Old 03-03-2013, 04:03 PM   #26
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by subi-T View Post
Hey guys I hope I can get some help here, I have a 2002 subaru wrx and a mechanic replaced my clutch but now it won't turn on only when I put starting fluid??
Any help? Thanks
Take it back to your mechanic? If it started up fine before the clutch replacement and doesn't afterwards, your mechanic should fix it free of charge.
Old 03-03-2013, 04:44 PM   #27
EJ20cosworth
Member#: 253551
2009 Sti
Originally Posted by SnowmanFX View Post
Check your compression.
Air
Fuel
Spark
Compression
Timing
Exactly. Check for unplugged connectors, just look over everything with a fine tooth comb before you start digging around.
EJ20cosworth is offline   Reply With Quote
Old 03-03-2013, 09:44 PM   #28
subi-T
Member#: 348082
2006 impreza
SGM
I have found a unplugged connector under the fuel regulator its not for the injectors I can't find where it goes. I have pictures but I'm using my phone and don't know how to post pics. I took it to the mechanic and he's giving me a real hard time.
subi-T is offline   Reply With Quote
Old 03-03-2013, 10:08 PM   #29
EJ20cosworth
Member#: 253551
2009 Sti
I just saw this, if no one else chimes in, I will take a look at what connectors are around there. What's the color and amount of pins?
Old 03-03-2013, 10:40 PM   #30
recce02
Member#: 13815
02 GCRally prepped
277TQ 281HP 19PSI
Might be tgv plug?
recce02 is offline   Reply With Quote
Old 03-04-2013, 12:23 AM   #31
subi-T
Member#: 348082
2006 impreza
SGM
What is that plug used for. I read it can be deleted but why
Old 03-04-2013, 02:11 AM   #32
subi-T
Member#: 348082
2006 impreza
SGM
The connector is gray and inside its Orange it has 2 pins it looks similar to the fuel injector connector, its also wired along the same bunch of wires that connect on the right side fender. Thanks
And hues what! Don't make fun of me but I found out why it didn't start, ready?.... the intercooler was not connected :'( lol
I'm an idiot but the mechanic said it does not need to be attached to start the car but I new it did so when he left I attached it and bam!!!
Old 03-04-2013, 10:47 AM   #33
nhat
Member#: 140163
03 STi
hellaflunctional
Please learn how to. It'll help us all out. Use Photobucket or Imageshack to host then post the link here.
Old 03-05-2013, 05:37 AM   #34
EJ20cosworth
Member#: 253551
2009 Sti
Figure it out?
Download the photobucket Mobil app. It will upload photos out of your pictures that you select. You then click on the ! Icon on the bottom right of the screen for image code. It auto copy's the link and then you just post the link here.
Old 03-05-2013, 10:46 PM   #35
02suub87
Member#: 311634
I had this problem shortly after my build on my car. I started panicking and double checked everything. turned out that my Crank and Cam Sensor were both loose. Maybe check that? best of luck
02suub87 is offline   Reply With Quote
Old 03-06-2013, 10:38 PM   #36
Legatron02
Member#: 295810
98 LGT EJ205 swap
Spruce Pearl
Any help? Thanks
Your probably not getting fuel... check your fuel pump and filter
Legatron02 is offline   Reply With Quote
Old 06-18-2013, 03:43 PM   #37
TykoSubs
Member#: 324900
Chapter/Region: PRSIC
2005 Impreza
Crown Blue
hey guys, can i get some rescue please! my 2005 Impreza RS2.5 wont start. The interior electronic accessories do come on, but when i turn the key to ignition nothing happens, literally. Battery's good and I've checked all the fuses.
Thanks in advance for any suggestion of what might be happening
TykoSubs is offline   Reply With Quote
Help Help *wrx Wont Start* Help Help hawaiifosho Newbies & FAQs 11 05-27-2011 08:22 AM
02 wrx wont start after timing please help ej20wagon02 Service & Maintenance 6 04-03-2009 02:05 PM
Help 03 WRX wont start after new battery! newgensti Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 01-20-2009 01:58 AM
Help My WRX wont start! Jokoso Newbies & FAQs 9 10-30-2002 10:02 AM
need help wrx wont start Brewmaster New England Impreza Club Forum -- NESIC 8 06-15-2002 09:06 PM
