Old 11-18-2012, 12:53 AM   #251
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
remove the uppipe and turbo^ lol
Old 11-18-2012, 07:41 AM   #252
armyssoldierboy
Member#: 109424
06 AW STI
Twin Scroll HTA gt3076r
Use a 14mm crows foot^^ worked wonders!!
I had put in power steering fluid not even looking at the cap. It takes Dextron ATF. I bought some and disconnected the pressure line underneath and the reservoir line down low. Drained, reconnected the lines and refilled. As I was bleeding I noticed some drips on the ground. After wiping and rebleeding, I find a leak coming from a line I never touch
It was leaking from between the line and fitting. I pulled the line off after dropping the crossmember. One of the flares is smashed ??? I thought it was tight, maybe too tight and noticed this when I backed out of the bay.
The line
Good double flare
Smashed flare, see how flat the side edge is instead of having a mm or so side?
I talked to my dude at a Subaru dealership that has a few donor cars and he's going to pull one off another Sti for me. I'm picking it up Tuesday.
armyssoldierboy is offline   Reply With Quote
Old 11-29-2012, 06:34 PM   #253
Ishart
Member#: 332001
For anyone planning on swapping both lines going to the rack.... .
I found that removing the brace that covers the rack allows you to move the lines a bit more to make them easier to access. Especially the return line that has the rubber hose in it.
Ishart is offline   Reply With Quote
Old 11-29-2012, 06:37 PM   #254
Ishart
Member#: 332001
Also. There is a a sort of "restrictor" pill in the line. I cut my open just out of curiosity. I have pics for reference if anyone is interested.
Old 11-29-2012, 10:40 PM   #255
scby rex
Member#: 104878
02 wrxbastardchild
theres pics of it in the first few pages. It doesnt do anything and your fine without one.
Old 03-01-2013, 06:02 PM   #256
jnorth85
Member#: 76785
2000 580Whp The RSTI
SRP
ordered these items per The owner of anplumbing's recommendations for the power steering application.
Part # Qty Price Item Total Brand Specs
9894DBH 1 $6.49 $6.49 Earls Female End: 14mm x 1.5
AN Thread: -6
600006 6 $5.59 $33.54 Earls Any Length: any
Hose Size: -6
604706 1 $19.49 $19.49 Earls AN Thread: -6
Hose Size: -6
609006 1 $31.25 $31.25 Earls AN Thread: -6
Hose Size: -6
871406 1 $8.73 $8.73 XRP AN Thread: -6
Metric Thread: 14mm X 1.50
He also stated that the 9894DBH adapter that we are all using is not correct for the application and that it needs to have a 70-45* bevel cut inside in order to accept the flare fitting on the rack side.
as it stands you are essentially crushing the flare and hoping it holds the pressure.
jnorth85 is offline   Reply With Quote
Old 03-01-2013, 08:58 PM   #257
Serkan
Member#: 180514
2004 Sti
So there isn't a correct fitting to replace the 9894DBH ??
Serkan is offline   Reply With Quote
Old 03-01-2013, 09:19 PM   #258
jnorth85
Member#: 76785
SRP
No,
He informed me that we should cut off the OEM fitting and braze/weld on a AN based fitting. They offer the weld-on fittings.
The other alternative is to machine in a bevel to the 9894DBH this would help mate up to the OEM line.
Old 03-01-2013, 09:42 PM   #259
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
There are companies that make them. They are not cheap. See this:
http://www.3sx.com/store/comersus_vi...dProduct=30271
The problem with what you're saying jnorth85 is that perhaps your setup is different or maybe I misunderstand, but my rack doesn't have a flare fitting. Instead it relies on a oring to seal on a flat surface inside of the fitting. I can verify this by looking on the inside the factory lines which don't have a flare fitting on them.
Here is a picture of the high pressure side on the factory line (sorry for the bad picture, cellphones are poor for shots like these):
Here is a picture of the low pressure side on the factory line:
Essentially they are both the same but with different diameters. No flare there. Now look at the rack side fittings:
See the oring seal? No AN flare fittings on this one. At least on the 06 WRX rack I have.
The only modification I would do on these fittings from EARLS is to cut a slight chamfer on the inner diameter of the fitting to resemble the stock fitting and be a bit easier on the oring. That's my plan. But the lines are certainly not a reverse female flare fitting.
Old 03-01-2013, 09:54 PM   #260
jnorth85
Member#: 76785
SRP
Yes that.
You can easily modify the earls fitting
Old 03-01-2013, 10:02 PM   #261
kpluiten
Member#: 120273
06 WRBWRXWGN
Yes that.
See above. There is not need to modify it like you are describing.
EDIT: OK, I think I was just confused on what you said at first. We are saying the same thing, but with different terminology. I hear flare and start thinking you're talking about a 45 or 37 degree internal female flare like the fitting I posted above. :facepalm: You are correct.
You are correct, the chamfer is NOT hard to add to the inside to mimic the factory lines and I had already planned on doing that.
Apparently you are cool without it though as everyone here has been doing it for years! Maybe they just have slow leaks or always air in the system.
Old 03-01-2013, 11:48 PM   #262
jnorth85
Member#: 76785
SRP
Yup exactly! That's also what I plan on doing. From what Tom at earls told me it will hold but at a much lower pressure. He said if you were to smack a curb or introduce a shock load it would blow the fitting out, in addition once its cranked on you can't really remove it again.
Old 03-15-2013, 02:20 AM   #263
Serkan
Member#: 180514
2004 Sti
What about re flaring the power steering lines with this tool. It says in the description that this make 37 degree flaring for AN fittings.
http://www.summitracing.com/parts/sum-900311/overview/
Old 03-15-2013, 12:18 PM   #264
jnorth85
Member#: 76785
SRP
you could the motor in the car there isnt much room with the rack installed, also the lines coming out of the rack arent very long to begin with.
Old 05-04-2013, 07:42 AM   #265
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I have this tool and had a tough time flaring good grade aluminum lines. I can't imagine how this could possibly work on a oem hard line.
The problem is the little holder bracket can't hold the line unless you put an ungodly amount of torque on the nuts. Otherwise the flare part of the tool just pushes the line through the holder. I had to a big ass adjustable wrench on the nuts to stop it from slipping
Bad Noodle is online now   Reply With Quote
Old 05-04-2013, 07:52 AM   #266
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Can any of these lines (FMS, P&L, Chasebay) be routed like like the stock line but with a little more slack. So it lays on the frame and goes by the PS bottle?
(I looked for install pics but couldn't find anything)
Old 05-05-2013, 01:36 AM   #267
scby rex
Member#: 104878
02 wrxbastardchild
I made my own like that.
Old 06-20-2013, 10:47 AM   #268
christhjesus
Member#: 300296
2004 WRX
Originally Posted by wrx_driver_2002 View Post
The stock pressure line has a restrictor built into it... Did you get that put back in? If you didn't, your fluid will foam up in the pump and in the resevoir and your power steering will work like ass... Trust me, I know
Anyone else have this problem? I ask because I am having this happen with my setup.
What would be a fix for the foaming and lack of power steering when using these parts?
christhjesus is offline   Reply With Quote
Old 06-20-2013, 01:32 PM   #269
wgknestrick
Member#: 32576
04 STI
I am pretty sure those are MIO and FOR fittings.
Male Insert O-ring = MIO
Female O Ring = FOR
http://refsales.shopnow247.com/index...iewCat&catId=8
They are definately NOT 37 or 45 deg flare fittings. Those are used in the refrigeration industry quite a bit. I just don't know if they are the standard 6,8,10 AN sizing or if FHI uses a metric equivalent.
They may also be referred to as BEADLOCK fittings"
http://www.acparts.com/Aluminum-Bead...1-c-92636.html
Bill
wgknestrick is offline   Reply With Quote
Old 06-20-2013, 02:47 PM   #270
christhjesus
Member#: 300296
2004 WRX
Nevermind, had a torn o-ring on the reservoir to pump line and it was sucking air. YAY!
Old 04-05-2014, 11:56 PM   #271
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
See this thread ....post #6 for fitting size and thread patterns to make a High Pressure Line with banjo from PS Pump to rack
http://forums.nasioc.com/forums/show...1#post41741247
dangerousatom is offline   Reply With Quote
Old 04-28-2014, 05:10 PM   #272
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
So any thoughts on using a thicker than OEM O-ring?
OEM is 1.5mm tick. Matching O-Ring from HF O-ring set is 1.9mm thick. Will this cause issues?
Also, how tight should the metric adapter be? Hand tight + a little love?
Old 04-28-2014, 05:45 PM   #273
Justin V
Member#: 98747
07 WRX
I have a leak from that spot and thought replacement o rings would fix it. I bought a #10 and #11 from the hardware store to replace the factory ones. They may be slightly thicker or it was just how they looked since they had not been compressed.
I tried some slightly thicker o rings and 1 pinched in half. I can't remember what I did with the others. One may have fit or not. Point is they are pretty picky on the size. they need to fit into the flat face on the line side easily (as opposed to the rack side). I'd definitely test fit it.
Edit: The other two were a #78 and #83, one pinched through and the other mushroomed out.
You can look up a size chart for those o ring numbers, I don't know them off the top of my head.
Justin V is offline   Reply With Quote
Old 04-28-2014, 05:55 PM   #274
dangerousatom
Member#: 70710
The O-rings are really going to depend on the fitment inside the adapter fitting....see the blue fitting in the pics previous. If it pops inside and doesn't wrinkle or fold over, you should be ok. Use a good dab of vaseline on them before threading it altogether.
Torque, thats all up to you. Id say pretty tight as its going to see over 1000psi on the pressure side. The only way to test is thread it all up and then put the car on the ground and with the motor running turn the wheels from bump stop to bump stop. You will have to do this to bleed out any air in the lines anyway. If you have no drops your good to go, if you do, then tighter still. If you feel its tight enough and are unsure about further tightening due to a leak, pull it apart and check the O-rings first.
Old 04-28-2014, 06:13 PM   #275
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Thanks for the info. I did a test fitment but didn't torque the blue adapter down too hard. The HF Oring was fine. So at first it seemed like a good idea, but then I remembered its HF and will be ordering Orings from MCMaster tonight. It's like $10 for 2x100 packs. I'll pay that rather then try to get them replaced with the engine in.
I would guess that they are torqued about 10-15 lbs. That's what they felt like coming off at least.
It also looks like the oring gets coned and fills the beveled edge on the adapter. So not too sure what having more material in there would do ...
pic of the stock oil feed line ej20 please supernick77 Newbies & FAQs 1 09-08-2009 04:48 AM
How important is the placement of power steering line behind the grill tino Built Motor Discussion 23 06-01-2009 07:26 PM
Does Perrin rotated mount inlet/intake hit power steering lines? garface Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-03-2006 11:14 AM
short video of the broken Power steering pulley reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 7 01-04-2005 02:50 AM
Any locals with the dreaded power steering line problem? supermarkus North West Impreza Club Forum -- NWIC 6 01-01-2002 11:58 PM
