Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Motorsports Specific Items
Old 01-26-2013, 05:37 AM   #1
Rod702
Member#: 132978
2004 Mike angel tund
efr 7670 1.05 Twiscroll
Default 600 whp time attack/road race wrx
This car started out as just a passion of collecting the rarest parts for time attack road racing. i have babied this car from the beginning, always garage and maintained by me. Im 31 years old, and its time to move on. Im not some punk kid who abuses their toys, this was a project i pure my blood sweat and tears in.... and a whole lot of money!
this car has put down 571 whp last year on a dyno jet with stock heads/cams at 27 psi. this year i have done a head upgrade supertech +1mm oversize intake/exhaust valves, springs retainers, kelford 272 cams and a mild bowl blend. i am going to dyno it again and it should be well over 600+ whp on e85 of course. this is car is fully prepped for road race/time attack. from engine-suspension-aero-bracing, i have not tracked yet. my plans were to just have fun with car, but have an edge. 90K miles on chassis, 40k on motor. E85 Fuel, rotella t 5-40 engine oil, motul tranny/diff fluids.
MODS LIST AS FOLLOWS
ENGINE
* (RARE) Last 1 out of a batch brand NEW ej22t 2.2L closed deck block made before discontinued, not some junk 80k-200k mile used ej22t block. phase 1 2.5 crank making it a 2.35L, Pauter rods, CP pistons. ARP head studs, blue/printed balaced (drac9) @ revolutionsperformance in colorado
* Killer bee oil pan, killer bee oil pick up, killer bee oil baffle
* zerosports thermostat
* 2005 sti heads, supertech +1mm oversize valves exhaust/intake springs and retainers, mild bowl blend. 272/268 Kelford cams. New cometic head gaskets, water pump gates kevlar time belts (changed during head upgrade 07/2012) new buckets and shims.
*Jdm Spec C TGV
* Tigwerks (kelly) Twinscroll up pipe/downpipe 321 stainless steel, jdm twinscroll manifold, twin 38mm (21 psi springs) black wastegates all wrapped in heat shield lava wrap.
* GTX3582 turbo billet wheel/extra fin, genuine garret T4 .84 divided twinscroll hotside vband. wrapped in T4 flange heat shield lava wrap
* JIC spartan full 3" titanium catback
* Full Race reverse intake manifold FMIC 700+hp setup, tial blow off valve
* 2L surge tank, aeromotive topfeed fuel rails, aeromotive fuel pressure regulator, aluminum fittings/high pressure fuel lines with perrin pyro thermal shielding.
* 3x bosch 044 fuel pumps. 1 in fuel tank, 2x running off of surge tank.
* id2000 injector dynamics
* Greddy oil cooler/thermostat
* Koyo Race thick radiatior
* Crawford AOS FMIC 2 generation
* Relocation of battery to trunk, Optima Red
* Cusco engine/tranny mounts
DRIVETRAIN
* PPG andrewtech built 5 speed transmission 1-4 helical gear (slightly longer gear ratio) oem 5th gear,
* tripple exedy clutch ceramic plate
* ACPT carbon fiber driveshaft
* Sti LSD front torsen diff
* cusco 40/60 tarmac center diff
* R160 quife torsen LSD rear diff
* Rear driveshaftshop stage 5 axels
SUSPENSION
* KW variant 3 struts with 10k springs up front, 9k springs rear (i believe?)
* Cusco adjustable camber plates front and rear
* all whiteline: front top strut tower brace, roll center adjuster, anti lift kit med, 24mm heavy duty adjustable front/rear sway bars. rear sway bar mount heavy duty. rear full adjustable lateral links, front sway bar link heavy duty front/rear
* sti pink trailing links with tic harden bushings
* all GTspec: trunk cage, trunk rear reinforcement floor brace, front lower tie brace, sub frame reinforcement brace (3 pieces), 4 point front ladder brace. fender reinforcement brace Known as the "Gacchiri Support" in Japan or CAWL Support by SPT. (basically all the GT products you can think of for bracing, its on this car)
FOOTWORK
Footwork:
* 18x9.5 enkei NT03 in a limited 5x100 SBC coating, wrapped int Dunlap direzza starspecs 18/265/35. running spacers in front.
* 18x.9.5 work emotion kai, brand new hankook rs3 265/35/18 for track.
* Wilwood 6 piston calipers front, 4 piston rears. wilwood slotted disc with hubs. wilwood f/r stainless steal braided brake lines.
* project kics titanium extended lug nuts (baller)
* arp extended lug nuts front/rear.
EXTERIOR
* Sti front bumper, sti splitters, sti fog light covers.
* jna jdm style lip
* kaminari cf hood
* ALL APR: front cannards, gtc 300 cf wing, front splitter with supporting rods
* ALL Varis: dry carbon fiber trunk skin, dry carbon fiber trunk skeleton, dry carbon fiber vortex generators with custom aluminum mounts, dry carbon fiber diffuser.
* sti sideskirts with chargespeed cf sideskirts, and chargespeed cf shark fin diffuser
* sti hid headlights from lightwerks.
* nakabe tow hook
INTERIOR/ELECTRONICS
* Racetech RT4009 passenger and driver side seats/ractech 5 point harness driver side quick release, passenger normal. driver side harness good till 2015
* cusco seat rail mounts, recaro sliders
* Hydra 2.5v ECU with wideband/launch controll
* aem gauges: wideband, fuel pressure, coolant temp, oil pressure, oil temperature.
* eboost 2 40 psi boost controller
* Keys Racing steering wheel, bell works hub
* bolt in autopower roll bar/optional diagnal bar
* not to mention, hours upon hours of mechanical time, tuning time, suspension tuning. $$$
I WILL NOT PART OUT, DONT EVEN ASK YOU WILL BE IGNORED, I WOULD RATHER SELL IT AS WHOLE. I WILL NOT ENTERTAIN ANY TRADE OF ANY SORT, UNLESS YOU WANT TO PUT 30K ON A DOWNPAYMENT FOR A HOUSE FOR ME. CASH IS KING, WETHER YOU GET FROM YOUR BANK OR YOUR 401K/GRANDMA. CASH WILL BE CLEARED WITH BANK OR CASHIERS CHECK WILL CLEARED WITH BANK AND THEN I WLL HAND OVER PINK IF YOU HAVE PROBLEM WITH THIS CLICK THE BACK BUTTON ON TOP LEFT. DO NOT LOW BALL ME, I KNOW HOW MUCH THIS STUFF COST. TO DO THIS CAR OVER AGAIN YOU WOULD BE SPENDING WILL WORTH OVER 50K
$27,000 obo
if you have any questions please pm/ or email me gqpnoi@aol.com. also i live in las vegas nv, i am willing to ship car if buyer wants to work out deal
Rod702 is offline   Reply With Quote
Old 01-26-2013, 05:38 AM   #2
Rod702
Member#: 132978
Old 01-26-2013, 05:39 AM   #3
Rod702
Member#: 132978
Old 01-26-2013, 07:01 AM   #4
wadud
Member#: 258048
06 wrx
E.S.A.C
Great lookin car!!!!! GLWS!!!!!!
JIM
wadud is offline   Reply With Quote
Old 01-28-2013, 12:07 AM   #5
yazel
Member#: 215344
Really cool car and fair price! GLWS
yazel is offline   Reply With Quote
Old 01-28-2013, 01:18 PM   #6
brendan04wrx
Member#: 167494
04 STi
psm
nice build! makes me miss my 04 front end. good luck!
brendan04wrx is offline   Reply With Quote
Old 01-29-2013, 02:41 PM   #7
Rod702
Member#: 132978
thanks for the free bumps guys!
Old 01-30-2013, 10:14 AM   #8
TwinscrollGT35R
Member#: 256810
Wow great looking car. Well worth the money.
TwinscrollGT35R is offline   Reply With Quote
Old 01-30-2013, 06:03 PM   #9
2009subibaby
Member#: 309281
2009 impreza wrx
black
This coupon is goodfor one free "BUMP"
p.s. nice car man GLWS....
2009subibaby is offline   Reply With Quote
Old 03-05-2013, 07:43 PM   #10
Rod702
Member#: 132978
Took car out to sping Mountain raceway for a shakedown on wastegate pressure. Car had zero issues and handled amazing! Scary fast, still on wastegate pressure!
Old 03-06-2013, 11:11 PM   #11
2013 STI
Member#: 349322
Wish I had seen this before buying my 2012 STi.
2013 STI is offline   Reply With Quote
Old 03-07-2013, 02:07 PM   #12
Grippen
Member#: 329712
2005 Sti
Wow. Impressive, glws!
Grippen is offline   Reply With Quote
Old 03-19-2013, 11:40 PM   #13
02scooby
Member#: 72999
I absolutely love it. =)
02scooby is offline   Reply With Quote
Old 03-20-2013, 02:35 PM   #14
707rs84
Member#: 307437
04 sti
flat black
Default Interested in ur car.
First i would like to say this is one if the most beautiful cars ive seen both visualy and mechanically. The choise of parts is outstanding.
I emailed u about 2me wks ago offering 23k,u werent interested, and i understand.
I was about to build my widebody sti close to your specs, after getting a list together i realized i can buy a car gor the price of a built engine. So thats what i am doing. All cars i havr looked at i am most interested in urs. I have 23k cash in hand. I am a huge subaru fan and own a few subarus 98 rs 02 wrx, 04 sti. So ur car would u b at a good home. As stated i have 23k cash. I live in nor cal and would have to drive to vegas so it will be a ride for me but lets work something out. My name is kyle and my number is 707-272-4645
707rs84 is offline   Reply With Quote
Old 03-20-2013, 06:01 PM   #15
Rod702
Member#: 132978
pmed you back bud. looks like we have a solid buyer in the works!
Old 03-22-2013, 07:34 PM   #16
Rod702
Member#: 132978
Just want to throw this out there. If ur a drug dealer and want me to laundry money for u. Look else where, I will not deal with low life scums of the earth that prey on the hopeless and weak. I don't care how much cash u bing to the table, I won't sell u my car.
Old 04-02-2013, 02:36 PM   #17
Rod702
Member#: 132978
bumpsky
Old 04-07-2013, 10:15 PM   #18
thisisthenewsic
Member#: 156829
05 legacygt,00 OBS
red 95 supercharged nsx
Greatly build car. Glws! Killer price!!!
thisisthenewsic is offline   Reply With Quote
Old 04-08-2013, 02:12 PM   #19
belaud
Member#: 224449
2012 Kit B STI
Midnight ???
Have my children please.
belaud is offline   Reply With Quote
Old 04-09-2013, 09:41 PM   #20
Rayleal760
Member#: 299952
Bump for bad ass car .. good luck on sale
Rayleal760 is offline   Reply With Quote
Old 04-15-2013, 07:58 PM   #21
Rod702
Member#: 132978
Included in price track shoes
Work emotion Kai 18x9.5
Brand new hankook rs3 265/35/18
Old 04-16-2013, 06:14 PM   #22
Rod702
Member#: 132978
2 sets a of wheels bump!
Old 04-17-2013, 08:25 PM   #23
wrxsomeday
Member#: 141991
08 STi AW
12 Legacy 3.6R
This thing looks nuts! Why sell? Anyway, glws and fair price.
wrxsomeday is offline   Reply With Quote
Old 04-18-2013, 04:53 PM   #24
Rod702
Member#: 132978
Trying to put money down on a house
Old 04-18-2013, 04:58 PM   #25
bluetorch
Member#: 236285
2004 STi Race Car
Black & Green
Very nice looking car, and good luck on the new home purchase. Not sure if you tracked it much, but did you notice much of a difference from the front splitter and rear wing?
bluetorch is offline   Reply With Quote
