Old 03-04-2013, 10:49 PM   #1
USAMPDUFFY
Member#: 268849
Default stuck in test mode? and tune question....
Question #1:
I threw a stage 2 base map on my 02 WRX the other day from a new AP(my old one was stolen). I plugged in the test mode harness to sync my AP and then I removed it after the sync, however my car still has a flashing CEL. How do I get the car out of test mode? I don't have any performance related issues other than the eplileptic seisures the CEL gives me at night...lol, jk
Question #2:
How do I go about getting a tune through Cobb for all of my mods? On Cobbs website it states that the stage 2 base maps were for an intake and cbe. I have a Agency Power Header, Inividia Uppipe, Downpipe and CBE. Perrin turbo inlet and the Cobb Shortram so I'm sure theirs room for improvement I just don't want to dyno tune until i have my wlabro, 800cc's and VF39 on. . .So what the question sums down to is, Is it possible to get a more advanced map through Cobb without datalogging?
USAMPDUFFY is offline   Reply With Quote
Old 03-04-2013, 11:03 PM   #2
jebjkey
Member#: 73884
Chapter/Region: HIIC
16 HyperBlue STi
16 Crystal White STI
Originally Posted by USAMPDUFFY View Post
Question #1:
Did you disconnect the green plugs?
Question #2:
Stage 2 requires a DP (or TBE), not just a CBE. You are fine running your headers and UP on a stage 2 OTS map until you get the rest of your parts and a protune. Cobb only provides OTS maps for free and they do not e-tune. There are no "more advanced" maps available for download from Cobb, only protunes on a dyno at one of their shops. You can get an e-tune from one of several tuners for a reasonable price if you like and then when you install the rest of your parts hit the dyno for a protune. I am not sure who your are going to get protuned on the dyno with, but they might offer e-tunes also. You could check with them, maybe they can cut you a deal on the pricing for an e-tune now followed by a protune on the dyno later.
jebjkey is offline   Reply With Quote
Old 03-04-2013, 11:05 PM   #3
jebjkey
Member#: 73884
16 HyperBlue STi
Also, I assume you unmarried your ECU from the stolen AP (with Cobb's help) and married the ECU to the new AP.
If not, I am sure Cobb will chime in, but I would contact them to see what your options are.
Old 03-04-2013, 11:08 PM   #4
USAMPDUFFY
Member#: 268849
Yes, I disconnected the green Harness, I'll try to reconnect it and disconnect it in the hopes that it randomly works.
As far as the tune goes, thanks. My tuner runs about $350 or so based on the amount of dyno pulls i take, I wasnt sure if I could get a limp mode tune so I didnt have to pay for installation on top of a tune but its looking that way!
thanks for the help btw!
Old 03-04-2013, 11:26 PM   #5
USAMPDUFFY
Member#: 268849
I did NOT have Cobb's assistance with unmarrying the AP...that may be my issue! guess I'll have to wait until tomorrow for Cobb!
Old 03-05-2013, 08:16 AM   #6
Cobb Tuning
Member#: 4803
Question #1:
Question #2:
Is this a version 1 (black brick-shaped device) or version 2 (gray with color screen) Accessport? The version 2 Accessport will recognize the old install from the old Accessport and there will not be a problem in installing over it.
Did you run the install process on the Accessport ("sync" as you described it)? Was there any message that the process was complete? I would try to reflash a different map (temporarily - say a lower octane map just as a test) to the car to make sure that the reflashing process completed properly and that the Accessport can still communicate with the ECU. If that all checks out and you are sure you are disconnecting the correct test mode connectors, disconnect the car's battery (neg. terminal) for a few minutes and see if that fixes the problem.
Bill
Old 03-05-2013, 04:41 PM   #7
USAMPDUFFY
Member#: 268849
Bill
Sorry I didn't specify which version I had, I had a V2 and overwrote the V2 with a new one. It allowed me to pull my Stage 2 93 oct tune so I have that on right now, I'll upload the other stage 2 tunes and reflash like you said...thanks Bill.
