Old 02-25-2013, 07:20 PM   #1
RussSTI
Member#: 334177
2007 STI
Default Banjo Bolt how tight
So lately i was dealing with a p0021 code so i decided to take out my ocv solenoid and clean the heck out of it along with the banjo bolt that sits right next to it.
Now so far check light has been gone been riding for 50 miles and still clear. Now my problem is an oil leak around the banjo bolt area.
My Question is how tight am i suppose to tighten that bolt or is it suppose to sit in a certain position for proper oil flow through that hole? Dont want anymore oil blockage or starvation.
RussSTI is offline   Reply With Quote
Old 02-25-2013, 07:52 PM   #2
Wicked Innovation
Member#: 265606
did you replace the crush washers?
Wicked Innovation is offline   Reply With Quote
Old 02-26-2013, 12:55 PM   #3
tabKola
Member#: 297591
You tighten it enough to crush the washer just like an oil drain plug. Position doesn't matter.
tabKola is offline   Reply With Quote
Old 02-26-2013, 12:56 PM   #4
RussSTI
Member#: 334177
2007 STI
the banjo bolt near the OCV (Driver Side) didnt have any crush washers. The ones on on the turbo side does.
Old 02-27-2013, 02:38 AM   #5
aboothman
Member#: 127745
06 WRX 30r 6 speed
99L EJ255 6 Speed
There IS a torque spec. Don't have my FSM handy but it is around 19ft/lb IIRC
Old 03-01-2013, 04:30 AM   #6
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
If you're throwing codes... you have bigger problems.
DHRDAN is offline   Reply With Quote
Old 03-01-2013, 12:27 PM   #7
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
They should.
Old 04-08-2013, 08:38 PM   #8
napster
Member#: 352829
Im new to the wrx scene. I am having a problem with the P0021 code turning on and off. Anyone have pictures of where this banjo bolf and OCV thing is at? I have googled for hours.
napster is offline   Reply With Quote
Old 04-08-2013, 10:54 PM   #9
OK Houston
we have an Uncle
ya know...i have looked and LOOKED for that torque spec and could never find it....one of the few things that i have never found printed
post it up if you can find it
Old 04-08-2013, 10:55 PM   #10
OK Houston
we have an Uncle
Click to View Search Results for p0021 subaru - Google Search p0021 subaru - Google Search
Old 04-09-2013, 01:07 AM   #11
dead_eye
Member#: 308265
2008 WRX
thought i had an answer...
Last edited by dead_eye; 04-09-2013 at 01:09 AM. Reason: thought i had an answer...
dead_eye is offline   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 01:42 AM.
