Welcome to the North American Subaru Impreza Owners Club Sunday December 4, 2016
Old 02-17-2013, 09:48 PM   #1
mrchyes
Member#: 294069
98 Forester
Green
Default STi Trunk, The Plan
Yes i know this has probably been covered before!
I just wanted to make an up to date thread about how to successfully fill holes in the trunk lid after removing the wing.
The Plan:
3M Bondo body filler - 6oz.
Bondo spreader
.063 aluminum
loctite PL premium poly adhesive
I plan to cut the aluminum into over sized squares on the underside of the trunk and apply loctite adhesive to seal the holes (and hopefully help the bondo not to crack)
then I will fill most of the hole on the upper side with the adhesive
after that I will apply bondo and attempt to make it a smooth transition across the trunk lid.
i will then wet sand, prime, and paint, then clear.
I'd like to know what you guys think about this plan, i'm not dead set on anything, but i dont have the funds to have a professional do it (and id like to learn) and i dont have the tools (welder) to weld the holes.
Let me know what you think!
once I get the supplies I will start in and update with pictures!
mrchyes is offline   Reply With Quote
Old 02-17-2013, 09:51 PM   #2
BIGJBEARS
Member#: 301099
Buy a welder it will pay itself off a million times over
BIGJBEARS is offline   Reply With Quote
Old 02-17-2013, 09:54 PM   #3
mrchyes
Member#: 294069
98 Forester
Green
how am I to learn how to use it?
Old 02-17-2013, 10:11 PM   #4
rs_sedan
Member#: 323517
2000 2.5RST
Stm, one day Wrb
Grab junk steel and start practicing, just dont buy a harbor freight flux core pos, youll regret it later...
rs_sedan is offline   Reply With Quote
Old 02-17-2013, 10:14 PM   #5
mrchyes
Member#: 294069
98 Forester
Green
ill think about it..
might just try fiberglass for now
Old 02-17-2013, 10:19 PM   #6
rs_sedan
Member#: 323517
2000 2.5RST
Stm, one day Wrb
If you dont wanna spring for a welder im sure you orginal plan would work... That essentially what you would do if you had a welder anyway, well atleast what id do. Cut small pieces of sheetmetal and tack them in from below, the smooth with bondo (i prefer z-glass) and paint.
Old 02-17-2013, 10:21 PM   #7
mrchyes
Member#: 294069
98 Forester
Green
cool, thanks for the help!
Old 02-17-2013, 10:56 PM   #8
p951951951t
Member#: 276541
1972 Alfa Romeo GTV
Alfa Rosso
Make sure you don't get any bubbles in there. I usually like to let stuff get warm/hot (then let it cool) before I paint it just to make sure all the gasses have expanded and escaped from inside the filler. You don't want to end up with bubbling paint the first time it gets really hot in the sun!
I've mostly only had that issue when using plastic welding filler when shaving holes on urethane parts though.
p951951951t is offline   Reply With Quote
Old 02-17-2013, 11:03 PM   #9
mrchyes
Member#: 294069
98 Forester
Green
i will try and make certain there arent bubbles!
Old 02-18-2013, 12:29 PM   #10
mrchyes
Member#: 294069
98 Forester
Green
The plan as of now:
take trunk off car
cut .063 aluminum into squares and press them into place with loctite PL premium poly adhesive
once adhesive has cured (24hrs) completely cover inside of trunk lid (plastic, tape, ect)
strip paint off trunk lid (just outside)
apply bondo over holes lightly (4-5 coats)
sand inbetween coats (probably 500-750 grit??)
sand down entire trunk (500, 750, then 1200 grit??)
Prime
Paint
Clear
Old 02-28-2013, 02:59 AM   #11
88hatchback
Member#: 347645
93 Subaru Legacy
you can sand your rough shaping bondo with a 80-120 -220 grit paper.
when it comes to priming - sand the whole trunk with a 220 grit, make sure you use a high build primer (fills scratch marks well)
wet sand with a 600 grit paper (the primer) MAKE SURE YOU USE A SANDING PAD!!!
spray your base coat - make sure you give it lots of time between coats if you're using a water based paint.
First coat is a dust coat - 50% overlap
second coat is a med application with 35% overlap
third is another med coat with 30% overlap to fill all the color in.
if you're spraying clear as well - you can lay it on 1-2 hours after base (with water based)
if you lay on 3-5 coats of clear it'll give you enough paint depth for wet sanding (1000-1500) then cut and polish (buff)
just make sure you watch your edges when sanding - as its easy to cut through the paint and would cause you to have to redo the whole job again.
C.
88hatchback is offline   Reply With Quote
Old 02-28-2013, 11:11 AM   #12
mrchyes
Member#: 294069
98 Forester
Green
If i do paint it myself i dont think ill wetsand after the clear coat.
thanks for all the info though!
Old 03-03-2013, 02:12 PM   #13
04wrxhart
Member#: 204246
2004 Impreza WRX
WRBlue
You could also take it to a muffler shop and have them weld the holes shut. Theres a shop by my house and im pretty positive the guy wouldnt charge me more than $20.
04wrxhart is offline   Reply With Quote
Old 03-03-2013, 07:53 PM   #14
mrchyes
Member#: 294069
98 Forester
Green
scratch this whole plan.
i traded for a wrx wing and trunk
