Old 02-28-2013, 12:43 AM   #1
mysoda
Member#: 300648
Default water liquid leaking sound when driving or accelerating.
hi, i heard a water or liquid leaking noise when i drive the car, it sounded like it in the engine bay. when i am sitting inside, it seems like its coming out from the area behind the gas gauge or the gas pedal, my car was overheat before after they replace the radiator, and head gasket and some belts and aftermarket thermostat. the noise seems reduce, but i can still hear it when i accelerate relatively hard. i am wonder what may that be and has anyone had that problem happen to them before.
mysoda is offline   Reply With Quote
Old 02-28-2013, 11:38 AM   #2
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
Replace your thermostat with an OEM one. The water dribbling sound is air bubbles in your heater core and will expedite another head gasket failure due to poor coolant flow.
cal_look_zero is offline   Reply With Quote
Old 03-01-2013, 02:08 AM   #3
mysoda
Member#: 300648
ok. thank you. i am going to do so as well any idea where i can get the oem thermostat?
Old 03-01-2013, 06:48 AM   #4
Bababou
Member#: 280689
2010 2.5i Impreza
Newport blue
Other than your local dealership, any one of thousands of online parts stores will have them. Rallysportdirect.com seems to have good prices on a lot of parts. Go to google and search for OEM subaru parts.
Bababou is offline   Reply With Quote
Old 03-04-2013, 07:43 PM   #5
cal_look_zero
Member#: 294461
2006 San Remo Wagon
Under construction
You can also get an xactstat made by stant. Just google "(Year and model) xactstat."
Old 03-04-2013, 08:12 PM   #6
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Thermostats & radiator caps are about the only "wear & tear" items I only use OEM.
