapped 2 dr RS
You would not want to boost a N/a 2.5. Sti swap it or put a 2.0 turbo back in it.
bigolrig is offline   Reply With Quote
Old 02-27-2013, 06:59 PM   #6
TyConway
Member#: 193189
2002 wrx
Thumbs up
why didn't anyone tell me this? lol
TyConway is offline   Reply With Quote
Old 02-27-2013, 10:28 PM   #7
tjluke
Member#: 348283
lol good for future notes in life, but right now im not any where near marriage lol i was thinking bout the eg33??? the boxer h6 engine found in the svx i found a running complete car cheap. and thoughts. i figured id do a stand alone system and build the motor so i can run it all motor. i think it would be a very unique wrx where i live. all motor i can hear it all ready.
Old 03-04-2013, 07:57 PM   #8
geriko
Member#: 349049
geriko is offline   Reply With Quote
Old 03-04-2013, 08:29 PM   #9
TurboLag23
Member#: 347343
2004 Outback H6
2008 Acura TL
As someone who's never actually modded a car before (but has definitely wanted to), walk the hell away.
TurboLag23 is offline   Reply With Quote
Old 03-08-2013, 01:12 PM   #10
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Not a bad choice honestly as long as you do your research and know all the pros and cons. There are people that have already done this and are enjoying the H6.
If I was going to do this swap I would buy a NA subie which is cheaper to insure
geronimo81 is offline   Reply With Quote
Old 03-10-2013, 10:55 PM   #11
wrxoutback
Member#: 349061
2002 impreza wrx
06 subaru LGT
were is this junk yard i want to swing by and get some sti parts???
wrxoutback is offline   Reply With Quote
