Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Mid Atlantic Impreza Club
Old 03-01-2013, 08:51 PM   #4576
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Originally Posted by The1SloR/T View Post
I gave them to another local STi owner. They are pretty bright
Lol so they are for subaru but not yours?
slowgenius is offline   Reply With Quote
Old 03-02-2013, 08:10 AM   #4577
The1SloR/T
Member#: 251879
1998 Neon R/T 178whp
2010 Wrx Sedan WRB
sylvania bulb replacement guide screwed me over saying it was a 7440 bulb. Looks like a 921 to me..
The1SloR/T is offline   Reply With Quote
Old 03-02-2013, 11:43 AM   #4578
d3v0
Member#: 225692
2015 WRX
Getting a po244 whenever giving the car some power in 4th gear. Must be overboosting. Running Cobb stage 2 with just a turboback. Did the waste a adjustment on my td04 two turns tighter. Car runs like ****, boost bouncing al over the place. It was so bad I thought maybe the clutch was slipping but I don't think that's the case. I checked all the vac lines and they're all secure. What else should I look into? Restricter pill? Boost solenoid? Halp!
d3v0 is offline   Reply With Quote
Old 03-02-2013, 11:48 AM   #4579
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Did you tighten the wastegate after the problem or before?
isis is offline   Reply With Quote
Old 03-02-2013, 12:35 PM   #4580
d3v0
Member#: 225692
2015 WRX
Before. I know that tightening it 3-4 turns helps with wastegate flutter, which i was having. I also know that turning it causes some overboost.
No problems before. Then I tighten 4 turns. problems. Now its loosened 2 turns, so its back to being 2 turns tighter than stock. Think i should return to 0 turns and see if problem persists? I find it odd that a highly recommended mod on my WG actuator arm could cause such issues, but its definitely possible I suppose. I just didnt think I could really overboost with only 2 turns on the arm.
Old 03-02-2013, 12:38 PM   #4581
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Put it back. Move it 1/2 turn at a time. Any preload on the actuator affects your boost control. Not everything ever done on the Internet will give you moar mad powarz.
Old 03-02-2013, 03:14 PM   #4582
glhs377
Member#: 125388
97 240hp NA GF6
giant Carbotron wing
and i wouldn't put it past dan or max to have already done that, and totally forgot about it. because the cutout.
glhs377 is offline   Reply With Quote
Old 03-02-2013, 04:44 PM   #4583
d3v0
Member#: 225692
2015 WRX
^ fair enough. Ill turn it back. I dont care for power (stock 5 speed) but I just wanted it to stop doing the WG flutter.
Old 03-02-2013, 04:49 PM   #4584
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
if you don't care for power, go to cobb stage 0 and enjoy your flutter free driving.
Blinden is offline   Reply With Quote
Old 03-02-2013, 04:55 PM   #4585
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Get a real tune or figure out how to fix it properly. Off the shelf maps are jokes. And all the posts on the Internet on how to make them work 'better' are jokes too.
You will give yourself way too many problems if you start troubleshooting by assuming your car has a problem and the Internet lemmings wrote the bible on what works. If they are using standard Cobb reflashes, they can't help you.
Old 03-02-2013, 04:58 PM   #4586
d3v0
Member#: 225692
2015 WRX
I think you guys are reading into this a bit too much. All I did was shorten the WG arm, now im returning to normal, and hoping it stops overboosting
the car did have a tune on it when i bought it (by dan, circa 2007) that allowed it to run a turboback but it ran stock boost pressure. I got the Cobb AP so I could have an easy to use datalogger and code-reader and might as well toss the stg 2 map on there. its far from perfect (too rich, needs avcs tuning) but its good enough to roll with for now.
Old 03-02-2013, 05:03 PM   #4587
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
You're probably right.
The real problem is the TD04 on a 2.5L. Of course 4th and 5th gear are going to cause problems.
A lot of tension on the WG arm is a band-aid. And not a good one. I think the stock spring is 6-8 lbs if that. If you start cranking down on the spring your control resolution disappears especially with the stock BCS. How many miles on it? A new actuator might help. They do wear out.
Take a good tune off for a crap one. Not sure why you'd expect good results.
Old 03-02-2013, 05:49 PM   #4588
d3v0
Member#: 225692
2015 WRX
43,000 miles. Thanks for the advice. I'm gonna ask Dan If he still has that map.
Old 03-02-2013, 05:50 PM   #4589
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
I have a cable if you'd like to put it back on.
Actuator prob not worn out by then at stock boost.
Old 03-03-2013, 07:33 AM   #4590
subiewrxsubie
Member#: 278814
anybody sking/snowboarding today at 7springs?
subiewrxsubie is offline   Reply With Quote
Old 03-03-2013, 11:08 AM   #4591
d3v0
Member#: 225692
2015 WRX
Actuator felt solid this morning when I adjusted it back to stock, 0 turns.
Took it for a drive, and the car hesitates like hell under part throttle and watching the AP boost gauge, under steady throttle in third it just bounces from 14 psi to 8 and back up and back down - lurching and hesitating. At first it felt like when a clutch is slipping, you know, grabbing and not grabbing - but it isnt the clutch. So im thinking the WG adjustment didnt do anything. It seems to me the boost control is completely borked. BCS maybe? restricter pill?
Old 03-03-2013, 11:40 AM   #4592
sk84fun21
Member#: 113300
WRB, LOUD
What year car?
sk84fun21 is offline   Reply With Quote
Old 03-03-2013, 12:00 PM   #4593
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Dude just take it and get it fixed.
Old 03-03-2013, 12:54 PM   #4594
sk84fun21
Member#: 113300
WRB, LOUD
I have an oem ebcs you could see if it fixes the issue, also spare waste gate.
Can't get it fixed (assuming you mean tune) if a part is broken
Old 03-03-2013, 02:03 PM   #4595
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
Sounds like a vacuum hose or something may have come loose or cracked in that general area - are you sure it doesn't have an aftermarket BCS? If it does a map meant for a stock BCS won't work.
Old 03-03-2013, 02:28 PM   #4596
glhs377
Member#: 125388
97 240hp NA GF6
what do your datalogs say the desired boost is, and what about the boost control duty cycle, requested TPS vs actual TPS etc etc.
you said you got accessport for datalog. bring it!
Old 03-03-2013, 05:43 PM   #4597
d3v0
Member#: 225692
2015 WRX
Here is one I did last week as soon as I got the AP. third gear pull. Stupid AP doesnt log Boost target with initial settings, so I will do another log tonight with a Boost Target.
Old 03-03-2013, 06:13 PM   #4598
d3v0
Member#: 225692
2015 WRX
Went out and did some more logs. Have a few third gear pulls with different parameters. Will post shortly.
Old 03-03-2013, 06:27 PM   #4599
d3v0
Member#: 225692
2015 WRX
Blew a PO244 doing a 3rd gear pull with the cutout open: see datalog:
Log 5: PO244 during run; CUTOUT OPEN
Four more 3rd gear pulls from tonight w/ cutout closed
Log 1
Log 2
Log 3
Log 4
As Jason said, looking at the target versus actual boost; there is a problem. overboosting
Old 03-03-2013, 08:37 PM   #4600
isis
Member#: 73283
05 OBXT & CTS-V
03 Z1000
I'm sure somebody knows more than me but I'd like to see what it looks like with the original map. It worked fine till you cobb'd it. I wouldn't dismiss that. What's the BCS solenoid look like?
Official Pittsburgh Thread Build 4 WastingTime Mid Atlantic Impreza Club -- MAIC 8 04-26-2011 06:58 PM
Official Pittsburgh Thread v5 MRF582 Mid Atlantic Impreza Club -- MAIC 10302 10-07-2010 10:03 AM
Official Pittsburgh Thread V4 Kjott21 Mid Atlantic Impreza Club -- MAIC 10940 10-29-2009 03:16 PM
Official Pittsburgh thread V3.0 MikeCee Mid Atlantic Impreza Club -- MAIC 10519 01-11-2009 09:08 PM
Didn't there used to be an official Pittsburgh Thread? crystalhelix Mid Atlantic Impreza Club -- MAIC 0 01-08-2004 07:23 PM
