Old 03-01-2013, 05:38 PM   #1
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
Default camshaft position sensor gap?
I put an EJ257 into my 02 WRX (using the WRX harness) and put a camshaft position sensor bracket on, in order for my CPS to be mounted and utilized.
I'm getting a code for "camshaft position sensor bank one" with 1 and 3 cylinders misfiring.
I believe the air gap between the CPS and the Camshaft is too large, and need to know the measurement that I have to adjust it to.
Anyone know the specs?
scoobynoobEMT is offline   Reply With Quote
Old 03-02-2013, 07:58 PM   #2
scoobynoobEMT
Member#: 199206
anyone..?
Old 03-03-2013, 04:38 PM   #3
scoobynoobEMT
Member#: 199206
I figured it out. Thanks for all the help.
Old 03-12-2013, 04:24 PM   #4
BrandonDrums
Member#: 118630
2005 Wrx wagon
Red
Hey man, I'm having the same issue. I would have replied earlier but have been traveling since you posted.
What did you end up doing?
BrandonDrums is offline   Reply With Quote
Old 03-12-2013, 04:27 PM   #5
scoobynoobEMT
Member#: 199206
I used a feeler gauge to match the gap from the ej20 to the ej257. That didn't work. I read about putting a 1/16th inch washer in between the sensor and bracket and I haven't thrown the code since.
I do get random misfires until the coolant reaches 180* though. Not sure if it is because of the sensor..
Old 03-18-2013, 02:33 AM   #6
Wraith646
Member#: 311865
2005 Subaru
just to help --- you gap is just a hair to far that is the miss fire at warm-up
Wraith646 is offline   Reply With Quote
Old 03-18-2013, 10:20 PM   #7
scoobynoobEMT
Member#: 199206
I've tried adjusting it closer and farther with a screwdriver while it's misfiring. Nothing works.
Old 05-30-2013, 12:20 PM   #8
Wraith646
Member#: 311865
2005 Subaru
What year 2.5 ar you using?
Old 05-31-2013, 12:17 AM   #9
05rs25
Member#: 192375
2000 2.5rs Coupe
Did u swap the cam gear from your ej205 to the ej257?
05rs25 is offline   Reply With Quote
Old 06-01-2013, 08:09 AM   #10
tja1618
Member#: 181995
2003 WRX
I'm heading down this same route (Ej257 with no AVCS) and would certainly like to avoid misfires. Can anyone else chime in about the mounting of the cam sensor?
tja1618 is offline   Reply With Quote
Old 06-02-2013, 08:44 PM   #11
Supraru
Member#: 23313
99' 2.5Rs
black
I also ran the 1/16 washer on the cam sensor and had no issues again. I did however seem to have one glitch with it. I had a 6 puck act clutch and occasionally would get to comfortable with it and stall. If I tried to fire it right back up it would just crank and it occasionally popped the code. I found if I stalled and turned the key fully off then back on it was good. Just a heads up for anyone if it happens to you.
Supraru is offline   Reply With Quote
Old 01-26-2015, 06:18 PM   #12
Dr. octagon
Member#: 171127
2015 Subaru
I have been battling this for longer than I care to admit.
Tired of the car dying at slow roll rpm.
What is the inner diameter of the washer.
I over think things I will admit, buy I can not find 1/16th washer. Home depot and lowes don't carry it....say it's too small.
Old 01-29-2015, 11:30 AM   #13
Que_mo
Member#: 410394
1998 impreza l
red
sandpaper
Que_mo is offline   Reply With Quote
Old 01-29-2015, 11:31 AM   #14
Dr. octagon
Member#: 171127
2015 Subaru
Originally Posted by Que_mo View Post
sandpaper
Please..........feel free to expand upon your statement.
Old 02-04-2015, 02:48 PM   #15
topfuelman
Member#: 140036
Default sandpaper
Just flat sand the washer down to the thickness you require
topfuelman is offline   Reply With Quote
Old 02-04-2015, 03:24 PM   #16
Dr. octagon
Member#: 171127
2015 Subaru
Thank you for the response
Old 02-05-2015, 04:31 PM   #17
skatesfobia
Member#: 412751
Default Happy
Glad you figured it out!
skatesfobia is offline   Reply With Quote
Old 02-05-2015, 04:32 PM   #18
skatesfobia
Member#: 412751
Default Happy
Happy you figured out what you were trying to. Maybe we can help next time!
