Old 03-04-2013, 06:01 PM   #426
ogboot
Member#: 170906
psm
I've been researching Kinugawa for a couple of years now, verifying their reliability as a MFG. Pulled the trigger on a T518Z for my stock ej205, just looking for a "mild" upgrade from stage 2. Will post unboxing, impressions, etc.
Self tuned the Stg2 setup, looking forward to getting the tune laid down for the new turbo as well.
I may eat crow, but I feel like they're a good product and not just another "ebay knockoff". I'm glad these turbos are getting more exposure here, it seems they're known to be very reliable in other circles, just not on NASIOC (yet). Plus, they offer some configurations that aren't advertised anymore by the other MFGs.
ogboot is offline   Reply With Quote
Old 03-04-2013, 06:05 PM   #427
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
No motor No Trans :-(
Originally Posted by gabedude View Post
Go to Kinugawa.com and get a twinscroll 18G. I have tuned many 18Gs and 16Gs on the 2.0L. The 2.0L loves the 18G much more than the 16G, and especially with meth injection or even better, E85. Every EJ205 I tuned was stronger than my EJ257 when it had stock pistons. For cast piston motors, I would only want a 2L.
I dig this post! Im torn between a TS 18G or TS 20G. Im a fuel pump, turbo and tune away. :-)
Mario
marios03wrx is offline   Reply With Quote
Old 03-04-2013, 07:47 PM   #428
2011boostdwrx
Member#: 263470
Gabedude, everything has been professionally installed, leak test was performed and well as vac. leak test, nothing. Secondly, i did not make 375 WHP with the HTA68 (338-350 23.5 PSI max i think) right now I am sitting at (over 350) with the current setup (no timing 20 PSI). 375whp on a stock VF-52 no way not on this dyno. There is no E85 around me in CNJ that i can run on a regular basis.
Heres the mods:
Stage-2 SB (Weisco Pistons, Eagle H-Beam, ACl race Bearings, new crank, ARP head Studs) Stock Heads decked, cleaned
Kamak 20 GTX STS
AP ELH/GS upipe, CNT catless DP CBE
AP fuel Rail kit with Fuel Lab FPR
73mm Intake, Perrin Inlet, FMS FMIC
6-spd swap HDSS Clutch
GS Boost Sol, AEM 4.5 Bar MAP
TGV/Air Pump Delete
2011boostdwrx is offline   Reply With Quote
Old 03-04-2013, 10:25 PM   #429
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Originally Posted by wrxsubiemod View Post
A td05h should probably never be put on a 2.5.
A td05h 8cm^2 20g is a fun street turbo on a 2.5, especially with an ewg.
theotherguy is offline   Reply With Quote
Old 03-04-2013, 10:30 PM   #430
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Looking at the Kamak/kinugawa turbos and would like some help. Looking for something thats hitting full boost before 4.5k and making a easy 350whp on pump and 400 on E85. I'd like to make more than that and spool sooner ideally.
Mods are
Stock V8 Ej207 w/ AVCS
FMIC
ID1000s/rails/pump
Stock TS header/uppipe
3in exhaust
APS hard inlet
CAI
EBC
So Im thinking TS18g or 20g but not sure what ones.
All Twin scroll
kinugawa td05h-18g 3in anti-surge ($300 Cheaper than rest)
kamak sts td05h-18gtx 3in anti-surge
kamak sts td06sl-18gtx 2.4
kamak sts td05h-20gtx 3in anti-surge
kamak sts td06sl-20gtx 2.4
kamak sts td06sl2-20gtx 3in anti-surge
kinugawa td06sl2-20g 3in anti-surge ($300 Cheaper than rest)
Im leaning towards one of the first or last 2.
Paul is online now   Reply With Quote
Old 03-05-2013, 09:59 AM   #431
Stas 2.0
Member#: 214696
Originally Posted by bluestone View Post
I am looking for the most cost effective upgrade for my 04 wrx without too much power to blow my stock engine or transmission. Would this Kamak be the best option under $800:
http://www.ebay.com/itm/130345616682...84.m1436.l2649
18g TD05H 7 cm
good choice, but 16g for 2.0 engine will be better. 16g and 18g both will make injectors duty over 100%, so no difference if you're not going to replace stock injectors.
Paul
I have td05-20G twinscroll on my 2.5l setup, good low end torque, but top power is poor, TD06SL2 is much better for TS, and 20G is at least option to get 350whp, 18g will not push it, so td06sl2-20g, 3in anti-surge, and ask Kinugawa to make billet wheel 5+5 blades for some extra money!
Stas 2.0 is offline   Reply With Quote
Old 03-05-2013, 02:08 PM   #432
bluestone
Member#: 36583
2004 WRX sedan
For a twinscroll I would need a new exhaust manifold right? I have a p&p manifold and don't really want to buy a new one. I'm on the fence whether to put in a VF48 (earlier spool and less topend, but I'd rather have more topend) or 18G. I'm just gunshy of the 18G for the possibility of blowing motor/trans.
Why did you decide on the T518Z housing? It's just effectively a bigger housing with higher A/R right?
bluestone is offline   Reply With Quote
Old 03-05-2013, 02:51 PM   #433
V8 GTFO Lesbic WGN
Member#: 191212
2007 FXT-5MT E85 20G
TD06SL2 Kinugawa
Simple, all these can be acquired for same price as a 18G/20G-XT/XT-R turbo:
Kinugawa 18G/20G twinscroll, approx $750
Kinugawa header twinscroll approx $450
Kinugawa downpipe twinscroll (need to weld to your aftermarket downpipe of choice), approx $115 (or buy a $20 flange):
V8 GTFO Lesbic WGN is offline   Reply With Quote
Old 03-05-2013, 03:42 PM   #434
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
^nice didn't see those
Old 03-05-2013, 03:56 PM   #435
bluestone
Member#: 36583
2004 WRX sedan
That's great, but like I said my price point is $800, ergo Kinugawa 18G non-twinscroll. I already have headers and downpipe that work just fine
Old 03-09-2013, 12:20 PM   #436
ogboot
Member#: 170906
psm
It's funny, I don't know exactly what info to trust, because cross referencing the ebay store --> with the online store --> with the kamak product catalog doesn't really yield a page without a typo or missing data. If the info is to be trusted, the T518z compressor housing has a slightly larger A/R than the TD05. But, the inlet is a fraction of an inch smaller (seems to be near the original TD04 inlet size..maybe?). Seems Greddy was mum about the complete stats, but I may just not know where to look for reliable info.
There's not a whole lot of information on this housing on the subies, there are a few posts of people using the actual greddy but little data. Part of me just wanted to try something unique for the fun of it and it's not so unusual to be dangerous or foolhardy, just different. Looks like a mild, fun upgrade for the 2L with decent power and spool. I'm going to check on eta sometime this week, I believe it was a 2 week lead time.
Old 03-09-2013, 12:32 PM   #437
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
I had the original greddy t518z. If you have any questions about it I will be glad to help. Its been sold off but I still remember some stuff about it
Old 03-09-2013, 01:38 PM   #438
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
This is why I can make 484 FT/lbs of WTQ and 479 WHP running E85 on my 8CM^2 worn out Blouch TD05H-20G.
Dammn!!! That must be on a high reading dyno. You running fast trap speeds with that?
Old 03-09-2013, 02:52 PM   #439
ogboot
Member#: 170906
psm
Thanks man. Overall what were your impressions? Supposedly it's incredibly comparative to the 18G.
Old 03-09-2013, 06:15 PM   #440
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Well it is a 18g. It actually uses a sl2 turbine so that's why they were doing well. If I can put it in a nutshell I would consider this a big 18g.
The compressor cover is bigger than a td05 housing, uses a bigger turbine wheel and comes in 8cm. Its a nice turbo for both 2.0 and 2.5
Old 03-09-2013, 07:56 PM   #441
2011boostdwrx
Member#: 263470
little update 360/380 today by just changing the wastegate spring to 1.5 bar. we are gonna turn up the boost next. car feels nice on the road. mustang dyno.
Old 03-10-2013, 11:28 PM   #442
Kamak_Dynamics
Member#: 349754
Default A Little Bit of Info
This is George from Kamak Dynamics, I will be directing Kamak from here on out and I just want to drop a line. I usually don't have time to participate in forums, but after reading this thread, I had many laughs and want to thank everyone for making the community so exciting. Of course, some information true, some false, but it's funny to see that you guys know the operations of our company, maybe, better than we do. I LOLed the whole way through and had a great time reading.
I wanted to let everybody know my experiences. There is no way I can put it in a short paragraph so I'll summarize. Recently, I've been doing a lot of traveling to know what the turbo industry is like, Globally. I've spoken with the largest turbo companies around the world and it's amazing that everyone is wanting to jump into the market in China right now because they are just beginning to play with performance cars. Thought you guys might like to know what what you guys are doing is leading a brand new trend in China. I will be in going to Kinugawa and Kamak locations in a few different countries the coming weeks to merge Kinugawa and Kamak together, officially. I will then setup a solid network so everybody can contact us easily. I know that it seems hard to communicate with us for some people, and I have to admit that I feel the same way; therefore, things will improve here for us. As a smaller company, our most difficult task is to spread our resources around the world. Unlike many familiar brands, we want to offer the same support globally and offer the excitement of turbocharging to countries that are not as experienced. This limits our resources we can place in a certain area, but it certainly does not mean that we do not want people to contact us.
I will most likely not be able to view this thread often and want to thank everyone that participated in talking about us. Whether is good or bad, it's all good for us. The good gives us encouragement to continue doing what we do. The bad gives us motivation to improve and become better.
Kamak_Dynamics is offline   Reply With Quote
Old 03-11-2013, 11:47 PM   #443
ogboot
Member#: 170906
psm
*head explodes*
Old 03-12-2013, 07:30 PM   #444
SplatWRX
Member#: 85932
2005 STi / 2013 STi
2005 Forester XTi
Ordered a 16G 8cm today for my Foz, Looking forward to installing it.
SplatWRX is offline   Reply With Quote
Old 03-12-2013, 11:32 PM   #445
V8 GTFO Lesbic WGN
Member#: 191212
TD06SL2 Kinugawa
Cool, join us at the Deals Gap "Forester Only" meet in May to compare Kinugawas, pm if interested. Tuned200 is going from Cinci.
Old 03-13-2013, 01:45 PM   #446
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
We just had one of these; TD06SL2 18G 7cm installed on a WRX 2.5L hybrid (flared chambers), Manley pistons. We feared for his tranny when we did E85 conversion.
A setup we did a long time ago with a Blouch TD06SL2 18G 8cm, tmic on E85 made over 400wtq on a Mustang dyno. There's a PPG trans on that car though. Lol
Old 03-13-2013, 03:18 PM   #447
Zee Biker
Member#: 166005
2005 Saab 92x
Beaten Silver
the 18g did more than your 20g?
Old 03-13-2013, 03:46 PM   #448
mystilexzero
Member#: 154674
2007 wrx
ugm
I've had my subaru since 2007, almost 6 full years and ive been through countless parts, i was 18, low on money, and did what i had to do to get performance parts. Through all my ebay parts, the only thing to me that is proven are intercoolers, pipes, basiclly anything that doesnt have a moving assembly. Wastegates? blew the diaphragms, blow offs? they leaked, turbo's? had 2 gt35r's installed on 2 friends cars, one runs decent at 11 psi, the other seized at 17 pounds.
moral of the story, im 100% ebay parts work, but you take a gamble. plain and simple is that, if your willing to gamble your money in sacrifice of the longevity of your motor, thats all on you, we cant make that decision for you, all every forum member here can do is show/tell facts and opinions.
would i run an ebay turbo? no, never, if you cant afford a quality turbo then dont mod it, plain and simple.
would I run ebay pipes, catch cans, intercoolers, badges, anything not moving? sure why not
mystilexzero is offline   Reply With Quote
Old 03-13-2013, 04:06 PM   #449
ericz
Member#: 224467
2005 CGM STI
93 4Runner 1JZ swap
Well, the good news is, these aren't eBay turbos.
ericz is offline   Reply With Quote
Old 03-13-2013, 04:13 PM   #450
wrxsubiemod
Member#: 165104
E85 SoCalPorting
Owner
Welcome to the Forum. I know communication can be tough for some of us but are you willing to share a direct line or email address?
I have a few things I really wanted to discuss about the turbos.
-Ruben
FS : Kinugawa Td05 20G Turbo + Boost Gauge. Fit Subaru thenic123 Engine/Power/Exhaust 15 06-08-2011 07:02 PM
VF39 vs HTA68 vs Blouch TD0518G 8 cm dmcutter Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 103 03-11-2010 01:41 PM
NEW 1 Bar / 14.5PSI Blouch Turbo Wastegate Actuator NEW 1 Bar / 14.5PSI Blouch Turbo dexterous Engine/Power/Exhaust 6 02-14-2010 07:55 PM
Blouch Turbo Budget Series Turbos Blouchturbo Engine/Power/Exhaust 18 06-05-2009 04:07 PM
fullrace GT3076 1.5 Scroll vs Blouch DOM III vs FullRace Twinscroll GT35R azn_ryder02 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 58 04-06-2009 10:29 PM
