#9601 |
Member#: 331636
Tri-State
Vehicle:09 impreza paprika |
#9602 | |
Member#: 146287
BAIC
Vehicle:2009 Impreza 2.5i 5D Sunlight Gold Opal |
T6 is designed for Diesel engines, but it works extremely well in our gas engines. |
#9603 |
Member#: 253642
NESIC
Vehicle:2008 Impreza 2.5i SSM |
I bought the catback from my friend for cheap.
I'm only going to be using the Y pipe/ axelback and I will be cutting off the resonator and welding it onto my current setup. Only reason why I'm not going to just bolt it up is because its 3 inches. I want to keep the 2.25 setup i have now. Should change the sound a lot and make it deeper. |
#9604 | |
Member#: 331636
Tri-State
#9605 |
Member#: 346087
Vehicle:2008 impreza 2.5i gray |
hey was wondering if you found any mods worth the time or effort yet looking to upgrade mine and im kinda stuck on whare to start any help is apreciated, and BTW going for performance not look. and yes i know if i want power like a wrx i should get a wrx but pockets arn't that deep and this is what i have so i would like to work with this so thank you for any help you can give me greatly appreciated
#9606 | |
Member#: 301179
BAIC
Vehicle:2009 Outback Sport Sage Green Metallic |
![]() http://forums.nasioc.com/forums/show....php?t=2473124 Last edited by theoutbackdream; 03-02-2013 at 01:10 PM. |
#9607 |
Member#: 146287
BAIC
Rear Sway Bar
Top of the list. Also, don't underestimate the usefulness of a good set of tires. |
#9608 | |
Member#: 293006
SCIC
Vehicle:2010 Impreza 2.5i Newport Blue |
Tech works engineering makes EL headers, Delta has cams/springs/retainers ull want 1000-1500 grind, look at hybrid sticky for ur intake, hfc/2.25 catback, contact STiMikey for a open source tune (via tactrix cable/rom raider, n I'm sure that would put a smile on ur face. Disclaimer : I'm pretty sure u can get away with cheaper EL headers ie: obx, Cobb, CNT. This is what my setup would be given the budget. Throw a rear sway bar/endlinks on if u haven't yet. K I think that's enough info from me now go do ur research n read then read some more. |
#9609 |
Member#: 293006
SCIC
#9610 |
Member#: 249696
NESIC
Vehicle:2010 Outback Sport Black |
Anyone looking into the Shell Rotella T6 oil, here's a good deal: http://slickdeals.net/permadeal/9050...etic-motor-oil
#9611 |
Member#: 331636
Tri-State
Some how got a test pipe welded in today for $60! Tuning ASAP now.
#9612 |
Member#: 304055
Vehicle:2008 Impreza 2.5i Lighting Red |
Cheapest coils out there?
#9613 |
Member#: 262503
MWSOC
Vehicle:2008 Impreza 2.5i |
#9614 | |
Member#: 304055
I'm looking for adjustable height and stiff so i don't have to dial in every time i have stuff in the car. If I had the cash I'd put it on bags with an e-level system. |
#9615 | |
Member#: 304055
#9616 |
Member#: 146287
BAIC
Cheap coils are fail.
Get some after market struts. If you really want height adjustability, get the Ground Control kit. |
#9617 |
Member#: 293006
SCIC
#9618 |
Member#: 262503
MWSOC
#9619 | |
Member#: 304055
#9620 |
Member#: 262503
MWSOC
Depends. If you want coils just to say you have coils then that's a fail in itself. You are looking at $1,500+ for good coils. Then add your brutal salt filled winters in Canada and plan on replacing them in a few years.
OR, get quality struts and springs for the same look and ride quality... |
#9621 | |
Member#: 304055
Spending 1500 on a nice setup just to have it replaced due to salt and winter damage doesn't sound like fun. Different story if I lived in Florida. |
#9622 |
Member#: 290211
MAIC
Vehicle:2009 impreza 2.5i SSM |
How much would i be looking at spending on A descent Strut/spring combo? I'm looking to order either tomorrow or Monday. And what springs and what struts are you guys running and happy with. Thanks
#9623 |
Member#: 290211
MAIC
And I do want to have a noticeable drop stock height sucks!
#9624 |
Member#: 262503
MWSOC
Konis for anywhere between $6-800 depending where you get them. Then springs are $200 give or take.
#9625 |
Member#: 290211
MAIC
| Thread Tools | |
| Display Modes | |
| 08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 7 | 03-24-2012 02:14 PM |
| Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
| 08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
| Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
| 08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
