Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-26-2013, 11:07 PM   #1
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Default Gear oil capacity '10 2.5i 5MT
Planning on changing the gear oil in the Impreza tomorrow. I found little information regarding specific information for the non-WRX Impreza.
According to sources the WRX 5mt takes 3.7 qts of 75w-90, does this also apply to the base Impreza? Looking for this info ASAP, I'll be picking up fluid tomorrow to do this while I'm swapping tires.
Thanks.
SlimJim8804 is offline   Reply With Quote
Old 02-26-2013, 11:29 PM   #2
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
75w-90 is correct. As far as how many qts the dealer told me "about 4 qts " but he didn't sound to sure lol but that's just because its Kearny mesa Subaru. I did 3.7 qts n just used the dipstick to measure how much more I needed. Are you doing the tranny + rear diff?
Steve2.5i is offline   Reply With Quote
Old 02-27-2013, 02:32 AM   #3
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
I'm mounting and balancing a set of tires on it in the morning, so I figured I'd just change the gear oil while it's in the air already. I'll do an oil change in about a month, so ill do the rear diff then. Thanks for the info.
Old 02-27-2013, 03:17 AM   #4
AWDmonk
Member#: 271442
2006 Impreza 2.5i
CGM
Did you not get an owner's manual? Mine lists everything, I would think yours would, too. I got really lucky after I bought my car and found someone with a digital copy of the dealer service manual.
AWDmonk is offline   Reply With Quote
Old 02-27-2013, 08:29 PM   #5
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
Quite honestly I hadn't considered that. I'm used to having used cars w/o owners manuals, this is a family members car. I was just doing 'ground work' to get some info ahead of time, I was running on a limited timeframe and had to mount+balance a full set of tires.
Tried Penzoil Synchromesh, took ~3.5 qts to read full on the dipstick. The difference is dramatic regarding the quality of shift feel, I've always been a big supporter of this product and it continues to impress me. I'll probably run a short interval and change more frequently as the miles roll on. It's cheaper than an oil change, and the improvement is significant enough.
Old 02-28-2013, 12:24 PM   #6
GEE-OTTO
Member#: 201277
2009 Legacy GT
Penn synchro mesh hmm never thought about that
I use 2.5 bottles of RedLine Lightweight Shockproof + Motul Gear 300
GEE-OTTO is offline   Reply With Quote
Old 02-28-2013, 02:29 PM   #7
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
It was available locally and I've had great success with it in the past.
Old 03-03-2013, 09:32 PM   #8
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Is this as simple as it seems like it should?
I have an 09 2.5i 5mt and should probably do the tranny and diffs soon as I just passed the 80k mi mark...
Ralph47 is offline   Reply With Quote
Old 03-04-2013, 03:50 PM   #9
JohnM10
Member#: 244231
2006 Impreza 2.5i 5M
Crystal Grey Metallic
Yes, it is very easy. The hardest part is getting the filll and drain plugs off of the rear diff. Make sure you remove the fill plug 1st to make sure you don't get stranded with no way to fill the diff back up. Get some kind of hand pump as well to pump the oil into the diff.
JohnM10 is offline   Reply With Quote
Old 03-04-2013, 04:20 PM   #10
Steve2.5i
Member#: 293006
2015 Subaru WRX
WR Blue
Hand pump helped me out alot when I did it. For the rear diff I used a breaker bar + rubber mallet lol I'm not the strongest of guys so that probably took a good 5mins. Overall like he said very very easy.
Old 03-04-2013, 05:47 PM   #11
Ralph47
Member#: 214774
2009 Impreza 2.5i
Dark Grey
Cool, I will have to look up the rest of the stuff for the diffs and tranny ect...
I think I will make it part of my 100k service then I will do it more frequently after the fact. We will see lol
Old 03-12-2013, 09:54 PM   #12
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
The gearbox oil is very simple.
Just a torx bit for the drain plug, and fill through the dipstick hole. I had a extended funnel that made the process a breeze. Drove it around the block a little bit, checked the level and finished. It took me ~45-hr as I always do loooong drains when changing any fluids. Especially gear oils. The majority of the time was letting it drain, and slowly filling it to insure it wasn't over full.
I haven't done the rear diff on this car yet, but it's a painless process on other cars.
Old 03-13-2013, 10:17 AM   #13
NH8991
Member#: 197937
2016 Golf R
Under the radar silver
Originally Posted by SlimJim8804 View Post
....It took me ~45-hr as I always do loooong drains when changing any fluids. Especially gear oils.....
Yep, 45 hours is a long time for gear oil change
NH8991 is online now   Reply With Quote
Old 03-16-2013, 02:22 PM   #14
SlimJim8804
Member#: 241943
2065 Magic Carpet
Swirl Rally Bleu
I know! Gotta be thorough.
