Old 03-04-2013, 05:06 PM   #26
the suicidal eggroll
Member#: 51961
2005 STi
Originally Posted by MWRX13 View Post
in my experience i have had the following....(i live in fairfield county ct...rural enough but not in farmland)
completely stock 13wrx sedn. - 19-22mpg driving easy on it and about 17-19 driving like a madman 24mpg on a 5th gear cruise control set at 70 / rolling in 5th between 40 and 65mph i have gotten 26-30.
Cobb AP stage 1 stock parts - 16-19mpg any way you slice it...pay to play.
what i do now is flashed my ECU to economy mode which turns down your boost to about 8PSI and rev limiter to 5K (please note: this is a lean map - you punish your car with this map and you WILL mess something up....dont bother flashing back to stock after because subaru can tell if you have messed with the edu.) this allows me about 22-25mpg when i want to turn it up i do a real time flash (takes about 3 seconds) and voila boost for all.
as far as 91vs93....the cobb AP lets you do it efficiently...no matter how you slice it 91 burns lower temp then 93....this is for people that love their engines more then vagina...which i sometimes do. but people in CA will run 91 forever.
if you want really good gas mileage - go buy a honda.
What on earth are you talking about?
1) A stage 1 tune does not lower gas mileage unless you are always going WOT. Neither does stage 2. If you don't use the additional power, you don't use the additional gas.
2) The economy tune is a complete waste of time and a marketing gimmick. Use your right foot to control fuel consumption, you'll do a much better job than that POS ticking time bomb of a tune.
3) A real time flash does not set all of the tables properly, only those that are explicitly specified. Be very careful going WOT with just a real time tune running on top of an economy base map, because there could still be a few "economy map" tables that are in effect.
4) 93 does not burn hotter than 91, and 91 is not for protecting the engine. The octane rating essentially tells you how controllable the burn is. 87 is like the fire swamps in the princess bride, it's going to ignite somewhere, but you don't know when or where. 93 still sucks, but is better. Race gas is like a bunsen burner, you know exactly how it's burning, where it's burning, how hot it's burning, and where the flame front is moving. It's controllable, slower, and can you can get much more aggressive with the tune without the risk of the air/fuel mixture exploding for no damn reason during the compression stroke and blowing a hole through your piston.
Old 03-05-2013, 08:04 AM   #27
SpamBot
Member#: 287534
Originally Posted by TryHonesty View Post
I would say most of the drives have been around ~30F or so, yes, from a "cold start", I let it warm up about 5mins before driving.
Lets see: 10 mile drive, stop and go traffic, with a 5 minute warmup from cold start in ambient temps around 30 deg F.
I'd say you're getting pretty good MPG for those condtions.
SpamBot is offline   Reply With Quote
Old 03-05-2013, 08:27 AM   #28
nightdown fox
Member#: 309636
2012 WRX Limited
Plasma Blue Pearl
^ yep, this. Although the "stay outta boost" portion if this thread has some legitimacy too. Eeked a few more mpg out when I bought a boost gauge.
nightdown fox is offline   Reply With Quote
Old 03-05-2013, 08:35 AM   #29
Wrexflex
Member#: 326301
2012 wrx sedan-stg2+
red
I tested this yesterday on my 15-mile, city drive home from work and when I pulled in the driveway I was sitting at 27.5 MPG, keep in mind I was very light on the throttle. I hit a good amount of stop lights too. Stage 2
Wrexflex is offline   Reply With Quote
Old 03-05-2013, 08:56 AM   #30
leach0789
Member#: 210903
2002 Wagon/97 Miata
Nitrous Rhodes
Drive it for a full tank, not 10 miles, then report back.
leach0789 is offline   Reply With Quote
Old 03-05-2013, 03:13 PM   #31
Trustkevin13
Member#: 259184
2008 Subaru WRX
yup, i usually get 21-22 average with both the city (lots of it), and highway (lots of this as well). but on the very flat roads, i get about 29-31 mpg at stage 2 going 65-68. its pretty nice. I'm currently at a "stage 2" set-up. hopefully it wont change to much after i swap in a vf52 and ebcs+tune. i dont think it will though.
Trustkevin13 is online now   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 01:50 PM.
