Old 02-22-2013, 10:55 AM   #451
AFP520
Member#: 102932
2013 WRX PRM Sedan
Plasma Blue Pearl
Hey guys,
Haven't had my car long but will be doing this soon. I wanted to let you guys know that you might be able to add your own dimmer switch to the gauges by using a potentiometer. http://www.radioshack.com/product/in...ductId=2102789
*NOTE* This should only be used on your illumination wire!!!! I have no idea what could happen to your gauges if you put it on another wire. Make sure you are 100% positive you hook it up to the correct one! It works by reducing the amount of power that flows to the lighting on the gauge. It's pretty adjustable, so should allow you to find that perfect spot. I had 2 Autometer C2 gauges both hooked up at the same time to the same one and they worked fine for months. Worth a shot for the few bucks IMO. Definitely has helped me avoid unnecessary attention when cops were following me. Those gauges are extremely bright when fully lit.
AFP520 is offline   Reply With Quote
Old 02-23-2013, 10:54 PM   #452
Bradrcr
Member#: 276382
2005 SaaBeeru
Just curious, but how do you wire up a potentiometer? They all seem to have 3 terminals but no labels?
Bradrcr is offline   Reply With Quote
Old 02-25-2013, 07:51 AM   #453
AFP520
Member#: 102932
2013 WRX PRM Sedan
Plasma Blue Pearl
I would start by buying yourself a test light. It really helps when it comes to wiring things up.
I'm pretty sure only 2 of the terminals get used. You would put this between the illumination wire that runs from your car to your gauges. Turning it will adjust the amount of electrical flow to the lighting on the gauge. Again, some might act funny because I'm not really sure how every manufacturer of gauges does their lighting. I can only attest that I've had the 2 autometer gauges hooked up and I was able to adjust the brightness using a potentiometer.
Old 02-25-2013, 08:04 AM   #454
gsrcrxsi
Member#: 236952
2010 WRX
Spark Silver
Pots with 3 terminal:
1. Input
2. Variable output
3. Fixed output
If you hook up 1 and 2, varying the pot will vary resistance (and hence voltage. If you hook up 1 and 3, you will have fixed resistance and varying the pot won't do anything.
gsrcrxsi is online now   Reply With Quote
Old 02-27-2013, 10:08 PM   #455
Apedz215
Member#: 328682
Looks good
Apedz215 is offline   Reply With Quote
Old 03-10-2013, 09:54 PM   #456
subi400
Member#: 216984
1996 Impreza outback
Green
Been looking at getting a Defi Racer series white LID oil pressure gauge for my gf8 wagon. Finally pulled the trigger since I want a gauge that is going to work perfectly and be accurate. From what I have read, the Defi gauges are worth money in the long run
My friend has done some wiring but I have not so this thread should help a bunch when I finally get to instal the gauge and such. I am putting the oil pressure sensor unit where the OEM one is under the alternator. Not sure where I am putting the gauge inside the car yet. Will have some time to think about it...
So, I need to buy 1 or 2 fuse taps? I have an AutoZone here so I probably will get them there. Also have some heat shrink wrap some where. Will be posting some pictures if I can and asking questions if and when I have some.
Old 03-11-2013, 01:05 AM   #457
Yeeman19
Member#: 8
Chapter/Region: HIIC
Ice Silver Metallic
Great install guide It was a big help installing my STRI boost gauge and control button. Feeding the wire through the firewall was a lot easier on my bugeye
Yeeman19 is offline   Reply With Quote
Old 03-11-2013, 08:14 PM   #458
Apedz215
Member#: 328682
So at idle my oil pressure gauge also defi is reading around 20, then steady drive is 80, is this common
Old 03-12-2013, 08:38 AM   #459
jaxx4k
Member#: 232010
2013 STI hatch
good read.. thanks for the info.
jaxx4k is offline   Reply With Quote
Old 03-12-2013, 11:31 AM   #460
kakarot09
Member#: 182375
08 Sti
Wrbm
Yep. The pump pressure raises with rpm and generally speaking the rule of thumb is you want it to be at least 10 psi per 1000 rpms. So at 7000 rpm you want at least 70 psi.
kakarot09 is offline   Reply With Quote
Old 03-12-2013, 12:51 PM   #461
Jay C
Member#: 318234
Originally Posted by MancinosUn4gvn View Post
Installed this today, I usually keep my headlights on, and my brightness on the gauges up, I've noticed since the headlights are on the gauge dims, is there anyway to hook up so the gauge doesn't dim, and is at full brightness at all times?
I was having the same issue, I found a thread on iwsti that said if you just disconnect the white illumination wire completely they won't dim. Just gave it a shot today and it works perfectly. Gauges are at full brightness with lights on and off.
http://www.iwsti.com/forums/gr-inter...e-install.html
Jay C is offline   Reply With Quote
Old 03-12-2013, 02:08 PM   #462
Elky
Member#: 303906
2011 WRX Sedan
Spark Silver Metalic
Wanted to chime in and say thanks for this thread, it helped me a lot.
Elky is online now   Reply With Quote
Old 03-15-2013, 11:24 PM   #463
SATSTI
Member#: 341814
2013 STI
Yep....I'll be using this thread soon as well. Good job OP.
SATSTI is offline   Reply With Quote
Old 03-16-2013, 03:39 PM   #464
Beck2013STI
Member#: 344006
2013 WRX STI Sedan
Awesome write-up! Thanks a lot.
Beck2013STI is online now   Reply With Quote
Old 03-23-2013, 10:09 PM   #465
crabsandwich
Member#: 337442
2013 WRX Limited 5DR
So when using these add a circuit fuse taps, I see there are two slots to add fuses. Am I correct in saying that the fuse you removed goes into the first slot, and a new fuse (i.e. 10 amp) does in the second slot?
crabsandwich is offline   Reply With Quote
Old 03-24-2013, 02:37 AM   #466
kizzer505
Member#: 168897
2009 WRX
Yes but it's a small one. Mine are 3.5 amp.
kizzer505 is offline   Reply With Quote
Old 03-24-2013, 09:18 AM   #467
crabsandwich
Member#: 337442
Does it matter using a smaller amp fuse(i.e. 3.5) versus using a slightly larger fuse (10 amp) to power the gauge?
Old 03-24-2013, 07:39 PM   #468
S1CkWrx
Member#: 325249
2012 wrx
dgm
subbd
S1CkWrx is offline   Reply With Quote
Old 03-28-2013, 01:47 PM   #469
Jellynuts
Member#: 305774
2007 STi
I installed my gauges last week into my GD and this DIY was very helpful. Thank you very much, Jon!
PS. What are you driving these days?
Jellynuts is offline   Reply With Quote
Old 03-29-2013, 08:03 PM   #470
peekeesh
Member#: 316476
12 WRX
Quick question, how does your SMY clustermaker fits? Does it have gaps along the edges where it meets the dash?
mine has gaps and it isn't snug fit.
peekeesh is offline   Reply With Quote
Old 03-29-2013, 08:35 PM   #471
nmlittlebigman
Member#: 321409
2011 WRX STi Sedan
WRB Stage II T.P. tuned
^^^^ Mine's the same way on just one side. I forgot all about it. Other than that I really like the setup.
nmlittlebigman is online now   Reply With Quote
Old 03-29-2013, 10:45 PM   #472
peekeesh
Member#: 316476
12 WRX
Does your's wobble or is it tight fit?
thanks for your reply...
Old 03-30-2013, 07:54 AM   #473
Jay C
Member#: 318234
Same issue on mine. I'm glad I bought it used and didn't pay full price.
Old 03-31-2013, 02:37 AM   #474
TryHonesty
Member#: 346323
2013 WRX
Just installed this on my 2013 WRX. It's a snug fit for me (the cluster).
TryHonesty is offline   Reply With Quote
Old 03-31-2013, 03:28 AM   #475
DearDiaryJackpot
Member#: 343041
2013 wrx limited
metallic silver
This is my next project. Maybe for my Bd but it will happen.
DearDiaryJackpot is online now   Reply With Quote
NOAH is a tool....and I can proove it (Post here if you want points!) madcatz Mid West Subaru Owners Club Forum -- MWSOC 14 05-02-2011 06:47 PM
Tell us how Subiefest went when you get back tonight & pics if you have them KB'izzle Southern California Impreza Club Forum -- SCIC 361 10-30-2009 07:57 PM
ssr professors, post pics if you have them streko Member's Car Gallery 2 07-22-2004 04:27 PM
Anyone put WRX stock rims on an RS? Pics if you have them... Samirr76 Interior & Exterior Modification 2 07-21-2001 03:15 AM
Message Board Statistics All times are GMT -4. The time now is 11:15 AM.
