Old 03-02-2013, 09:33 PM   #1
esms06
Member#: 215391
1993 Impreza wagon L
white
Default wagon hatch stuck
Hey guys I've been searching but can't find the thread to fix this issue. I have a saab 9-2x aero with the back hatch stuck closed. I've opened a couple times before with the metal tab through the hole in the back but this time its stuck good. I've tried and tried unfortunately I managed to bend the tab. Do you guys have any suggestions? Any help is greatly appreciated because I have a two year old and I need that room. Thanks in advance.
esms06 is offline   Reply With Quote
Old 03-04-2013, 08:59 PM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Short term, maybe have someone push down from outside and use the tab again.
Once open, is likely either the locking mechanism needs to be lubed or the strike pin needs to be adjusted.
If it's a cable that does the unlock, it may need a lube as well, check it with the hatch open.
