#326 | |
Member#: 92423
Tri-State
Vehicle:2002 WRX still locked in freezer |
#327 |
Member#: 328135
Vehicle:2004 impreza WRX Blue |
So, I've only read up to page 11....
But is this a good mod or not? I heard the stock BOV should not be touched until your using over 22PSI of boost? Or else it will in-fact hurt performance. Does this mod also cause any more of a blow off sound. |
#328 |
Member#: 270482
Vehicle:2011 forester xt corn fed td06 20g 8cm |
It made my bpv more noisey and it holds boost alot better between shifts.
#329 |
Member#: 198861
SCIC
Vehicle:2004 WRX PSM |
gnna try this out. hopefully i feel a gain
#330 |
Member#: 328135
Has anyone seen the results on a tune or dyno? I think that is the major determination for doing this or not?
#331 |
Member#: 198861
SCIC
bringing this thread back to life. any more results anyone?
#332 |
Member#: 334417
South East
Vehicle:02 impreza wrx black blue pearl |
good idea wish i could do that to my parents but i'd need the money simple mods like this r what i like to see. got anymore simple cheap mods?
#333 |
Member#: 325517
Tri-State
Vehicle:2002 wrx blue |
Just crush the bov it will work good
#334 | |
Member#: 182415
Tri-State
Vehicle:1999 RS Aspen White |
I got to really drive the car hard over the weekend with some buddies, did about 250 miles around the mountains over saturday night. Going from full brake to full throttle gets me nice, quick and steady spool, and a rock solid hold on the boost, quick vacuum/boost transitions seem to be a bit quicker/smoother as well. About 3 weeks ago we did this to another buddies car who also feels its improved driveability in the same ways i did, all in all this is a winner! I even bought some extra set screws incase my buddies want to do it haha |
#335 | |
Member#: 335235
Vehicle:05 Liberty GT |
+1 for this mod. |
#336 |
Member#: 270482
I am running this just like above on the plastic bpv but now am running a td06 20g at 22psi on e85. Do you think it will hold up or should i bite the bullet and buy a forge recirculating bpv? I think its still working fine and my tuner was impressed but just wondering how far you guys have pushed this mod befor the breaking point.
#337 | |
Member#: 129681
Vehicle:2014 FXT Touring SWP |
In other words, you are fine. |
#338 |
Member#: 336361
VIC
Vehicle:2009 WRX WRB |
Excellent mod. Amazing bang for...well it didn't co$t me anything!
#339 |
Member#: 316517
NESIC
Vehicle:2012 WRB WRX Hatch TP Stage III (291/313) |
For something as serious as drilling a goddamn hole in your BPV, you would think people would have some better photos.
I want to do this, since it's free, but I haven't gained the appropriate confidence here. Where on the stock BPV do I drill a hole in it? |
#340 |
Member#: 263694
Vehicle:2002 WRX World Rally Blue |
Read the whole thread before your flip out.. They are on the second or third page
#341 |
Member#: 316517
NESIC
#342 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
why not post a picture yourself?
#343 |
Member#: 316517
NESIC
#344 |
Member#: 32792
NESIC
i mean of your virgin oem plastic bpv, so that someone can point it out to you.
#345 |
Member#: 135787
Bumping this thread again. Anyone got a pic of the side vent hole they drilled on the newer plastic BPVs?
#346 |
Member#: 89016
Vehicle:2005 Legacy GT Wagon ABP |
Just did this to mine last night - first drive definitely felt like it was easier to hold boost through shifts. Lovin it.
norbs - I drilled just high enough to be sure to clear the set screw. |
#347 | |
Member#: 254771
Vehicle:2011 WRX hatchback silver - Stage 2 |
[edit] Found pics here: http://forums.nasioc.com/forums/show....php?t=2169450 So here are the pics needed: Last edited by KMA2; 03-06-2013 at 03:57 PM. Reason: Found it |
#348 |
Member#: 254771
Quick question: I've read through the thread, but I'm hoping someone can explain to me why the stock BPV valve isn't designed this way to begin with? Is it to avoid surge for the "normal" stock driver? Thanks in advance.
#349 |
Member#: 32792
NESIC
yes, the stock valve will open with less pressure differential.
why they didn't just use a weaker spring? who knows. |
#350 |
Member#: 176692
thanks
