Old 02-21-2013, 08:12 PM   #2651
senna1a
Member#: 231943
2011 Sti
& '03 Bugeye
Originally Posted by abrumlev View Post
Yazel and myself are registered for the Wilimington Match Tour in early April....anyone else going? The class is a whopping 4 of us right now.
I'm one of the 4 registered and planning to run, but I've just started on a coilover setup last week. To top it off, I'm out of the country until March 10th, so if anything does not stay on plan, then I may have to jump into another car/class.
senna1a is offline   Reply With Quote
Old 02-21-2013, 08:39 PM   #2652
yazel
Member#: 215344
Originally Posted by WRX8XB View Post
don't forget stiff suspension and camber as well.
T3hClap.com how to fit 9.5s on a GD
That is pretty strait forward though. I know a few guys myself that are running the 17x9.5" +38 RPF1 on fixed perch strut GD WRX's/STi's with no problems. They fit quite well and don't rub with 245's and 255's (normal rear camber too).
Other than the 3-5mm spacer up front, the rear just needs a roll and stiffer than stock springs to avoid rubbing depending on your tire size. With our 245 limit in STU, rubbing isn't a problem for even the lowest of cars with a fair spring rate in the back. Normal rear camber (-1.5 to -2.0) is fine as well.
Originally Posted by CircuitRacer View Post
Stumbled upon yazel's group buy. From what I've seen aside from rolliing the fenders and 5mm spacers up front and recommending extended wheel studs, it should fit rather nicely under an '04 STi's wheel wells.
That will be fine. We will discuss your setup and fitment further via PM.
yazel is offline   Reply With Quote
Old 02-21-2013, 08:42 PM   #2653
yazel
Member#: 215344
You should definitely run your STi. We will be on a new suspension setup as well and will not have much time if at all to test beforehand.
Should be a fun weekend. Wilmington is the best site I've ever been to. It is 2 or 3 times larger than Toledo's site!
Old 02-22-2013, 10:45 AM   #2654
senna1a
Member#: 231943
2011 Sti
& '03 Bugeye
I'm looking forward to it!
PS - Anyone considering the NJ Pro should register before it fills up (likely today)!
Old 02-22-2013, 10:53 AM   #2655
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
Already signed up, looks like STU has 4 so far. Come on kids, let's get a full class!
piknockout is offline   Reply With Quote
Old 02-22-2013, 10:14 PM   #2656
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
We should be okay. Though, if the clutch goes, I think I will pass on the DC Pro
Pretty shocked that STU > STX.
I need to get some anti-BFG stickers made before then though
Butt Dyno is offline   Reply With Quote
Old 02-26-2013, 01:18 PM   #2657
yazel
Member#: 215344
Looks like we will have a great class at the Wilmington Match Tour in STU. Beyond psyched.
Old 02-26-2013, 02:28 PM   #2658
piknockout
Member#: 192173
I'm actually half tempted to go. Anyone need a roommate?
I forget, is it concrete or asphalt?
Old 02-26-2013, 04:11 PM   #2659
yazel
Member#: 215344
The pad we will be on for the Tour is concrete. They actually have an asphalt area used for smaller local region events as well.
Old 02-26-2013, 04:20 PM   #2660
piknockout
Member#: 192173
Sounds like it might be a good site to do some preliminary BFG vs. Dunlop testing on concrete. Hmm...
Old 02-26-2013, 04:30 PM   #2661
yazel
Member#: 215344
Definitely a good site. Probably a decent drive for you, but not horrible I guess compared to Blythville or Lincoln.
Wilmington: (paddock area for Tour's is the area the local region uses for smaller events and can still produce 60-70 second courses...)
Old 02-26-2013, 04:37 PM   #2662
em99sport
Member#: 172670
2011 STI 5-door
Damn, that's BIG. I wish I could make it.
em99sport is offline   Reply With Quote
Old 02-26-2013, 04:47 PM   #2663
piknockout
Member#: 192173
Looks like about 8 hours, not that bad at all. Fairly easy drive for a Tour...and might be worth it for the two free BFG's.
Old 02-26-2013, 04:59 PM   #2664
yazel
Member#: 215344
confidence... this one has it.
It will be a fun weekend.
Old 02-26-2013, 07:30 PM   #2665
Butt Dyno
Member#: 17301
is the "dark side"
Match tour though... so there is some PAX involved. Not great for a street tire car on concrete, at least in terms of the challenge. But as long as the class is fun. Hrm.
There's also a Hershey double that weekend.
Old 02-28-2013, 11:49 AM   #2666
piknockout
Member#: 192173
You get tires for a class win I believe, so PAX is irrelevant when it comes to the contingency. I agree, I would prefer it to be an NT, but it still might be worth it. If I don't go, you'll likely see me at Hershey.
STU currently has 7 competitors. I'm guessing that Shane won't go, so let me know if you want to co-drive John...would be an easier early season trip than Dixie was last year.
And I'm kind of lazy and have a poor memory: did the Killer B oil pickup definitively become legal for this season? If so, I'll be installing mine soon. Thanks.
Old 02-28-2013, 12:32 PM   #2667
UWMechEngr
Member#: 193756
2014 BRZ
#75 STX
Yup, pickups can be modified or replaced now.
UWMechEngr is offline   Reply With Quote
Old 02-28-2013, 12:55 PM   #2668
piknockout
Member#: 192173
I remember that they could be, but I seem to remember that the initial wording would have made the Killer B illegal due to the pickup location or something?
Old 02-28-2013, 01:10 PM   #2669
yazel
Member#: 215344
Nope, it is fine. ANY pickup is legal.
Old 02-28-2013, 01:24 PM   #2670
piknockout
Member#: 192173
Thanks for helping me be lazy, I guess I'll be installing that sometime soon.
Old 02-28-2013, 05:29 PM   #2671
yazel
Member#: 215344
No problem, I am doing the same soon I believe.
Old 02-28-2013, 08:57 PM   #2672
em99sport
Member#: 172670
2011 STI 5-door
It's on my list as well, along with engine mounts.
Old 03-01-2013, 08:33 AM   #2673
piknockout
Member#: 192173
I guess we could make a Wilmington Match Tour thread specifically, but once again I'm too lazy. Anyone have suggestions for hotels in the area? Looks like there's a good chance that Shane and I will be going out there.
Old 03-01-2013, 09:29 AM   #2674
yazel
Member#: 215344
The town of Wilmington itself isn't all that big. Everything is pretty close to the site so you should be fine with any decent hotels you find online.
Old 03-01-2013, 09:50 AM   #2675
piknockout
Member#: 192173
Well that narrows it down.
Air Force Guys Check-in (other branches welcome) joosrsx Off-Topic 293 05-01-2010 10:36 PM
northwest connecticut guys check in 09wrxtorrington New England Impreza Club Forum -- NESIC 6 08-12-2009 02:46 PM
New Guy Checking In mmormino Newbies & FAQs 3 02-14-2009 12:07 PM
New guy checking in amfj231 Newbies & FAQs 7 12-22-2008 09:13 PM
