Old 03-06-2013, 07:12 PM   #1
mopar3.0
Member#: 261696
2004 wrx
red
Default Shifter linkage bearings ,my experiment
Measured the busings from my sti and found these bearings on e bay.
At a cost of 8 dollars i wanted to try some cheap ones before sourcing out some quality pieces,
The shifter its self will have to be drilled out to fit the beaings, it appears to be about 1mm too small.
Any one every try anything like this?,debating on maby adding some grease nipples to the housing too.
car is still in pieces and snow is still on the ground so won't be any testing for couple months.
mopar3.0 is offline   Reply With Quote
Old 03-06-2013, 07:25 PM   #2
AR-45ACP
Member#: 204360
06 wrx
Bearings are always better than bushings in almost every application that I know of so I would say you are on to something!
AR-45ACP is offline   Reply With Quote
Old 03-06-2013, 07:59 PM   #3
classicaddict
Member#: 220619
04 wrx wagon
I don't think bearings are a good idea. You need some side to side give so nothing binds up, stiffer bushing from mc master would be better.
classicaddict is offline   Reply With Quote
Old 03-06-2013, 08:06 PM   #4
the small amount of movement there may not be enough to make much difference
but it might
and grease nipples would be a waste of time if the grease used initially was of good quality
there is no need to regrease that application, i should think....and sealed bearings wouldnt ever require it anyway
what bearings, exactly, are those???
Old 03-06-2013, 08:13 PM   #5
mopar3.0
Member#: 261696
2004 wrx
red
http://www.ebay.com/itm/10pcs-F698zz...item2321602fcd
I have yet to see to see if they make the assambley any thicker,causing it not to fit in the "fork" will do this week,
They are very cheap if they last 2 summers i would be dam happy
Old 03-07-2013, 08:50 AM   #6
here is a site that has a bunch of bearings
http://www.vxb.com/ballbearings.html...Fad_QgodmXQA1w
which dimention is not quite right on the ones ya got off ebay
Old 03-08-2013, 06:19 AM   #7
mopar3.0
Member#: 261696
2004 wrx
red
they do fit, needs small washers on both side on out side, gona use copper crush washers ,
if not the fork will bind up on the out side part of the bearing when you thighten it down
Im also thinking about a spacer between the 2 bearings so you dont side load the bearings when you also tighten it down
(just trim the sleve from the old bushing set up)
Old 03-10-2013, 03:46 AM   #8
keep us posted on this and what ya do to make it work
Old 03-10-2013, 02:00 PM   #9
stephens
Member#: 124581
I was going to take mine apart this summer to see if I could change something and this looks like it would save me some trial and error.
Definitely keep us posted as to your findings.
Do you have any other shifter/shifter bushing upgrades?
stephens is offline   Reply With Quote
Old 03-31-2013, 12:29 AM   #10
DuckStu
Member#: 124060
2004 WRX STI
You may well need to make a spacer tube to go inside between the two bearings inner races,.. otherwise the clamping load of the bolt will be putting a tremendous side-thrust on the bearings.
The spacer would need to have washers welded on either end to keep it centered so you can get the bolt started.
Much the same as how motorcycle wheel bearings work. They have a spacer tube inside them.
DuckStu is offline   Reply With Quote
Old 04-07-2013, 09:49 PM   #11
mopar3.0
Member#: 261696
2004 wrx
red
Just finished and installed it today. and yes i cut the old tubes that were in the original bushings,
i also had to use thin washers on the bolts inside the u brackets so the bracket would not bind up the outside of the bearing.
The shifter feels great,like its its part of the gear box like a mustang or 240
also added about 1/2-3/4 of a inch to the bottom on shifter , Its now about 3.5 inches between each gear!
Old 04-07-2013, 10:08 PM   #12
yeah....the torque value for that bolt is like 8ft-lbs...not much but still....
Old 04-07-2013, 10:10 PM   #13
The shifter feels great,like its its park of the gear box like a mustang or 240
d0000000000000000000d....i hate to ask but......
take it all apart and take pics and post them......otherwise, nobody will want to attempt this....well...i will, but....
Old 04-08-2013, 06:16 AM   #14
mopar3.0
Member#: 261696
2004 wrx
red
lol its pretty easy.
you need a 7/8 drill bit to drill out the bore In the shifter, I am in a rush to get my car in one piece as summer is coming, so no pictures . Hoping u will try it and do a proper write up
Old 04-08-2013, 05:07 PM   #15
stephens
Member#: 124581
What other modifications have you done to your shift linkage? I'm just curious to how it compares to other modifications that have been done.
Old 04-08-2013, 05:21 PM   #16
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Originally Posted by AR-45ACP View Post
Bearings are always better than bushings in every application that I know of so I would say you are on to something!
Better in every application? What about cost? I'm sure bushings were cheaper than bearings for Subaru to spec, manufacture and install.
Also, what about poor weather and salt-spray testing? Even sealed bearings have a hard time resisting salt spray. Bushings, however, don't have near as much trouble. You'll rarely find a seized bushing, but bearing seize all the time for a variety of reasons.
And then there is NVH (noise/vibration/harshness). Most people do not want to feel the intimate inner workings of their transmission when they shift. They also don't want to hear it. Bushings help to isolate some of the harsher frequencies from the driver and cabin. Again, this is most likely why Subaru spec'd bushings in this application.
I agree, I would love to see bearings in this particular application, but to make a blanket statement that they are better in every application without considering design goals/constraints is silly.
