#26 |
Member#: 152449
Vehicle:2003 Impreza WRX Silver |
correct i did do the pull after swaping maps and putting 93 oct. blacksnake i would find someone with a maf but i dont know anyone here with a wrx.
#27 |
Member#: 152449
should i still do the 3rd gear pull? btw?
#28 |
Member#: 274499
NESIC
Vehicle:2007 CGM VF'd WRX 12.9 @ 105mph |
#29 |
Member#: 274499
NESIC
Since you clearly don't understand how this forum works, I have spent my precious minutes of morning poop time, calling out to the members of the SE region. Just simply to show you how.
http://forums.nasioc.com/forums/show....php?t=2472273 |
#30 | |
Member#: 152449
#31 |
Member#: 274499
NESIC
Check out this item I found on eBay: http://pages.ebay.com/motors/link/?n...d=380565002272
#32 | |
Member#: 152449
https://docs.google.com/spreadsheet/...Wc&usp=sharing |
#33 |
Member#: 274499
NESIC
I'm going to laugh hysterically when you blow up your car.
Stop driving like an *******, you clearly have a serious problem. You need to stop reflashing your ECM. You car is trying to tell you something and by resetting you are basically telling it to go F itself. Try driving the car normal for a few days and see what your A/F Learning values do. Have you not noticed that your MAF values never exceed 150ish g/s? If you had a boost leak your MAF values would be normal, but your boost wouldn't hit target values. Your car is creating pretty severe knock corrections, even after a reflash. That right there should tip you off that you need to stop driving lick a dick. The only other thing that *COULD* create the symptoms you are seeing, is a post maf leak and a broken BCS, or a post maf leak and a severe boost leak. If the MAF isn't registering the full amount of air that is entering your intake, you could infact be running so lean that you cant even produce a full combustion inside the cylinder. If you aren't getting enough out of the engine, you wont spool the turbo so make higher boost. If you truly don't care about your engine (which you clearly don't) add your a/f sensor to your datalog. I'd be willing to bet that you don't see it ever get down near your target a/f ratios. |
#34 | |
NASIOC Manufacturer
Member#: 4803
You also have quite a bit of perceived knock in these logs, as indicated by the low DAM. You mentioned that you were running 89 octane at some point. This could certainly cause issues when trying to run a 91 octane map. This could cause the DAM to drop as you've seen. Then you reflashed the 93 octane map after filling up with 93 octane gas. If the tank was not near empty, the effective octane could also be lower from the mix of 89 and 93. At this point, I would take the car to a professional Subaru tuning shop and have them do a once-over on the car. Bill |
#35 |
Member#: 152449
thnx for the help. will do.
#36 |
Member#: 152449
*update*
cleaned maf today withe maf cleaner. it was black! also am in the process of cleaning the injectors. put some Lucas lube in it with a full tank. anything i should look out for? |
#37 |
Member#: 73884
International
Vehicle:2005 STi 2006 Evolution MR |
Were there any change in the AF Learning values and/or how the car drove after you cleaned the MAF?
Have you taken your car to anyone to get looked over yet? Last edited by jebjkey; 03-05-2013 at 05:18 AM. |
#38 |
Member#: 152449
I haven't had a chance yet due to
Finances . Feels smoother, I wanna take it this weekend. Should I run a log driving slow? |
