Old 03-05-2013, 06:20 PM   #1
Boostedbob
Member#: 336241
08 Sti
OPB
Default Perrin inlet install issues
Hey guys I am having a few issues with my install, The bulge were the BPV nipple is molded into is hitting against the coolant(?)hard line where I cant fully seat the inlet onto the turbo. If I angle the inlet a bit up I can get the nipple on bpv to rest against the hard line but can not get the inlet to seat all the way with out it having a slight bulge where it again will not seat all the way,
I can get the inlet to seat all the way by angling the bpv nipple facing down but then will not be able to get the bpv hose on. I am at a loss and with me trying to get the inlet over the turbo it is starting to wear. Was there any tricks you guys tried doing to get it to seat fully? I did try to use hair spray to help it slip on worked great until the bulge forms.
Thank's.
PS also talked to perrin and they said to crush the inlet a little, I did that and it did not work.
Boostedbob is offline   Reply With Quote
Old 03-05-2013, 08:50 PM   #2
jziegler
Member#: 275858
2004 Wrx Sti
Java Black Pearl
Those are a super pain in the ass to install.
jziegler is offline   Reply With Quote
Old 03-05-2013, 09:05 PM   #3
Boostedbob
Member#: 336241
08 Sti
OPB
Yeah I was at it for 3 hours the old one came out no issue didn't break anything on it. Even getting it put in is cake, but getting it to seat argh such a pain.
Last edited by Boostedbob; 03-05-2013 at 09:13 PM. Reason: I dont know how to spell
Old 03-06-2013, 04:28 AM   #4
NJ_wrx
Member#: 268855
2009 WRX
red
I heard the v2 turbo inlet pipes addressed the hardships that was associated with the install. OP is your inlet used? It might very well be a v1.
NJ_wrx is offline   Reply With Quote
Old 03-06-2013, 09:20 AM   #5
Leafy
Member#: 330625
2006 WRX
That coolant tube is really easy to bend. I had to bend it a good bit to fit my MR inlet.
Old 03-06-2013, 09:39 AM   #6
Boostedbob
Member#: 336241
08 Sti
OPB
Nope brand new straight from Perrin.
Leafy I was thinking of taking off the bolt that is holding that hard line, I tried bending it but no leverage, ill give it another shot though
Old 03-06-2013, 09:40 AM   #7
Leafy
Member#: 330625
2006 WRX
I may have used the screw driver that fixes everything (the big flat head from HF) and pried against the turbo.
Old 03-06-2013, 09:49 AM   #8
gtasti
Member#: 152036
2004 Sti
Not the easiest way but removed ur manifold and remove the coolant tube with rubber hose
gtasti is offline   Reply With Quote
Old 03-06-2013, 10:21 AM   #9
Boostedbob
Member#: 336241
08 Sti
OPB
Wish I could figure out to multi quote lol, anyways the removing the manifold will be a last resort as I do not have all the tools I would need to remove it.
Leafy which part of the turbo did you pry on to bend the coolant line? I just need about a half inch to get the inlet to fully seat.
Old 03-06-2013, 10:23 AM   #10
Leafy
Member#: 330625
2006 WRX
I dont remember, just stick it in there and figure it out.
Old 03-06-2013, 10:32 AM   #11
Boostedbob
Member#: 336241
08 Sti
OPB
Okay once it warms up a little more ill go work at it again, thanks for the help all! Ill post a update and pictures when I get it to fit.
Old 03-06-2013, 12:55 PM   #12
Manimal
Member#: 124291
2011 WRX STI
Spray some WD-40, helps it slip right on.
Manimal is offline   Reply With Quote
Old 03-06-2013, 01:20 PM   #13
tom312
Member#: 261936
2006 WRX STi
I blasted it with lithium grease and was able to get it on after a lot of wiggling and busted knuckles
tom312 is offline   Reply With Quote
Old 03-06-2013, 04:32 PM   #14
rallyweapon11
Member#: 318306
not sure if thats the best idea, but thats the approach you need to take. blast the crap outta it with warm soappy water. i kept a bottle on hand for my install so i could continously spray it. it's a wicked PITA to get in, just make sure you get it fully on the turbo.
rallyweapon11 is offline   Reply With Quote
Old 03-06-2013, 07:33 PM   #15
Boostedbob
Member#: 336241
08 Sti
OPB
I ended up using Hair spray to get it further on, Its still barely on but it has seated, I said screw it and clamped it down and took it for a test drive. Everything looks great, Was a pain in the ass but I am happy that it is done.
Now I have to figure out why my tmic is popping off the throttle body, Just got some new clamps so hopefully it will hold better. Thank's for everyones help!
Oh i was tuned at 19.5psi of boost and am now hitting 20.1 psi is this due to the inlet? No vac leaks and no boost leaks as far as I can tell.
Old 03-06-2013, 08:17 PM   #16
NJ_wrx
Member#: 268855
2009 WRX
red
That is barely on there. If its got a good seal that's all that matters. Grats!
Old 03-06-2013, 08:49 PM   #17
S1CkWrx
Member#: 325249
2012 wrx
dgm
the TB hose to IC just are prone to coming apart. its a faulty design. buy an aftermarket one they arent expensive at all.
S1CkWrx is offline   Reply With Quote
Old 03-06-2013, 10:45 PM   #18
Boostedbob
Member#: 336241
08 Sti
OPB
That was next on my list already on rsd looking at some new coupler's.
If I had to do this all over again I would probably just take it to a shop to do it. My mechanic is happy I did it though he hates doing them haha
