Welcome to the North American Subaru Impreza Owners Club Friday May 29, 2015
Old 01-04-2013, 11:49 AM   #101
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Obs Blk Prl/Drk Gray Mtl
I agree that the car should start more easily, but let's not get carried away. It starts. Be glad you don't have a VW TDI. The issues that VW has been building into those cars since 2009 leave people stranded, sometimes causing engine damage. I owned a TDI before this Impreza, so I know what it feels like to be stranded by a car with less than 30k miles on it.
So for me, I don't think that cranking the starter for 5 or 10 seconds is a show stopper. It shouldn't happen, but as long as the car starts, is it really a big deal?
I doubt it's caused by the car wash. I don't use a manual car wash. The wash I use is automatic, where it pulls the car through. I do this once or twice/week, and have only had a hard-start once (unrelated to the wash).
Old 01-07-2013, 01:04 PM   #102
kagetora13
Member#: 305389
2009 Impreza
Hi Everyone
Looks like we started seeing this on our 4 month old 2013 Impreza so I wanted to post my notes which I have provided to my dealer in Toronto. The car is parked outside all the time and is driven daily. We only use the recommended fuel (no high octane fuel).
To describe the issue this morning:
  1. Turned car on and Dash reading -8 Celsius.
  2. All dash lights light up and car radio indicator reports subaru, no warnings.
  3. Crank car over first time and engine turns over a couple times and did not starting.
  4. Wait a couple seconds and crank car over 2nd time and not starting.
  5. Crank car over 3rd time and it starts and runs for 20 seconds and shuts off.
  6. We then waited 15 minutes (while I looked under the hood:
  • Checked battery pole to make sure tight (notice it is not greased)
  • Checked Oil and fluids (looks good ... engine oil at first indicator)
  • Made sure no loose wires
  • Checked gas cap to make sure tight.
7. Turned car on and waited 2 minutes (made sure to listen for fuel pump to complete cycle). The car now started and idled high for 1.5 minutes.
I will follow up if I get a solution (As I am waiting for feedback from the service advisor).
kagetora13 is offline   Reply With Quote
Old 01-07-2013, 01:16 PM   #103
Haunty
Member#: 319378
2012 2.0i Sport Ltd.
Has anyone else tried the premium fuel trick? I might but it happens so rarely in my case so far.
Haunty is offline   Reply With Quote
Old 01-07-2013, 02:21 PM   #104
kagetora13
Member#: 305389
2009 Impreza
In regards to the premium fuel trick,
I really don't understand the logic with this. Condensation in the tank freezing is the most common issue which causes fuel related issues. Premium (high octane fuels purpose is to not prematurely ignite when the engine is running at high temperatures. The best way to avoid condensation is to keep the fuel tank full to keep out the air.
My dealer (Brampton Subaru) did a service record check and did not see any reported issues relating hard starts in cold weather. So I think it is best we report the issue to the home dealership and make sure it is recorded.
Suggestion from dealer:
One thing that may help is that when starting the car is when turning the key leave it in the on position for 4-5 seconds before going to the start position, this allows the engine throttle control servo to cycle improving cold start. We may have to preform an "IDLE LEARN" which teaches the engine computer how much to open the throttle on start up.
Old 01-07-2013, 05:19 PM   #105
Caocao
Member#: 330507
2012 Impreza Ltd CVT
First failed start happened yesterday morning. The temp was -7 celsius but the car had spent the night in the garage so not a factor. So failed he first 2 time i turned the key. Third time i waited for all the lights to do their things and the car finally started. I have about 12000 km on the car so far.
Caocao is offline   Reply With Quote
Old 01-08-2013, 01:56 AM   #106
djupstromj
Member#: 342923
try replacing the plugs
djupstromj is offline   Reply With Quote
Old 01-08-2013, 06:53 AM   #107
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
What makes you think this would be the solution, on a relatively new car?
Old 01-08-2013, 12:30 PM   #108
Caocao
Member#: 330507
I'm not planning to replace anything at this point, just observed and if it reoccurs all that the car to the dealer.
Old 01-09-2013, 09:54 AM   #109
jay25RS
Member#: 4273
2011 GR-STI
& 2015 Legacy Ltd.
I had my 2nd hard start event this morning. 28 deg F out. I let the gauges do their sweep and then while cranking it took a while for it to start. Once started though it was like normal; that is no rough idle or any of that.
jay25RS is online now   Reply With Quote
Old 01-09-2013, 10:05 AM   #110
Angelus911
Member#: 89967
2012 Impreza Sport
Just saw this thread bump, I had my first hard start with just over 10k on the odometer. I turned the key, it barely started, and then about a second later it "caught" and the rpms seems to be normal.
Old 01-09-2013, 08:09 PM   #111
G-Omaha
Member#: 209172
2012 Impreza CLL
BL2
When it is at or near freezing, I use the remote starter. Never has failed to start. Only time that I experienced a "non-start" at the first attempt was on my 2008 OBS, and that was caused by a misfire on all cylinders (cold morning @~40 F). Dealer isolated case of the misfire to be water in the gas tank (filled up at a station that I normally don't use - and will never use again).
Old 01-16-2013, 08:49 AM   #112
osilus
Member#: 343794
2013 Imperza Sport
Originally Posted by Xafen View Post
I was just browsing all the TSBs and saw this:
Service Bulletin # 11-124-12
Bulletin Description: This bulletin will provide an inspection and repair procedure for camshaft position-related and/or engine misfire DTCs for 2.0L FB engine-equipped 2012MY or later Impreza and XV Crosstrek models. In addition to a Check Engine light coming on, there may or may not be customer concerns of rough idle, extended cranking or no start. The camshaft position sensor clearance may be out of specification causing these condition(s) and one or more of the DTCs to set.
Information contained in any technical document found on the STIS web site should only be used as reference material for highly trained automotive technicians. Only automotive technicians have the training and the special tools/equipment to repair Subaru vehicles.
11-124-12
This was my issue right here. Thanks Xafen for giving me the info I needed to get the service guys looking in the right direction. My issue appears to have been more severe than most I've read so far in this thread. Within a few hundred miles of a brand new 2013 Impreza Sport, I started having the same problem, only nothing in the thread seemed to make a difference. The car was most problematic to start in the mornings. As it is kept in a heated garage, temperature was never the issue. 19 time out of 20, the car wouldn't start on the first, second, or maybe third time. I also waited for the gauges to do their thing and listened for the fuel pump to complete its cycle. Didn't make a difference, also in my case, giving it premium fuel didn't help at all. After scheduling some time for the dealership to keep my car so they had ample opportunity to reproduce and mentioning the service bulletin Xafen found, they re-adjusted the camshaft position sensor with some shims, and the car starts like it should, no need to wait for the gauges, simply turn the key. After all this isn't some old diesel engine that needs time for glow plugs to heat up. It's a brand new car that should start right up without issue, and now mine does. So if anyone else is having the problem, I highly suggest mentioning this service bulletin to your service guys.
osilus is offline   Reply With Quote
Old 01-16-2013, 11:40 AM   #113
Xafen
Member#: 306398
2012 Impreza Premium
Camellia Red
Your problem definitely sounds like it was a lot worse than most of the rest of ours. Glad it got fixed!
Most of us have trouble replicating it, and for me, I'm not worrying about it, because it hasn't happened in a long, long time. If it was ever even close to as severe as you describe, it would very much warrant a trip to the dealer.
Xafen is offline   Reply With Quote
Old 03-07-2013, 08:22 AM   #114
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Had this happen today. Failed first time, second attempt took over 10 seconds to start.
Old 03-07-2013, 08:26 AM   #115
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Are you thinking about going to the dealer and seeing if they should install shims to adjust the cam position sensors?
Old 03-07-2013, 11:09 AM   #116
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
i made the appointment for monday. I plan to print off the tsb and bring it with me.
it also happened last night, but it only took maybe 4 seconds to start. this morning was excessive IMHO. we will see in a few hours when i get back and can start it again.
Old 03-07-2013, 11:13 AM   #117
sgoldste01
Member#: 322264
2012 Impreza Sp 5sp
Sounds great. I know you will keep us updated on the outcome.
Old 03-08-2013, 07:55 PM   #118
PuyallupCoug
Member#: 337092
2013 Impreza SLTD 5d
I have the rough idle problem that happens at stoplights. It randomly occurs 3-4 times a week, usually when I've been driving for less than 5 minutes. The RPMS drop the car shakes and shudders and then it returns to normal. Feels very much like a misfire. I have an appointment on the 13 to get it checked out and will present the following TSB's to the dealer
Service Bulletin # 11-125-12
Bulletin Description: This Service Bulletin will provide an inspection and repair procedure for EXHAUST camshaft position and / or misfire-related DTCs for FB engine-equipped 2012 and later MY Impreza and XV Crosstrek models with FB engines. The camshaft position sensor clearance may be out of specification causing these condition(s) and one or more of the DTCs to set. In addition to a Check Engine Light coming on, there may or may not be customer concerns of rough idle, extended cranking or no start.
PuyallupCoug is offline   Reply With Quote
Old 03-08-2013, 08:17 PM   #119
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
do you have a light on, i don't, and from reading the TSB's it isn't clear if the light will be on or not.
Old 03-09-2013, 10:55 AM   #120
SirChadimus
Member#: 335781
I have also had this problem several times with my 2012 Impreza Sport (CVT). I've taken it to my dealer twice and both times they say they can't replicate it and therefore nothing was done.
In addition to the slow start, sometimes after the slow start I get the following message on the LCD
"The vehicle dynamics control system needs to be checked".
If I turn off the vehicle and start again the car starts fine and the error is gone.
SirChadimus is offline   Reply With Quote
Old 03-09-2013, 12:06 PM   #121
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
take a picture and bring it with
Old 03-11-2013, 01:38 PM   #122
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Dealer said they couldn't duplicate the problem and there were no dtc's set. They did find an ecu update though and did that. So I guess we will see if it happens again, it hasn't since I scheduled the appointment
Old 03-13-2013, 07:24 AM   #123
flyboy1100
Member#: 314216
2012 2.0i Sport 5MT
Car was not plugged in last night (it was, but apparently my timer failed so it never activated), temp -1f and car started in under 2 seconds so the ecu programming most of done something
Old 03-25-2013, 01:46 PM   #124
GTRYDER
Member#: 351352
Default Every 600 miles
My new 2013 Impreza has 1800 miles on it and I know exactly what you all are talking about. The car takes a while to start every 600 miles like clockwork. My 05 Honda Civic did something very similar and it had something to do with the emissions system cleaning itself out. Since my Subaru only has this issue every 600 miles to the exact mile, I figure it has something to do with the PZEV systems normal operation.
Any thoughts?
GTRYDER is offline   Reply With Quote
Old 03-25-2013, 05:11 PM   #125
auskip07
Member#: 315643
2012 Impreza Sedan
DGM 5mt
You can rule out weather. I think its a sensor or fuel delivery problem. It has only happened to me 1 time in 11 months.
auskip07 is offline   Reply With Quote
going to be like driving for the first time! ThaPuertoRican15 General Community 35 12-27-2010 01:42 PM
going to autox this weekend for the first time... CiViCKiDD General Community 12 03-21-2006 06:15 PM
I'm about to ride a Harley for the first time. Sharkbait Off-Topic 48 12-01-2005 10:23 AM
im going to watch american idol for the first time Protege Menace Off-Topic 5 05-19-2005 10:35 PM
Finally got to drive my WRX for the first time in a while! MGAMAN Alaskan Impreza Club Forum -- AKIC 3 07-24-2003 08:31 PM
