Old 03-04-2013, 10:33 PM   #1
bizarro252
Member#: 336417
2008 STi
Default What is this? A clutch return spring of some sort?
Hi All,
Just taking a look over everything since I just got my car back from the shop and notice this spring that looks to maybe connect to the clutch arm but it is just hanging out - does this need to be connected? I have an Exedy twin disk in there if that matters at all on if it should be connected or not...
This pic is looking down at the tranny right behind the throttle body, about halfway between it and the firewall.
Last edited by bizarro252; 03-04-2013 at 10:34 PM. Reason: Added detail on pic orientation
bizarro252 is offline   Reply With Quote
Old 03-05-2013, 02:21 AM   #2
mod maniac
Member#: 300551
2002 DD wgn 6 spd
2.1 kel 272's meth 2.5xtr
Yes that spring goes to the clutch arm.
Old 03-05-2013, 09:24 AM   #3
leecea
Member#: 37359
2003 WRX
Maybe it's just the angle of the picture, but it looks like the hook on the end of the spring is barely there - did part of it break I wonder?
leecea is offline   Reply With Quote
Old 03-05-2013, 09:29 PM   #4
bizarro252
Member#: 336417
2008 STi
Could have, its just a small hook, about a 180* bend, doesn't seem to have a place to 'click in' to the arm where it looks like it goes... Might try grabbing a new one and see if it fits - are these important? Does it make clutch feel better?
Old 03-05-2013, 10:02 PM   #5
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It "clicks into" the arm through the little hole near the top.
Not a clue if it's really necessary...based on the direction the slave cyl piston moves and the way the arm moves the TOB relative to the pressure plate, I'd say that spring does basically nothing, but having never tried it without the spring I can't say for sure one way or the other. If I had to throw out a wild guess, I'd say its purpose is to keep the TOB from riding on the PP when you're off the clutch.
Old 03-05-2013, 10:09 PM   #6
Cois32
Member#: 294755
2004 Impreza WRX
im in the middle of bleeding my clutch and noticed that same spring on my car looks really old. does anyone know if the dealership would carry this part?
Cois32 is offline   Reply With Quote
Old 03-05-2013, 10:14 PM   #7
vision.dynamix
Member#: 139955
# OneBoston
The spring hooks into the hole in the clutch fork.
vision.dynamix is online now   Reply With Quote
Message Board Statistics All times are GMT -4. The time now is 12:01 PM.
