Go Back   NASIOC > NASIOC Technical > Pre-2002 Factory Turbo Powertrain
Old 03-01-2013, 09:38 AM   #1
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Default How do I fit bigger injectors to my 20g
I've recently gathered all the parts for the robs 550 tune which includes 04 sti yellow sidefeed injectors. Some of you will know of the Carl davey injector kit which allows the new injectors to be fitted into the old engine.
However, I've contacted Carl Davey directly and he's no longer making the kits and doesn't intend to do so any more.
What do I do? Is there another way?
Millhouse_5 is offline   Reply With Quote
Old 03-01-2013, 10:12 AM   #2
seangfy
Member#: 242150
1993 impreza L ej20g
aquafrost blue
You can use 96-98 legacy 2.5 fuel rails they fit the sti yellow injectors and directly replace the EJ20G fuel rails. Might be even more years then that not 100% though
seangfy is offline   Reply With Quote
Old 03-01-2013, 12:43 PM   #3
69subaru360
Member#: 159682
1995 WRX
96-99 EJ25 dohc rails work. That's what I used. It's a bolt in.
Old 03-01-2013, 03:56 PM   #4
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
Seems like I have some options now. Thanks guys
Old 03-01-2013, 04:16 PM   #5
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
That is too bad about Carl. I really liked his kits.
Deatschwerks also has an adapter kit for this.
http://www.deatschwerks.com/products...ter-kit-detail
-Rob
rob is offline   Reply With Quote
Old 03-01-2013, 04:40 PM   #6
eg33GC
Member#: 206851
99 V4
EJ20K RS
but, $10 for D rails is the obvious answer!
Old 03-01-2013, 08:25 PM   #7
Ioku
Member#: 164864
95 Impreza coupe
I'm going to my local u-pull it tomorrow and last time I was there they had a few DOHC legacys so I can pull you a set if you like I get them for free to $5 so it would basically just be shipping cost to you.
Ioku is offline   Reply With Quote
Old 03-01-2013, 09:09 PM   #8
jaxscuby
n00b Moderator
Member#: 10613
2002 USDM WRX
side feed fuel rails..
Old 03-01-2013, 10:15 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Sometimes it is handy to use the conversion kit. They are quite a bit easier to install than replacing rails and at some point you might want to switch back to stock injectors. Plus it isn't every day you find them for $10
-Rob
Old 03-01-2013, 11:03 PM   #10
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Can you use this for an EJ20K set up too?
Smoke is offline   Reply With Quote
Old 03-02-2013, 01:43 AM   #11
seangfy
Member#: 242150
aquafrost blue
Not sure hopefully someone who knows will chime in
Old 03-02-2013, 02:02 AM   #12
pmugabi
Member#: 280926
Yes you can. G and K fuel injector rails are the same
pmugabi is offline   Reply With Quote
Old 03-02-2013, 10:03 PM   #13
Millhouse_5
Member#: 269208
95 JDM STI RA
08 2.5i Sedan
I'm loving the cost factor of the old salvaged fuel rails, but how hard is it to do the conversion. I know the injector conversion is almost as simple as fitting the new injectors and doing some plug work. So far these mods are the most intense bit of work I'll have ever done on a car and I have no background experience to help.
I don't want to jump in over my head.
Message Board Statistics All times are GMT -4. The time now is 03:32 AM.
