Old 02-25-2013, 03:16 PM   #1
BoomWrx
Member#: 327371
2007 WRX
BLEEEK with some sparkles
Default Mid-Pipe not fitting correctly??
Hello. I have a 2007 wrx. I recently bought a used magnaflow catback exhaust. i am running a hks downpipe atm. When I installed the catback, the mid pipe was resting underneath he car and it seems like the mid pipe needs to be bent. The whole car vibrates due to this. The mid pipe is 3" and has a flew right before the down pipe flange. Should I try bending the pipe or denting it or what?
BoomWrx is offline   Reply With Quote
Old 02-25-2013, 06:40 PM   #2
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
Post pictures.
scoobasaurusrex is offline   Reply With Quote
Old 02-25-2013, 07:13 PM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
not all exhaust systems bolt together..
but pictures would help.
Old 02-26-2013, 12:52 AM   #4
Andrewxxcarlson
Member#: 316415
2006 WRX
This.
Old 02-26-2013, 01:08 AM   #5
BoomWrx
Member#: 327371
2007 WRX
here is a picture of the mid pipe. I do not any pictures of it mounted atm. but it hits right it the middle. its literally rubbing and bent on the car.
Old 02-26-2013, 01:47 AM   #6
ditch the hks dp...they are garbage
and sounds like ya got the wrong pipe
Old 02-26-2013, 07:03 AM   #7
scott06sti
Member#: 320340
2006 Subaru STI
hks down pipe works great for an externial waste gate, but will not work as good on a internial waste gate because of the way they are made. The mid pipe doesnt look like it has enough of a bend if you know how to weld then fix it your self not worth paying someone to fix, you will spend to much money for someone else to do this. Cheaper to buy a better one already to the correct shape.
scott06sti is offline   Reply With Quote
Old 02-26-2013, 02:25 PM   #8
yeah...they are great right up to the time they rust through and fall apart
just great
they are GARBAGE
and that pipe may just need a non n0000b to fit it
Old 02-26-2013, 06:06 PM   #9
BoomWrx
Member#: 327371
2007 WRX
just great
they are GARBAGE
I've actually installed many exhausts..
Old 02-26-2013, 08:28 PM   #10
scoobasaurusrex
Member#: 255114
2007 wrb wrx wagon
93oct vf43 ewg
Post pictures of it mounted.
Old 02-27-2013, 02:55 AM   #11
then what's the problem??
Old 02-28-2013, 12:45 AM   #12
BoomWrx
Member#: 327371
2007 WRX
i'm not sure if the mid pipe is made for my car or not. I will install it this weekend and post pictures asap.
Old 02-28-2013, 01:18 AM   #13
BLUEWRX04STi
Member#: 325640
2004 STi
Doesn't look like its made for it. Try going with a whole turboback system, that way you know every piece fits. I have a Tanabe downpipe and a blitz turbo back. Coincidently fit perfectly.
BLUEWRX04STi is offline   Reply With Quote
