Go Back   NASIOC > NASIOC Technical > Factory 2.0L Turbo Powertrain
Old 02-28-2013, 11:45 PM   #1
Mariolemite
Member#: 341616
2004 WRX
Default Constant clicking under shifter when driving
04 WRX
So a little while ago I got in my car, started it up & started driving & I noticed as soon as I started to move I heard a slow clicking sound from underneath my shifter. As I drove faster, the clicking got faster. As I came to a stop, it slowed down and stopped. Is there something stuck to my driveshaft or what? I have no idea what this could be. Someone please help!
Mariolemite is offline   Reply With Quote
Old 03-01-2013, 01:46 AM   #2
PhotoREX
Member#: 180193
2002 Impreza WRX Wag
Maybe you ran something over. Check your tranny fluid level on flat ground. 5 speed or auto? Also this could be your loose shifter bushings jut vibrating. My 02 wrx always did it in 3rd gear
PhotoREX is online now   Reply With Quote
Old 03-01-2013, 02:28 AM   #3
OK Houston
we have an Uncle
clicking usually means bad things
if it isnt something simple like a rock or something stuck in a tire.....it may be a broken gear in the transmission....'clicking' is the tell
Old 03-01-2013, 10:02 AM   #4
Mariolemite
Member#: 341616
2004 WRX
It's a 5 speed. My transmission levels are where they should be. I don't think my gears are messed up cause it still runs strong. Like it literally sounds like when you would put a playing card on the spoke of your bicycle wheel.
Old 03-01-2013, 11:38 AM   #5
Mariolemite
Member#: 341616
2004 WRX
So I found out the problem. The idiot who owned the car before me had set up under glow & zipties were hitting the driveshaft. Lol. Thanks for the help though
Old 03-01-2013, 11:49 AM   #6
jdmforrealz
Member#: 345274
Probably not the answer you are going to want to hear but could be anything from a CV axle to an internal issue within the transmission. I would start out by checking for rocks in the tires as thats what happened to me and I could only hear it with my window down driving between buildings.
jdmforrealz is offline   Reply With Quote
Old 03-01-2013, 11:50 AM   #7
jdmforrealz
Member#: 345274
I didnt read your most recent post that you fixed the problem, glad to hear ! Cheers.
Message Board Statistics All times are GMT -4. The time now is 12:04 AM.
