#251 |
Member#: 104878
TXIC
Vehicle:02 wrxbastardchild aw, 1,000,000 whp 2 aw tq |
#252 |
Member#: 109424
International
Vehicle:06 AW STI TS HTA 3076r 436hp/426tq |
Use a 14mm crows foot^^ worked wonders!!
I had put in power steering fluid not even looking at the cap. It takes Dextron ATF. I bought some and disconnected the pressure line underneath and the reservoir line down low. Drained, reconnected the lines and refilled. As I was bleeding I noticed some drips on the ground. After wiping and rebleeding, I find a leak coming from a line I never touch ![]() ![]() It was leaking from between the line and fitting. I pulled the line off after dropping the crossmember. One of the flares is smashed ??? I thought it was tight, maybe too tight and noticed this when I backed out of the bay. ![]() The line ![]() Good double flare ![]() Smashed flare, see how flat the side edge is instead of having a mm or so side? ![]() I talked to my dude at a Subaru dealership that has a few donor cars and he's going to pull one off another Sti for me. I'm picking it up Tuesday. |
#253 |
Member#: 332001
Vehicle:06 |
For anyone planning on swapping both lines going to the rack.... .
I found that removing the brace that covers the rack allows you to move the lines a bit more to make them easier to access. Especially the return line that has the rubber hose in it. |
#254 |
Member#: 332001
Vehicle:06 |
Also. There is a a sort of "restrictor" pill in the line. I cut my open just out of curiosity. I have pics for reference if anyone is interested.
#255 |
Member#: 104878
TXIC
theres pics of it in the first few pages. It doesnt do anything and your fine without one.
#256 |
Member#: 76785
MWSOC
Vehicle:2000 RSTi Coupe SRP |
ordered these items per The owner of anplumbing's recommendations for the power steering application.
Part # Qty Price Item Total Brand Specs 9894DBH 1 $6.49 $6.49 Earls Female End: 14mm x 1.5 AN Thread: -6 600006 6 $5.59 $33.54 Earls Any Length: any Hose Size: -6 604706 1 $19.49 $19.49 Earls AN Thread: -6 Hose Size: -6 609006 1 $31.25 $31.25 Earls AN Thread: -6 Hose Size: -6 871406 1 $8.73 $8.73 XRP AN Thread: -6 Metric Thread: 14mm X 1.50 He also stated that the 9894DBH adapter that we are all using is not correct for the application and that it needs to have a 70-45* bevel cut inside in order to accept the flare fitting on the rack side. as it stands you are essentially crushing the flare and hoping it holds the pressure. |
#257 | |
Member#: 180514
E. Canada
Vehicle:2004 Sti White |
So there isn't a correct fitting to replace the 9894DBH ??
#258 |
Member#: 76785
MWSOC
No,
He informed me that we should cut off the OEM fitting and braze/weld on a AN based fitting. They offer the weld-on fittings. The other alternative is to machine in a bevel to the 9894DBH this would help mate up to the OEM line. |
#259 |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN Now with 100% more Spec-C |
![]() There are companies that make them. They are not cheap. See this: http://www.3sx.com/store/comersus_vi...dProduct=30271 The problem with what you're saying jnorth85 is that perhaps your setup is different or maybe I misunderstand, but my rack doesn't have a flare fitting. Instead it relies on a oring to seal on a flat surface inside of the fitting. I can verify this by looking on the inside the factory lines which don't have a flare fitting on them. Here is a picture of the high pressure side on the factory line (sorry for the bad picture, cellphones are poor for shots like these): ![]() Here is a picture of the low pressure side on the factory line: ![]() Essentially they are both the same but with different diameters. No flare there. Now look at the rack side fittings: ![]() ![]() ![]() See the oring seal? No AN flare fittings on this one. At least on the 06 WRX rack I have. The only modification I would do on these fittings from EARLS is to cut a slight chamfer on the inner diameter of the fitting to resemble the stock fitting and be a bit easier on the oring. That's my plan. But the lines are certainly not a reverse female flare fitting. Last edited by kpluiten; 03-01-2013 at 09:17 PM. |
#260 | |
Member#: 76785
MWSOC
You can easily modify the earls fitting |
#261 |
Member#: 120273
SWIC
See above. There is not need to modify it like you are describing.
EDIT: OK, I think I was just confused on what you said at first. We are saying the same thing, but with different terminology. I hear flare and start thinking you're talking about a 45 or 37 degree internal female flare like the fitting I posted above. :facepalm: You are correct. You are correct, the chamfer is NOT hard to add to the inside to mimic the factory lines and I had already planned on doing that. ![]() Apparently you are cool without it though as everyone here has been doing it for years! Maybe they just have slow leaks or always air in the system. ![]() Last edited by kpluiten; 03-01-2013 at 09:14 PM. |
#262 | |
Member#: 76785
MWSOC
#263 |
Member#: 180514
E. Canada
What about re flaring the power steering lines with this tool. It says in the description that this make 37 degree flaring for AN fittings.
http://www.summitracing.com/parts/sum-900311/overview/ |
#264 | |
Member#: 76785
MWSOC
#265 | ||
Member#: 174442
Tri-State
Vehicle:2007 SuperWagon I don't spell well |
The problem is the little holder bracket can't hold the line unless you put an ungodly amount of torque on the nuts. Otherwise the flare part of the tool just pushes the line through the holder. I had to a big ass adjustable wrench on the nuts to stop it from slipping |
#266 |
Member#: 174442
Tri-State
Can any of these lines (FMS, P&L, Chasebay) be routed like like the stock line but with a little more slack. So it lays on the frame and goes by the PS bottle?
(I looked for install pics but couldn't find anything) |
#267 |
Member#: 104878
TXIC
I made my own like that.
| Thread Tools | |
| Display Modes | |
| pic of the stock oil feed line ej20 please | supernick77 | Newbies & FAQs | 1 | 09-08-2009 03:48 AM |
| How important is the placement of power steering line behind the grill | tino | Built Motor Discussion | 23 | 06-01-2009 06:26 PM |
| Does Perrin rotated mount inlet/intake hit power steering lines? | garface | Factory 2.0L Turbo Powertrain | 3 | 06-03-2006 10:14 AM |
| short video of the broken Power steering pulley | reddevil | Normally Aspirated with bolt-on Forced Induction Powertrain | 7 | 01-04-2005 01:50 AM |
| Any locals with the dreaded power steering line problem? | supermarkus | North West Impreza Club Forum -- NWIC | 6 | 01-01-2002 10:58 PM |
