Old 02-15-2013, 04:53 PM   #126
rwdeatr
Member#: 147337
brz lookin good!
rwdeatr is offline   Reply With Quote
Old 02-15-2013, 04:56 PM   #127
mkvaron
Member#: 326317
2011 WRX hatch
SSM
I have one word to describle this, BEASTLY!!
mkvaron is offline   Reply With Quote
Old 02-18-2013, 12:15 PM   #128
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Thanks guys!!!
Check out the new video we made of the Tein Street Flex coilovers
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 03-04-2013, 09:39 PM   #129
RallySport Direct
Member#: 33174
We are Open Late!
Wanted to do a quick review on the Cusco engine mounts and their rear diff mount as well. One thing I noticed while driving the car was the vagueness coming from the stock engine mounts and the rear end as well. I saw this as a opportunity to not only improve on those aspects of the car, but it also gives me the opportunity to give you guys my impression of the parts as well.
Let's start with the install first. The engine mounts are very straight forward, simply unbolt the 2 large nuts on the bottom of the front cross member, and then the 4 bolts holding the left and right mounts to the engine block. Lift the engine up a few inches to gain enough clearance to remove the old mounts. The new cusco mounts are a bit easier to get in than the stock ones are to remove, but really neither are that bad. The new cusco mounts will bolt up just like stock, and so you will just reverse the uninstall process, and they should bolt right in without too much fuss.
The rear diff mount was a bit more tricky, and not that I would ever call it a difficult install, but a bit more time consuming as you do have to access the inner portion of the rear cross member, which will require you to remove the lateral arms from the rear cross member. Once you have access, you will want to get your skinny fingered friend to hold the nut on the inside of the cross member as you thread the long bolt through the new mount and into the nut. Other than that very minor frustration of small access holes, the install was a breeze and bolted up just like it was supposed to without any problems.
Now the review! I must say, I was never expecting these to retain the factory comfort levels, as I have run products like this on my own cars. I did notice a bit more noise and vibration than I was used to, but once I had a chance to go drive the car, I knew exactly why I did these mods, and the extra noise and vibration was almost a welcomed feeling. The direct connection these parts bring to the car is a huge improvement over the stock bushings, no longer do you feel the slop from the rear end, or the somewhat delayed response from the engine. Everything is instant, everything feels solid, and it feels AMAZING! Finally the Albino Rhino is starting to become what I had envisioned in my head, and besides the extra noise and vibrations, I could not ask for anything more.
I would not recommend these parts for anyone who wants to keep their car as a comfortable daily driver, as you will most likely despise these mods. But for someone looking for something more aggressive and direct, and does not mind the harshness, than this would be perfect!
Check out the videos below for some before and after.
Cusco Engine Mount Set Subaru BRZ / Scion FR-S
Cusco Rear Differential Support Brace Subaru BRZ / Scion FR-S
Thanks,
Rick
Old 04-22-2013, 12:57 PM   #130
RallySport Direct
Member#: 33174
We are Open Late!
Been really busy with the car recently and have a few updates for everyone!
First, we installed the Kartboy short throw shifter with the rear bushing. Now we all know the stock shifter is pretty good, but I wanted even shorter throws and a more direct feel to the shifter as a whole and Kartboy came to the rescue with their Short Shift Kit!
I LOVE this shifter! Install was not too bad at all, and the shifts are definitely more crisp and direct, plus it does reduce the throw between shifts which makes for slightly quicker shifts as well. The rear bushing helped secure the shifter assembly as a whole and really adds to the feel when shifting quickly.
Next, we decided the car needed something up front to complete the look we were going for when we added all of the beautiful APR carbon fiber bits. So, naturally we looked to APR and we installed their Carbon Fiber Mirrors and Carbon Fiber front Air Dam. I was not quite sure how these would look, but based off the quality and look of the previous APR parts installed, we knew we had to install them, and I must say, they make the car look jaw droppingly beautiful.
And last but not least we installed the Prova Front Fender Emblems. Since day one, we have wanted to get rid of the stock fender emblems, and go with something a bit different, so as soon as these showed up here, I grabbed a set and installed them that same night. Fitment is perfect, the quality is top notch and they come pre-painted and ready to install. I really like these as they are a subtle addition to the car, they don't really stand out, but they do add something to the car that I just can't quite put my finger on. Either way, I am loving the way the car is looking with all of the additions we have done to it.
We have some really good things in the works for this car, can't divulge any info, but I think you will really like it
Thanks,
Rick
Old 04-22-2013, 01:03 PM   #131
RallySport Direct
Member#: 33174
We are Open Late!
Old 04-24-2013, 04:55 PM   #132
RallySport Direct
Member#: 33174
We are Open Late!
Loving this vector drawing of the STi and Albino Rhino.
Thanks,
Rick
Old 06-21-2013, 03:48 PM   #133
RallySport Direct
Member#: 33174
We are Open Late!
The Albino Rhino Receives Some Boost!!!!
Well well well, so the little Albino Rhino has finally lost its baby horn! I can’t say how excited I was when we received the Vortech SuperCharger in for our Albino Rhino BRZ. First I poured through the box checking out all of the components, resisting the urge to run around the shop making supercharger/blow off valve noises, but I kept my cool. Really, on the inside I was like a kid at Christmas and could barely contain my excitement. I literally started on the install that very night and enlisted the help of a few chosen comrades, one for install help, and one for comic relief. With the team in tow, we set out to give the Rhino some much needed boost.
The install was very straight forward and I was impressed with the fit and finish of the kit overall, plus it just looks beautiful and proper in the engine bay. I was not keeping track of time, but I would assume we spent a solid 6-7 hours on the install, potentially longer, although it is hard to say for sure as I never bothered to look at a clock, I just wanted to get this thing boosted! The initial startup made my heart drop for a brief moment when we saw oil dripping from under the car. With thoughts of all the worst case scenarios racing through my head I could not help but think “this whole thing is going to have to come back out and even worse, I won’t get to drive it tonight…” I don’t ever recall popping the hood, but I vividly remember looking down at an oil soaked By Pass Valve filter. I have never been so excited to make a dumb mistake! I cleaned the excess oil off the filter and off the floor of the shop and started it back up. Such feelings of accomplishment when you finally finish something you have wanted to do for almost a year, and as a plus everything looked perfect and sounded even better. It was time for a drive!
Pulling out of the shop was no different than any other time except one thing.. We have boost! Even at idle the car felt like it had a different personality, almost a new beginning for the car. We took it very easy at first, wanting to make sure everything was secure and running well. After a few low boost pulls around the area we pulled it back in to double check everything, re-check the oil level, and clean off the bit of hidden excess oil that still wanted to mist out of the BPV filter. Everything was spot on, I was getting the butterflies from excitement, and it was time to put it to the test. We first hopped on the freeway wanting to run it up to redline to check that boost was where it should be. Naturally I forgot to even look at the boost gauge, as I was having too much fun and needing to pay attention to redline and the cars around me. My very first impression was… “This feels like a fast N/A Honda!” and that would be the best way I could describe it, as it feels almost exactly the same as before, just much more, and it’s awesome! I know everyone says “this is how the car should be from the factory”, but it truly is in this case. The car was still very responsive, predictable, and a bit peaky in the power delivery, but we just get more uumph out of the little FA20, plus a noise that compliments the feeling very well.
In the lower RPM’s the car behaves much like a stock car would, but once you get into the upper RPM range, the engine just wakes up and propels you along briskly with a bit of noise. You don’t get the sense of speed or power like you do with a turbo, but instead you get a nice linear power band that is more than happy to accelerate you to law breaking speeds at a moment’s notice. Not that I would recommend doing that or anything
Overall I am very pleased with this kit and the performance it gave our Albino Rhino. I was not expecting break neck acceleration from it, but I may have under estimated this kit a bit and was taken back at how it transformed the vehicle and the engine. For being a 100% bolt on kit, I could not ask for more, as this is something an average person can do in their garage over the weekend. I had assume that because we were using stock injectors and a stock fuel pump that there were not much, if any gains to be had, but the Vortech kit pulled through and left me with a huge smile from ear to ear. If nothing else, the sore face from my extended drive was well worth it.
Thanks,
Rick
Old 06-21-2013, 03:51 PM   #134
besthaticouldo
Member#: 279660
god thats such a clean and perfect install. i love this car. looks so good.
besthaticouldo is offline   Reply With Quote
Old 06-21-2013, 03:55 PM   #135
RallySport Direct
Member#: 33174
We are Open Late!
Thanks!
We also installed a Defi Boost gauge using the ATi pod mount and a Prova steering wheel of course!
Thanks again,
Rick
Old 06-21-2013, 08:30 PM   #136
jgardner9000
Member#: 219549
2009 STi
Looking good!
jgardner9000 is offline   Reply With Quote
Old 06-27-2013, 07:51 PM   #137
RallySport Direct
Member#: 33174
We are Open Late!
Just installed the Tom's Taillights and I think I am in love!! They literally change the way the back of the car looks, and it is amazing how such a simple mod can give so much attitude to the rear end of this car!
We should have some daytime running shots as well as a sweet video up on these shortly.
Thanks,
Rick
Old 06-27-2013, 08:17 PM   #138
Aarron_M
Member#: 68210
2016 Mustang GT
Oxford white
Those tails are amazing. If I had a BRZ, they'd be the first thing I'd buy
Aarron_M is offline   Reply With Quote
Old 06-27-2013, 09:00 PM   #139
JSchell1309
Member#: 321321
2010 Ford SVT Raptor
Tuxedo Black
I saw the tails updated on facebook. I drooled a little a lot
JSchell1309 is offline   Reply With Quote
RallySport Direct's BRZ: The Albino Rhino RallySport Direct BRZ Forum 179 07-18-2014 11:37 AM
RallySport Direct's 2011 STI Sedan! RallySport Direct NASIOC Project Cars 540 04-07-2014 02:31 PM
RallySport Direct's BRZ: The Albino Rhino RallySport Direct NASIOC Project Cars 156 02-06-2014 04:51 PM
RallySport Direct's 2011 STI Sedan! RallySport Direct Rocky Mountains Impreza Club Forum -- RMIC 192 12-27-2010 03:07 PM
RallySport Direct's 2011 STI Sedan RallySport Direct Member's Car Gallery 119 08-25-2010 04:06 PM
