Old 03-06-2013, 02:20 PM   #16501
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Originally Posted by sgoldste01 View Post
I believe you will also need end links, since your base Impreza has no RSB at all.
For those of us upgrading a 16 mm RSB to a 19 mm RSB, we can continue to use our existing end links, and just replace the bar and bushings. But the base Impreza has no bar, and therefore has no end links.
I'm sure someone will correct me if I'm wrong about this.
You are correct. They have no end links
Old 03-06-2013, 02:42 PM   #16502
MACaMillion
Member#: 313534
2012 Impreza
Satin White Pearl (WHI)
If someone wants to buy my stock 16mm RSB, PM me. No endlinks, just bar.
$50 OBO.
-Jeff
MACaMillion is offline   Reply With Quote
Old 03-06-2013, 03:06 PM   #16503
tspunk
Member#: 345444
2013 Impreza 5-door
I will also have a stock 16mm RSB for sale by end of March (no endlinks). PM me if you will want one and want to make me an offer on it. Even better if you're in Boston or surrounding states.
(not to step on MACaMillion's toes. Go to him first).
tspunk is offline   Reply With Quote
Old 03-06-2013, 03:28 PM   #16504
danstheman7
Member#: 331089
2012 Impreza Base
DGM/Dark Grey Metallic
Would someone mind explaining how to installed the RSB?
I have a base, so I have no bushing or end links or any of this. I was looking at the 19mm, as I do a lot of highway driving and wind kind of knocks the car around a bit.
And I have the hatch, if that affects the instructions.
danstheman7 is offline   Reply With Quote
Old 03-06-2013, 03:37 PM   #16505
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I was just on eBay, and saw a 15k mile service kit that included the oil, oil filter, air filter, and Positive Crankcase Ventilation (PCV) valve.
http://www.ebay.com/itm/Subaru-Impre...72b432&vxp=mtr
Is the PCV really something that gets replaced every 15k miles?
Old 03-06-2013, 03:38 PM   #16506
Zeeper
Member#: 299286
2017 Legacy Limited
http://www.perrinperformance.com/sha...0newmounts.pdf
http://www.perrinperformance.com/sha.../pspsus237.pdf
I am pretty sure if you buy it new from a reputable dealer like Perrin they will send you instructions for the install.
Old 03-06-2013, 03:42 PM   #16507
foghelmut
Member#: 328414
2012 Impreza SP 5MT
obsidian pearl black
On other cars, I used to replace mine once a year. Air filter too. I guess that would be 15k miles for most drivers? Never really thought about it mileage-wise.
foghelmut is offline   Reply With Quote
Old 03-06-2013, 03:44 PM   #16508
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
I've never seen a pcv go bad
Old 03-06-2013, 03:52 PM   #16509
danstheman7
Member#: 331089
2012 Impreza Base
man, it looks like a pain to install the rsb!
i don't even have jacks or anything ._.
Old 03-06-2013, 04:19 PM   #16510
aeoporta
Member#: 334126
2016 2.5i Premium MT
Dark Gray Mettallic
if I were gonna do the pcv I would do it at 30k when I am doing spark plugs, cleaning maf and throttle body, oil, tranny & diff, coolant, brake fluid, cleaning k&n. Apart from that 15k, nah.
Old 03-06-2013, 04:20 PM   #16511
Angelus911
Member#: 89967
2012 Impreza Sport
You have the base, so it might be different, but others have said you're NOT supposed to use jacks, as you want weight on the wheels when installing the RSB
Old 03-06-2013, 04:25 PM   #16512
saabarupp
Member#: 189032
2015 STI CWP
'12 Impreza Sport Ltd DGM
Originally Posted by averagewhiteboy View Post
Guys, question for you..
So, today my area got hit with some of the snow attacking the north east. It was a very fat, thick snow. In terms of traction, the car was amazing. Never slipped or hesitated once. However, I did have two things I wanted to ask. Not really "concerns", but figured I'd ask..
1) The ABS on this car seems to be super touchy. Never noticed it before. It may have been the overly chunky snow, and/or the iffy-at-best stock Yoko's. But the car kept wanting to jut to a stop.
2) Seeing an opportunity, I pulled into an open parking lot (no one around, 2:30am..lol), tapped the traction off button, and attempted to fling the car around a few times. If I tried to mostly finagle it using the throttle, the car kept trying to self-countersteer. If I pulled the e-brake and let it carry it's self around, it'd slide, but then again self countersteer. This, again, was with the traction button pressed to off. Is this "normal"? I mean, of course the car being used for normal conditions and situations should be driving straight and not swinging around.. But I figured that by turning it off, most of the nanny stuff should be off. It was rather disappointing.
Again, not sure if it was just this thick snow or what. I've done a couple tiny swing arounds before and it's worked good. But trying to actually do it tonight didn't work out too well. Is there some kind of extra traction control thing or variation of VSC I'm missing? I'm used to poking the VSC button in my Si and it letting me do what I want..
In addition, is the touchy ABS mostly just the tires? I realize they're iffy tires, and narrow at that. Didn't really think snows are necessary in these cars for a couple inches of fat snow. lol Would even just a wider, better all season help?
For reference, the car is a 13 Sport with CVT and 2k on the clock, with stock tires.
It's the tires. My wife's Imp has winter tires and the ABS intervention is not frequent as a result. As for the traction control... well, the car is very good at keeping you straightened out, on or off.
saabarupp is offline   Reply With Quote
Old 03-06-2013, 04:28 PM   #16513
Zeeper
Member#: 299286
2017 Legacy Limited
If you need to install the rear sway bar and the bushings and endlinks I would find a friend who has some basic tools (like a jack and jackstands) to help you.
It can probably be done with the car on the ground, but most people doing that are probably just swapping out the sway bar that is on their car for a stiffer version and reusing parts from the old one.
Old 03-06-2013, 04:30 PM   #16514
scoutisimo
Member#: 315759
2014 WRX Hatch
Lightbulb
To my fellow base models:
I purchased the oem rsb and endlinks here and just finished sourcing the other parts.
You will need the following: (prices are from local dealer, I will be checking Subaru Genuine Parts for a better deal)
Clamps Part# 20466fg000 (2) at 6.40 each
Bolts for Clamps #010108200 (4) at 4.18 each
Endlink Bolt # 901000360 (2) at 4.68 each
Endlink nut # 902370055 (2) at 2.05 each
Old 03-06-2013, 04:40 PM   #16515
scoutisimo
Member#: 315759
2014 WRX Hatch
It's $10 cheaper to order through subaru genuine parts After shipping is added.
Old 03-06-2013, 05:19 PM   #16516
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Anyone have a DIY or a pic of under the car where you have to go to access the fog light bulb? I got my new ones in, and I'm doing those, my highs, and my HID lows tomorrow..
Old 03-06-2013, 05:32 PM   #16517
MACaMillion
Member#: 313534
2012 Impreza
No worries, mine is available now and i prefer bay area/west coast. (shipping cost)
Old 03-06-2013, 06:31 PM   #16518
scoutisimo
Member#: 315759
2014 WRX Hatch
So Perrin would'nt price match their BRZ stubby antenna with the eBay seller who sells them new for the same price but with free shipping. (Perrin charges 7.00)
I tried to tell the live help that Jeff Perrin is my uncle... that didn't work. So I bailed on it.
Old 03-06-2013, 07:31 PM   #16519
WStrembitsky
Member#: 323877
2012 Impreza Limited
Their website showed it was going to add the shipping when I purchased mine but didn't actually charge me when I finalized the order.
WStrembitsky is offline   Reply With Quote
Old 03-06-2013, 10:05 PM   #16520
Dirt Bringer
Member#: 340297
2013 Impreza 5sp Prm
Ice Silver
So...someone lifted their impreza with some XV struts and springs. Yes this is legit:
http://i.imgur.com/SkAUMnV.jpg
And I have a feeling its one of us.
Dirt Bringer is online now   Reply With Quote
Old 03-06-2013, 10:14 PM   #16521
kinger37
Member#: 324423
2012 Impreza Sport
ISM
^^needs more tire
kinger37 is offline   Reply With Quote
Old 03-06-2013, 10:19 PM   #16522
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
So I made some calls today using the hands free system and my new cp635u radio and everyone I talked to said I sounded clear even doing 70 mph. So with the same factory Mic/location there is definitely better circuitry in the actual head unit.
Old 03-06-2013, 11:01 PM   #16523
jsteg
Member#: 329271
Ice Silver Metallic
Yes the traction control is never fully off. Subaru doesn't trust us. It is a rather buzz kill.
Actually it is...VDC kicking in is what he was experiencing.
Old 03-06-2013, 11:13 PM   #16524
Commander Keen
Member#: 319157
2012 Impreza 4DR 5MT
PCV isn't anywhere on the maintenance schedule, and the air filter replacement interval is 30K mi.
Old 03-07-2013, 12:05 AM   #16525
averagewhiteboy
Member#: 345877
2013 Impreza Sport
Ice Silver
Well whatever it is, it's stupid. lol Whatever happened to the days where cars weren't controlled by all this dumb stuff and people just knew how to drive.
2012 Impreza STI concept art khaki_man Member's Car Gallery 37 03-15-2011 02:02 AM
Newsflash: 2012 Impreza looks like BigElm's Butt WagonMonster Off-Topic 4 02-28-2011 07:11 PM
2012 Impreza Concept Zakster87 General Community 14 11-17-2010 04:09 PM
